RE: New CDI - opensource project JMJ and Bigboat
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
TMM New Version Released -TMM53N - RTR
Seller:  24H-Hobby
Details:   $350.00   |  3/16/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: New CDI - opensource project JMJ and Bigboat
Page: <<   < prev  28 29 [30] 31 32 33 34 35 36 37   next >   >>
Login
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 5:58 AM
gr8flyer55
Score: 100
Last Login: 3/18/2010
Status: offline
Brett.. I used the timer board set for the 7000 rpm test..I don't have anything else that spins fast enough to try higher speeds.
Board # 4 seems to be a failure.. Just built it and there is something wrong with it.. Bad parts placement or something..not sure yet.. did have to move a few components and omit the diode cause my timer board already has it on. Tried tracing the circuit with a logic pen and signals and voltages are wrong.. Oh well... Back to drawing board for #4.
John
Hide Signatures
(in reply to kermet)
       Post #: 726
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 7:13 AM
Bigboat
Score: 100
Last Login: 3/20/2010
Status: offline
@Brett,
This to pics show the exelsheet wat is possible.
Put you mousepoint on itand pulldown the menu.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
CU, Rob - www.modelbouw.gompy.net
Hide Signatures
(in reply to gr8flyer55)
       Post #: 727
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 7:18 AM
Bigboat
Score: 100
Status: offline
quote:
ORIGINAL: COM
Hi Brett, Yea I only post some of the table just to show the 0s in the table.
Rob, Can you confirm if there is a problem with the latest curve generator?
There isn't.
In the old curvegenerator you have to fill in all 255 values, every input has his own value.
In the new curvegenerator you only have to file in 20 values, only the value you fill in has his own value the other values will be calculate.
Feeld 1 is value 2, feeld 2 is value 8, between feeld 1 and feeld 2 there are ~20 calculate values.
If you want to fill in the new curvegenerator also 256 values I can change the sheet, but I can't see wat you win with it.
Hide Signatures
(in reply to COM)
       Post #: 728
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 8:46 AM
kermet
Score: 100
Last Login: 3/16/2010
Status: offline
Charlie it was mainly for the newbie (or and myself) to save time but thank you
John have you seen this little tester i came across yesterday ,
http://www.prcmodel.com/module.php?name=onlinestore&func=viewprod&product=340
Rob i understand what to do But in my exel program that cell is protected and i can not change it,  you have passwrd protect that cell
brett
Hide Signatures
(in reply to Bigboat)
       Post #: 729
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 8:47 AM
Bigboat
Score: 100
Status: offline
quote:
ORIGINAL: gr8flyer55
Can't you use your pcb-drill ?
I check the board twice, but I can't find any failure.
Hide Signatures
       Post #: 730
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 5:02 PM
gr8flyer55
Score: 100
Status: offline
Rob, it may be a bad part here..although I always use brand new parts, some defective part may have been soldered to the PCB.
Tried alot of things and am not getting oscillation with the MJE3055t..just gets hot instantly!
Switched the primary winding, feedback windings, tried lowering the resistor value, raising it, changed the capacitor..still gets hot and no output..
Switched the toroid to another board I made and it's ok..get 450 volts at 450 windings.. oscillates on that board so it's wiring, parts placement or a bad part.
John
Hide Signatures
       Post #: 731
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 5:12 PM
Bigboat
Score: 100
Status: offline
I'll try this evening to findout wat can be wrong.
You are sure you drawings, schematic and pcb, are right ?
Hide Signatures
       Post #: 732
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 5:13 PM
gr8flyer55
Score: 100
Status: offline
Just finished moving all the parts that didn't work (everything) to my design board and it worked perfect..I don't see what the problem is yet..will replace everything again and let you know what I find.
How did you place the diodes on that board.. I installed them all with the bands up. Should not be the problem but maybe..looked correct to me.
John
Hide Signatures
       Post #: 733
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 5:33 PM
Bigboat
Score: 100
Status: offline
The diodes are wrong installed I think.
If you put them all with the ring up and all at the same side and the ring to the big C, that will be correct.
I've a new scanner but I didn't know how he works......yet.
Click for fullsize
< Message edited by Bigboat -- 2/9/2010 6:41 PM >
Hide Signatures
       Post #: 734
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 7:36 PM
COM
Score: 100
Last Login: 3/19/2010
Status: offline
Rob,
this table is from the latest version of the curve generator.I got it from here: http://www.electronics.gompy.net/cditci/
notice the 0s all through out the table. I think there is a glitch in the code that generates the table.
