Chophop
KY, USA Status: offline
The G007 has a travel adjustment. It is worth trying to save a servo. If on the ground in AVCS and you bump the heli as little as 1/2 inch or less, the servo will creep to it's limit and buzz and grind. The travel limit will prevent this. The G007 is about 1/3 the cost of the GY401, but the 401 also seems to have a rate adjustment so you can set how fast the tail will swing. My G006 is stuck on very slow. If I bypass it by plugging the tail servo into the receiver, my tail can really whip around, almost as fast as the Three Dee model in FMS. I did some work with it and figured out that my receiver was powering up in the failsafe settings then switching to the stick signals while the gyro was initializing. That probably threw the gyro's init routine off. Now when I set it on the floor, turn it on, then turn the tail, the tail slider moves to counter the move, and when I move the tail back, the slider goes back almost where it was, and the opposite movement of the slider happens when I turn it the other way, again with the slider returning when I get back to the same spot. But if I move it randomly back and forth, it sort of just goes to one limit (ggggggrrrrrrr) and stays there. Don't look good to me. SB
< Message edited by stableblade -- 11/21/2006 12:02:57 AM >
_____________________________
Uhil be bok.
