RE: New CDI - opensource project JMJ and Bigboat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: New CDI - opensource project JMJ and Bigboat
Page: <<   < prev  49 50 51 52 53 54 55 56 [57] 58   next >   >>
Login
RE: New CDI - opensource project JMJ and Bigboat - 6/15/2011 11:40 AM
gr8flyer55
Score: 600
Last Login: 6/20/2013
Status: offline
Nyemi, I need the starting degrees to be at 6 degrees. If I try to start my engine with the curve set the way it is, it kicks back hard when trying to start. Maybe setting advance from 458 rpm to 1000 rpm to be 6 degrees would work better.
John
Hide Signatures
(in reply to nyemi)
       Post #: 1401
RE: New CDI - opensource project JMJ and Bigboat - 6/15/2011 2:49 PM
nyemi
Score: 210
Last Login: 6/17/2013
Status: offline
Hi gr8flyer55
I will give you a blank curve. I do not understand that you want.
You show me,  low-speed ignition curve.
The image shows the low speed options.
The degree values ​​can be changed.
In this case 15 °.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by nyemi -- 6/28/2011 6:05 AM >
_____________________________
Regards nyemi.
Hide Signatures
(in reply to gr8flyer55)
       Post #: 1402
RE: New CDI - opensource project JMJ and Bigboat - 6/15/2011 10:34 PM
COM
Score: 100
Last Login: 3/13/2013
Status: offline
Hi Nyemi,
Thanks for all your efforts. Inital or POP(point of pickup) timing is 28 - 30 degrees BTDC. At starting rpm(rpm > 500) the curve needs to be at 5 degrees BTDC to avoid kickback. once the engine starts and idle then the curve can begine to advance. Thanks again.
Regards
Charlie M.
Hide Signatures
(in reply to nyemi)
       Post #: 1403
RE: New CDI - opensource project JMJ and Bigboat - 6/16/2011 3:17 PM
nyemi
Score: 210
Status: offline
Hi COM
I asked. 458 rpm under a green or black curve?
Motor bicycle works: no spark <458 RPM
You manually operate the engine.
I, therefore, deals with low RPM.
I count reverse.
Click for fullsize
< Message edited by nyemi -- 6/18/2011 8:08 PM >
Regards nyemi.
Hide Signatures
(in reply to COM)
       Post #: 1404
RE: New CDI - opensource project JMJ and Bigboat - 6/28/2011 4:12 AM
gr8flyer55
Score: 600
Status: offline
Hi Charlie...
It seems to work for me now that I reduced max static advance to 15 degrees. Need a reliable excel sheet.
John
Hide Signatures
(in reply to COM)
       Post #: 1405
RE: New CDI - opensource project JMJ and Bigboat - 6/28/2011 10:23 AM
COM
Score: 100
Status: offline
Hi John,
with the inital timing set at 15 degrees you won't be getting all you can out the engine.As I am sure you know.
Regards
Charlie M.
Hide Signatures
       Post #: 1406
RE: New CDI - opensource project JMJ and Bigboat - 6/28/2011 11:14 PM
gr8flyer55
Score: 600
Status: offline
I know Charlie, but at least it's not kicking back now. The advance should actually start after 1,000 rpm. That seems to be so hard to accomplish with this program and excel sheet.
John
Hide Signatures
(in reply to COM)
       Post #: 1407
RE: New CDI - opensource project JMJ and Bigboat - 7/1/2011 2:13 AM
gr8flyer55
Score: 600
Status: offline
Charlie, have you had any luck editing the excel sheet for Nyemi's new assembly program?
I had tried awhile to get it to stay at 0 degrees until it reached 1000 rpms. Every time I try, it seems to revert back to 458 rpms. Wish I knew the trick to get the edits to stay what I changed it to. That's all I need to complete the hex file to make it perfect.
John
Hide Signatures
(in reply to COM)
       Post #: 1408
RE: New CDI - opensource project JMJ and Bigboat - 7/4/2011 12:38 AM
COM
Score: 100
Status: offline
Hi John,
I have not been messing with the new code. I have instead been playing with the old code and fine tuning the excell sheet for it. I ported the code over to a 12F pic. now all that is left is to try it. I want ti do that tomorrow or tuesday. I will let you know what I find.
Regards
Charlie M.
Hide Signatures
       Post #: 1409
RE: New CDI - opensource project JMJ and Bigboat - 7/4/2011 12:39 AM
COM
Score: 100
Status: offline
John,
for faster replys you can just email me. then when it is all figured out we can post it here. just a thought.
Regards
Charlie M.
Hide Signatures
(in reply to COM)
       Post #: 1410
RE: New CDI - opensource project JMJ and Bigboat - 7/4/2011 3:29 AM
gr8flyer55
Score: 600
Status: offline
Let me know if it works Charlie. Getting nowhere here with edits. Although it does run my 25cc engine just fine after a rough start.
John
Hide Signatures
(in reply to COM)
       Post #: 1411
RE: New CDI - opensource project JMJ and Bigboat - 7/4/2011 9:38 PM
gr8flyer55
Score: 600
Status: offline
Charlie, we have perfection! Absolutely perfect!
