RE: New CDI - opensource project JMJ and Bigboat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: New CDI - opensource project JMJ and Bigboat
Page: <<   < prev  49 50 51 52 53 54 55 [56] 57 58   next >   >>
Login
RE: New CDI - opensource project JMJ and Bigboat - 6/9/2011 11:19 AM
COM
Score: 100
Last Login: 3/13/2013
Status: offline
Hi Nyemi,
Thanks for the code and all the help. I loaded your code into a pic and was testing it on a development board and I don't get any output until after I toggle the input several times.Also how do I change the curve in the spreadsheet? Thanks again.
Charlie
_____________________________
Regards
Charlie M.
Hide Signatures
(in reply to nyemi)
       Post #: 1376
RE: New CDI - opensource project JMJ and Bigboat - 6/10/2011 9:27 AM
nyemi
Score: 210
Last Login: 6/17/2013
Status: offline
Many people ask, what difference the old code.The low speed (RPM) treatment.
452 rpm lower rpm, no spark.  But the program change.
Between 452-917 rpm. Defined spark advance.(15°   But the program change. Help Excel table.
917-468750 rpm of the table defines vary spark advance. But the program change. Help Excel table.
I  present pictures.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by nyemi -- 6/13/2011 10:01 AM >
Regards nyemi.
Hide Signatures
(in reply to nyemi)
       Post #: 1377
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 2:58 AM
gr8flyer55
Score: 600
Last Login: 6/18/2013
Status: online
Hi Nyemi...
Well, I just programmed the first successful chip with the edited lines in the ASM source code you provided. I believe we have a winner!!!! I tested the timer board with my test bed setup and the timing advance is excellent! I still have to run the test motor with it but it works perfect so far!
Thank you for all your hard work!
Finally we have good code for the old timer board with the internal oscillator in the PIC chip !!!!! You are a genius!
John
Hide Signatures
(in reply to nyemi)
       Post #: 1378
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 3:25 AM
gr8flyer55
Score: 600
Status: online
Hi Charlie...
I just programmed a 16f628A with the new hex file from Nyemi, and we finally have success!!!
I'll post the hex file shortly. I made the low rpm <458 change and also the mclr change in the last few lines of the program and assembled it with MPLAB-ASM. Works perfectly!
I would say you should try it for yourself and try it on the old timer board I sent you. Works like a charm here.
I used the 16F628A pic. Program source will have to be changed for the 16f628 to be used though.
John
Hide Signatures
(in reply to COM)
       Post #: 1379
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 8:39 AM
COM
Score: 100
Status: offline
Well this is good to hear. John, did you go with the default curve? I am having problems getting the code to assemble. Thanks for the info.
Regards
Charlie M.
Hide Signatures
(in reply to gr8flyer55)
       Post #: 1380
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 1:09 PM
gr8flyer55
Score: 600
Status: online
Hi Charlie,
Yes it is good news!
I used the default curve because it's so hard to change the excel sheet.
When I test run my plane today I want to do a video of it and then try to post it for all to see.
If we can change the curve, I have my curve to replace it with that worked so well before with the old code.
John
Hide Signatures
(in reply to COM)
       Post #: 1381
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 1:17 PM
gr8flyer55
Score: 600
Status: online
I want to post the hex file but the forum doesn't accept the format.
How do I post it?
John
Hide Signatures
(in reply to COM)
       Post #: 1382
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 2:59 PM  1 votes
CH Ignitions
Score: 420
Last Login: 6/16/2013
Status: offline
John,
I have a suggestion, Open the HEX with notepad, save it as .txt . Then when downloaded, open back again in text, copy the content...EXACTLY, open a old hex file with notepad, clear all inside, paste the content from the downloaded file and close.
Another option will be to add at the end of the file. TXT, after download on your computer delete the .TXT extension. It my ask you some " are you sure you wnat to change format file or extension" say Yes.
I think it should work.
John you will be able to try this option, do this on local computer, change the extension to .txt, email it to your self, then revert the .TXT and try to reload the PIC. If it works ...then post it here and will now it works.