 27,  28,  28,  29,  29,  30,  30,  31,  31,  32,  32,  33,  33,  34,  35,  35,  36,  36,  37,  38,  38,  39,  39,
         39,  0,  41,  0,  42,  42,  42,  0,  44,  0,  44,  45,  46,  46,  0,  47,  48,  0,  48,  0,  50,  50,  51,  51,  52,  0,  53,  53,
         54,  54,  55,  56,  0,  56,  57,  58,  0,  59,  59,  60,  0,  61,  62,  63,  64,  64,  64,  65,  66,  0,  68,  68,  69,  69,  0,
         71,  71,  72,  73,  74,  75,  75,  76,  76,  77,  78,  79,  79,  0,  81,  82,  83,  83,  84,  84,  85,  0,  86,  87,  88,  89,
         90,  90,  91,  92,  93,  94,  94,  95,  95,  96,  97,  98,  98,  99,  100,  101,  0,  102,  103,  104,  105,  105,  106,  107,
         108,  108,  109,  109,  110,  111,  0, 113,  113,114,  115,  116,  116,  117,  118,  119,  120,  120,  121,  122,  123,  124,
         124,  0,  125,  126,  127,  128,  128, 129,  130,  131,  132,  132,  133,  134,  135,  135,  136,  137,  138,  139,  139,
         140,  141,  142,  143,  0,  144,  145,  146, 147,  147,  148,  149,  150,  150,  150,  151,  152,  153,  154,  154,  155,
         156,  157,  158,  158,  159,  160,  161,  162,  162, 163,  164,  165,  166,  166,  167,  0,  169,  169,  170,  171,  172,
         173,  173,  174,  175,  176,  177,  177,  178,  179,  180, 181,  181,  182,  183,  184,  185,  185,  186,  187,  187,
         188,  188,  189,  190,  191,  192,  192,  193,  194,  195,  196, 196,  197,  198,  199,  200,  200,  201,  202,  203,
         204,  204,  250
Regards
Charlie M.
Hide Signatures
       Post #: 735
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 7:45 PM
Bigboat
Score: 100
Status: offline
The zero's are the last numbers in row, highest rpm, you never use them >16.000rpm.
The CDI and TCI start at the end to read.......not the first ones.
You can download the old generator if you don't trust me http://www.electronics.gompy.net/cditci/oldcurve.zip
Hide Signatures
(in reply to COM)
       Post #: 736
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 8:30 PM
gr8flyer55
Score: 100
Status: offline
I have high voltage now but can't trigger the scr..hmmmm..maybe bad scr now from ac flowing thru it..found 2 bad diodes anyway.. so that was part of it. Now have 450 volts at the .47uf cap.
Going to replace the SCR to see if that's it..never had a bad one but you never know..never had a bad diode either till now!
John
Hide Signatures
       Post #: 737
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 8:36 PM
Bigboat
Score: 100
Status: offline
Yesterday I have only one more TIC106 in stock.........it fired ones and he was broken.
I think the Voltage distroy the scr, there was 650 Volt on the C.
Hide Signatures
       Post #: 738
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 9:45 PM
COM
Score: 100
Status: offline
In the table I posted thee are no 0s in the last row. there all over the table. and they are not consecutive. Why are the code tags not working???
.....and Rob I do trust you.
quote:
27, 28, 28, 29, 29, 30, 30, 31, 31, 32, 32, 33, 33, 34, 35, 35, 36, 36, 37, 38, 38, 39, 39, <<<<<<<<<<<<<<<<<<<<<<<<<<<<<< no 0s here
39, 0, 41, 0, 42, 42, 42, 0, 44, 0, 44, 45, 46, 46, 0, 47, 48, 0, 48, 0, 50, 50, 51, 51, 52, 0, 53, 53, <<<<<<<<<<<<<<<<< 54, 54, 55, 56, 0, 56, 57, 58, 0, 59, 59, 60, 0, 61, 62, 63, 64, 64, 64, 65, 66, 0, 68, 68, 69, 69, 0, <<<<<<<<<<<< 71, 71, 72, 73, 74, 75, 75, 76, 76, 77, 78, 79, 79, 0, 81, 82, 83, 83, 84, 84, 85, 0, 86, 87, 88, 89,
90, 90, 91, 92, 93, 94, 94, 95, 95, 96, 97, 98, 98, 99, 100, 101, 0, 102, 103, 104, 105, 105, 106, 107, <<<<<<<<<<<<< 108, 108, 109, 109, 110, 111, 0, 113, 113,114, 115, 116, 116, 117, 118, 119, 120, 120, 121, 122, 123, 124, <<< 124, 0, 125, 126, 127, 128, 128, 129, 130, 131, 132, 132, 133, 134, 135, 135, 136, 137, 138, 139, 139, 140, 141, 142, 143, 0, 144, 145, 146, 147, 147, 148, 149, 150, 150, 150, 151, 152, 153, 154, 154, 155,<<<< 156, 157, 158, 158, 159, 160, 161, 162, 162, 163, 164, 165, 166, 166, 167, 0, 169, 169, 170, 171, 172,<<< 173, 173, 174, 175, 176, 177, 177, 178, 179, 180, 181, 181, 182, 183, 184, 185, 185, 186, 187, 187, <<< 188, 188, 189, 190, 191, 192, 192, 193, 194, 195, 196, 196, 197, 198, 199, 200, 200, 201, 202, 203, <<<<< not here
204, 204, 250
Regards
Charlie M.