I am getting 1 flip hand starts without a chicken stick.
1800 rpm very reliable idle and beautiful top end performance of 6800 rpm on my 25 cc conversion engine.
That's down from my normal idle of 1950 rpm and over 400 more top end from my usual 6400 rpm max I had before!
Excellent results I think.
I am in the process of getting everything finalized for a complete package ready to go and cheaper than an RCexcel.
Many things to do now from board production to final products. I have a shopping list underway here.
John
Hide Signatures
(in reply to COM)
       Post #: 1412
RE: New CDI - opensource project JMJ and Bigboat - 7/12/2011 11:30 PM
gr8flyer55
Score: 600
Status: offline
There's a new simpler timer board coming!
John
Hide Signatures
       Post #: 1413
RE: New CDI - opensource project JMJ and Bigboat - 7/13/2011 12:02 AM
COM
Score: 100
Status: offline
Hi John,
Yea it worked that way for me too. glad to see its consistant.
Regards
Charlie M.
Hide Signatures
       Post #: 1414
RE: New CDI - opensource project JMJ and Bigboat - 7/14/2011 7:36 PM
nyemi
Score: 210
Status: offline
Hi gr8flyer55
I'm curious look forward to.
Others.
Does anybody have an extreme curve of ignition.
I'll help.
Regards nyemi.
Hide Signatures
       Post #: 1415
RE: New CDI - opensource project JMJ and Bigboat - 7/17/2011 12:38 AM
bluejets
Score: 205
Last Login: 4/15/2013
Status: offline
Just posted this in another section and thought it might be of interest to you here.
http://www.rcuniverse.com/forum/m_9842658/mpage_22/key_/tm.htm
CDI capacitor charge chip and transformer.
Hide Signatures
(in reply to nyemi)
       Post #: 1416
RE: New CDI - opensource project JMJ and Bigboat - 7/27/2011 2:54 AM
gr8flyer55
Score: 600
Status: offline
Just finished testing new timer boards and new software. Everything is now working perfectly.
No frills, no bells & whistles, just great performance.
John
Hide Signatures
(in reply to bluejets)
       Post #: 1417
RE: New CDI - opensource project JMJ and Bigboat - 7/27/2011 6:42 AM
Fly42
Score: 105
Last Login: 10/7/2012
Status: offline
Why not show the schematic ?
Hide Signatures
       Post #: 1418
RE: New CDI - opensource project JMJ and Bigboat - 7/27/2011 10:35 AM
bluejets
Score: 205
Status: offline
Terrific work John.
Good to see you stuck to it and have good results. I can remember a few times when you were just about ready to chuck everything in the bin......can get frustrating at times I know. I had to get a few parts from Farnells the other day, so I looked up their spec sheets and had them send up a few of the ferrite cores you mentioned, 13mm ones. I will be overseas for the next 3 months so no "shed" work for me but I will keep a lookout for proceedings.
Once again, great achievement.......... Jeff
Hide Signatures
       Post #: 1419
RE: New CDI - opensource project JMJ and Bigboat - 7/27/2011 12:54 PM
dinoslmn
Score: 100
Last Login: 6/2/2013
Status: offline
Boys can you post a picture, sckech or any other visual think ?
Dino,
Israel
Hide Signatures
       Post #: 1420
gr8flyer55
Score: 600
Status: offline
There may be a hand drawn schematic shortly. I never figured out the circuit drawing program I downloaded.
John
Hide Signatures
(in reply to Fly42)
       Post #: 1421
RE: New CDI - opensource project JMJ and Bigboat - 7/31/2011 6:24 AM
gr8flyer55
Score: 600
Status: offline
I am adding one feature to the new timer board, a LED timing light triggered from a reverse output pin on the pic chip.
Anyone think this is a worthwhile feature? Added it to the schematic already. If it is not desired, just eliminate the 4 added parts.
John
Hide Signatures
(in reply to dinoslmn)
       Post #: 1422
RE: New CDI - opensource project JMJ and Bigboat - 7/31/2011 6:39 AM
gr8flyer55
Score: 600
Status: offline
Thanks to Blue Jets for the great help with my schematic!
Parts list and schematic will be posted shortly.
John
Hide Signatures
       Post #: 1423
RE: New CDI - opensource project JMJ and Bigboat - 7/31/2011 4:19 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Personal preferences for timing curves can be addressed to Nyemi. He has offered numerous times to accommodate requests.
Another project to be added in the near future is an inline tachometer, which simply plugs into the hall sensor cable with a Y-cable for testing your engines performance figures. If anyone has a tested design to add to this series of projects, let's see if it can be accomplished. I have one in mind to try with a 3 1/2 digit display. Only limit is top rpm readings. A 2 to 3 times per second sampling rate would serve our purposes very well. I am very interested in this add-on to the system.
John
Hide Signatures
       Post #: 1424
RE: New CDI - opensource project JMJ and Bigboat - 7/31/2011 4:41 PM
Fly42
Score: 105
Status: offline
No schematic, no program, need other to make timing curve, maybe better to buy in shop a 25 dollar ready to use cdi
Hide Signatures
       Post #: 1425
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: New CDI - opensource project JMJ and Bigboat
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.015RCU1