Thank You
Adrian Ciulei
www.ch-ignitions.com
Hide Signatures
       Post #: 1383
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 7:22 PM
COM
Score: 100
Status: offline
John,
Can you compile the asm code ? I get errors.
Regards
Charlie M.
Hide Signatures
(in reply to CH Ignitions)
       Post #: 1384
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 10:27 PM
gr8flyer55
Score: 600
Status: online
Yes, I have it assembled and working great here.
My problem is posting the hex file on here. I'll have to just send it to you in email as an attachment.
John
Hide Signatures
(in reply to COM)
       Post #: 1385
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 10:40 PM
COM
Score: 100
Status: offline
HI John,
Just copy and paste it between code tags.
Do you have a copy of the old nyemi spread sheet?
Regards
Charlie M.
Hide Signatures
       Post #: 1386
RE: New CDI - opensource project JMJ and Bigboat - 6/11/2011 11:53 PM
gr8flyer55
Score: 600
Status: online
I have the old spreadsheet file for you Charlie.. I'll send you another email with it attached. Just sent you the hex file of the new code but it only works on a 16f628A chip. While assembling it with the MPlab program, it asked for a target chip number. I only had 16f628a chips sitting here and wanted to try it out so that's what it was assembled for. I'll do another one for us with the 16f628 chip as a target and send that to you also. When I can, I'll try posting both hex files on here for everyone to download that's interested.
I use Picprog4u to write to the chips and it gave me a warning when I tried the 628 instead of the 628a..needless to say it didn't work when programmed cause it had the chip internal info for the 628a in the hex file. Oh well live and learn I guess.. Have to erase that one and try again with the right code.
John
Hide Signatures
(in reply to COM)
       Post #: 1387
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 12:00 AM
gr8flyer55
Score: 600
Status: online
Charlie.. We had this happen before.. What do you mean code tags? Is it a symbol I type or what? never did it.
John
Hide Signatures
(in reply to COM)
       Post #: 1388
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 12:38 AM
COM
Score: 100
Status: offline
Hi John,
IT won't show the code tags so I will email you with what they are.
< Message edited by COM -- 6/12/2011 1:02 AM >
Regards
Charlie M.
Hide Signatures
       Post #: 1389
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 2:12 AM
gr8flyer55
Score: 600
Status: online
Ok Charlie...not a problem. I'll check my mail.
Oh, by the way, I just ran my airplane with the ignition & timer..Works like a charm! So I hooked up the strobelight to see what the timing was doing, and it advances perfectly! I just have to tinker with my static timing a tad...not at exactly the right position for starting yet but it started right up and ran great! I was starting a video when the thunderstorm came and ruined my video! Oh well..tomorrow's another day.
John
Hide Signatures
(in reply to COM)
       Post #: 1390
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 2:16 AM
gr8flyer55
Score: 600
Status: online
Charlie, did you recieve the hex file I sent to you?
John
Hide Signatures
(in reply to COM)
       Post #: 1391
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 2:23 AM
gr8flyer55
Score: 600
Status: online
trying the code tags...if it works, here's the hex file for a 16f628A I'm running in my timer on my plane.