Hide Signatures
       Post #: 739
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 9:55 PM
Bigboat
Score: 100
Status: offline
If you don't fill in ALL yellow rectangles, there will be zero's into your code.
const char tspark[]={ 0, 0, 0, 1, 1, 2, 2, 3, 3, 4, 4, 5, 5, 6, 6, 7, 8, 8, 9, 9, 10, 10, 11, 11, 12, 12, 13, 13, 14, 14, 15, 16, 16, 17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 25, 25, 25, 26, 26, 27, 26, 27, 27, 26, 27, 27, 26, 26, 26, 27, 26, 26, 27, 27, 27, 25, 25, 26, 26, 26, 24, 24, 24, 25, 25, 25, 22, 22, 23, 23, 23, 23, 24, 22, 22, 23, 23, 23, 24, 24, 24, 22, 22, 23, 23, 23, 23, 24, 24, 24, 24, 25, 23, 23, 23, 23, 24, 24, 24, 24, 24, 25, 25, 25, 25, 23, 23, 23, 24, 24, 24, 24, 24, 25, 25, 25, 25, 25, 26, 26, 26, 23, 23, 24,
24, 24, 24, 24, 24, 25, 25, 25, 25, 25, 25, 26, 26, 26, 26, 26, 27, 27, 27, 27, 24, 24, 24, 24, 24, 25, 25, 25, 25, 25, 25, 25, 26, 26, 26, 26, 26, 26, 27, 27, 27, 27, 27, 27, 28, 28, 28, 28, 28, 28, 28, 25, 25, 25, 25, 25, 25, 25, 25, 26, 26, 26, 26, 26, 26, 26, 26, 27, 27, 27, 27, 27, 27, 27, 27, 28, 28, 28, 28, 28, 28, 28, 29, 29, 29, 29, 29, 29, 29, 30, 30, 30, 30, 30, 30, 30, 30, 31, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 27, 27, 27, 27, 27, 27, 27, 27, 28, 28, 28};
I don't have zero's........all yellow rectangles have a value.
I'll try to explain.
The sheet calculate the value between two yellow rectangles.
If you don't fill in all values, the sheet will see this like a zero......nothing into the rectangle - no value - zero.
Hide Signatures
(in reply to COM)
       Post #: 740
RE: New CDI - opensource project JMJ and Bigboat - 2/9/2010 11:00 PM
COM
Score: 100
Status: offline
Thanks Rob,
I will play with it.
Regards
Charlie M.
Hide Signatures
       Post #: 741
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 1:57 AM
gr8flyer55
Score: 100
Status: offline
Brett..that tester for ignitions I make here...555 timer chip 2 caps and 2 resistors..mine is set for 3000 rpms. want the schematic? it's a small board about 3/4 x 3/4 inch.. I'll upload a picture of my tester board drilled ready for components..
John
Click for fullsize
Click for fullsize
< Message edited by gr8flyer55 -- 2/14/2010 4:24 AM >
Hide Signatures
       Post #: 742
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 2:11 AM
gr8flyer55
Score: 100
Status: offline
Rob.. The diode placement on the hv-4 board doesn't match the layout..downloaded the Layo1 program, ran it, loaded your board and there are mismatches..extra traces, extra resistor, so you may have mixed a previous board with my circuit.. That's what I found so far.. tested the board again and still no trigger. I have high voltage to the cap, if I short across it after I unplug the battery and timer board, it gives a large spark..presence of being charged..still not sure what it is..same trigger circuit added as I have on mine but no triggerring yet.. Oh well.
Hide Signatures
       Post #: 743
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 2:17 AM
COM
Score: 100
Status: offline
Hi John,
So with your tester the pulse is fixed?
