thecheatscalc
GA, USA Status: offline
There are generally one of two problems at play here one check the gears that transition from the autorotationary gear to the belt, if you see plastic buildup under/over one of them by the shaft it's stripped, replace gears and when a new one is purchases CA THE HECK out of the gears! (actually just use a dab at the base of each one) another thing to look for is when you apply tail pitch, does the tail motor slow down? if so it either what has been said above or the belt is slipping, to fix that, just loosen the back 6 screws in the frame and pull tail boom. problem solved! (if problem is not solved continue your troubleshooting to page two) pg 2 your gyro is probably in reverse correcting the WRONG way. to check, remove gyro, hook servo to the slot where the gyro was, if spinning persists add more pitch/remove pitch from/to tail blades. If problem is solved and the heli is controllable again put gyro back on and flip the "reverse" switch. Problem solved PS: yes, I have had both happen to me
_____________________________
www.ushobbysupply.com - your #4 HQ! All stock located in the U-S of A!