John
:020000001929BC
:08000800F000030E8301F1007A
:10001000A70A0B119501710E8300F00E700E0900F6
:100020000000003400340034003400340034003464
:10003000013401340234023402340334033404340E
:1000400004340534053406340634063407340734E2
:1000500007340734073407340734073407340734C8
:1000600007340734073407340734063406340634BB
:1000700006340734073407340734073407340734A9
:100080000734073409340934093409340A340A348A
:100090000A340A340B340B340B340B340B340B346A
:1000A0000B340B340D340D340D340D340E340E344A
:1000B0000F340F341034103411341134123412341C
:1000C00012341234143414341534153416341634EE
:1000D000173417341834183419341A341A341A34BB
:1000E0001A341C341D341D341E341E341F34203485
:1000F000203421342234223423342334243425344C
:100100002534263427342834283428342A342A3411
:100110002B342C342D342D342E342F3430343034D1
:100120003134323433343334343435343634373490
:100130003734383438343A343B343C343C343D344E
:100140003E343F3440344134423443344334443405
:10015000453446344734483449344A344B344C34BB
:100160004D344E344F34503451345234533454346B
:10017000543456345734583459345A345B345C341C
:100180005D345E345F3460346134623463346434CB
:1001900065346634673469346A346B346C346D3476
:1001A0006E346F347034723473347434743476341F
:1001B000773479347A347B347C347D347F348034C2
:1001C00081348234833485348634873488348A3465
:1001D0008B348C348E348F34903491349334943403
:1001E00095349734983499349B349C349D349F349F
:1001F000A034A134A334A434A534A634A634A7343F
:10020000A834A834A934AA34AB34AB34AC34AC34FD
:10021000AC34AE34AF34B034B034B134B234B234C0
:10022000B33408000313831222088A0021088200D5
:1002300008000313831225309F0003138316263012
:100240008500C8309F0002308600073081002430CE
:10025000920003138312850120308600910104303F
:100260009200123095000C309700A401A701810183
:10027000A0308B009F1B9501861841290130A400F6
:100280003A29A40803193A298B0195010108A50010
:100290008101013027020319502903187E295C29A6
:1002A00000000000000000000000A50803195A2902
:1002B000A5035029FF30A5002508ED3E031C8C291D
:1002C0002508113EA10000300318013EA2000A08D3
:1002D000A0001221A30020088A00A30803197E2988
:1002E000000000000000000000000000000000000E
:1002F0000000000000000000A30B702931308606CA
:100300003230A600000000000000A60B8229313028
:100310008606910112309500A401A701A0308B0040
:040320003A29192934
:02400E00503F21
:00000001FF
Hide Signatures
       Post #: 1392
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 2:30 AM
gr8flyer55
Score: 600
Status: online
Charlie, it worked..thanks alot for showing me what I should have known a long time ago.
Ok everyone interested.. there's the hex file that Nyemi's new code produced for a 16F628A pic chip in the older timer with the 2 chips on it, pic and optocoupler, so there's no confusion. Working great in my timer and with my CDI board. Project completed.
John
Hide Signatures
       Post #: 1393
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 11:39 AM
COM
Score: 100
Status: offline
HI John,
I did get the hex. Thanks. I was able to assemble the code. Would it be possible to post a schmatic for the timer board that this code works for? Do you have a design that you are using?
Regards
Charlie M.
Hide Signatures
       Post #: 1394
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 4:43 PM
gr8flyer55
Score: 600
Status: online
I'll post it later today Charlie. It's the one with the optocoupler on the board.
John
Hide Signatures
(in reply to COM)
       Post #: 1395
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 6:48 PM
Atam
Score: 100
Last Login: 5/26/2013
Status: offline
Charlie M.
Click for fullsize
Hide Signatures
       Post #: 1396
RE: New CDI - opensource project JMJ and Bigboat - 6/12/2011 6:52 PM
COM
Score: 100
Status: offline
Thanks.
Regards
Charlie M.
Hide Signatures
(in reply to Atam)
       Post #: 1397
RE: New CDI - opensource project JMJ and Bigboat - 6/13/2011 1:07 PM
gr8flyer55
Score: 600
Status: online
Hi Nyemi...
How do we change the curve in the excel sheet and then get it into the assembly source code?
John
Hide Signatures
(in reply to nyemi)
       Post #: 1398
RE: New CDI - opensource project JMJ and Bigboat - 6/14/2011 6:10 PM
nyemi
Score: 210
Status: offline
Hi gr8flyer55
You need to copy ASM code. The red band (retlw values).
Excel does not generate ASM code.
Do you have ignition curve? I produced ASM code. To you.
Regards nyemi.
Hide Signatures
       Post #: 1399
RE: New CDI - opensource project JMJ and Bigboat - 6/15/2011 1:41 AM
gr8flyer55
Score: 600
Status: online
Thanks Nyemi...
I'll make the changes to the Excel sheet and try copy & paste.
Hope to post some results after test runs and possibly a video.
John
Hide Signatures
(in reply to nyemi)
       Post #: 1400
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: New CDI - opensource project JMJ and Bigboat
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