Regards
Charlie M.
Hide Signatures
       Post #: 744
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 2:28 AM
gr8flyer55
Score: 100
Status: offline
Yes the output is a fixed value timed pulse.. but if you play around with a variable resistor in the range, you could make it really sing !! I've done it but most small enough pots to fit on the board were twitchy..so when you plug this one in, it assumes the role of 3000 rpm..can be changed.. maybe a series of dip switches?? now there's an idea!! try it Charlie.. who knows.. you may be the next electronic guru!
John
Hide Signatures
(in reply to COM)
       Post #: 745
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 2:30 AM
gr8flyer55
Score: 100
Status: offline
Just added the component layout hand drawn but effective, with the resistor and cap values...
I think when I did it, I substitued a pot for R-2 the 10k resistor...so try a 50k pot maybe? enjoy!
John
Hide Signatures
(in reply to COM)
       Post #: 746
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 3:26 AM
COM
Score: 100
Status: offline
I made one using a pic. it seems to work OK. I can vary it from 500 rpm to 12000. Once I am satisfied I will post the schematic and layout.
Regards
Charlie M.
Hide Signatures
       Post #: 747
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 9:38 AM
Bigboat
Score: 100
Status: offline
This is the list from the cdipwr4 board, wat components doesn't belong to your schematic ?
Rhall = NOTE 1
The timerboard with the NE555 can given een problem.
You need a astable timer with a dutycycle with less 1%.
http://www.kpsec.freeuk.com/555timer.htm#astable
If the freq of the NE555 is to low and the dutycyle is 50/50%, you blowup the scr or you can't fire the scr.
The schematic with the diode in it can do the job.
You can also use a second CDI/TCI timerboard to test the CDI or TCI.
Instead of a hall sensor you connect the second timerboard output on the hallsensor input.
LINE 6 - if (PORTB & 0x04) delay_ms(200); // 300 rpm
Into the code you can change the timing of the testpulses, 200 = 300rpm, 100 = 600rpm, 50 = 1200rpm, 25 = 2400 rpm, 5 = 12,000rpm
Click for fullsize
< Message edited by Bigboat -- 2/10/2010 11:56 AM >
Hide Signatures
       Post #: 748
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 12:01 PM
Bigboat
Score: 100
Status: offline
Where will be the zero's ????? I found them !!!!!!!!!
const char tspark[]={ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 2, 2, 3, 3, 3, 3, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 8, 8, 9, 10, 10, 10, 12, 12, 12, 13, 14, 14, 15, 16, 16, 18, 18, 18, 18, 23, 23, 24, 24, 24, 25, 25, 26, 26, 26, 30, 30, 31, 31, 32, 32, 32, 33, 33, 34, 34, 35, 35, 39, 40, 40, 41, 41, 42, 42, 42, 43, 43, 44, 44, 45, 45, 46, 46, 47, 47, 48, 53, 53, 54, 54, 55, 55, 56, 56, 57, 57, 58, 58, 59, 59, 60, 60, 61, 61, 62, 62, 63, 63, 64, 64, 65, 65, 66, 66, 67, 74, 74, 75,
75, 76, 76, 77, 77, 78, 78, 79, 80, 80, 81, 81, 82, 82, 83, 83, 84, 85, 85, 86, 86, 87, 87, 88, 88, 89, 90, 90, 91, 91, 92, 92, 93, 93, 94, 95, 95, 96, 96, 97, 97, 98, 98, 99, 100, 100, 101, 101, 102, 102, 103, 104, 104, 104, 105, 106, 106, 107, 107, 108, 108, 109, 110, 110, 111, 111, 112, 112, 113, 113, 114, 115, 115, 116, 116, 117, 117, 118, 118, 119, 120, 120, 121, 121, 122, 122, 123, 123, 124, 125, 125, 126, 126, 127, 127, 128, 128, 129, 130, 130, 131, 131, 132, 132, 133, 133, 134, 134, 135, 136, 136, 137, 137, 138, 138, 139, 140, 140, 141};
If you can see, I have to change the curve into the wrong way a 2 stroke need.
Click for fullsize
Hide Signatures
       Post #: 749
RE: New CDI - opensource project JMJ and Bigboat - 2/10/2010 3:43 PM
gr8flyer55
Score: 100
Status: offline
Rob, I added my parts list to the schematic....
I have been using the 555 chip based tester board for 10 years without a problem..as long as you leave it set with values given, it works at 3000 rpm.
John
Click for fullsize
Hide Signatures
       Post #: 750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.484RCU1
