Need CG confirmation on Yak 85"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> Need CG confirmation on Yak 85"
Page: [1] 2 3   next >   >>
Login
Need CG confirmation on Yak 85" - 6/4/2006 6:59:27 PM
bart-rennes
Status: offline
Hello,
I'm from europe and have a problem to understand well the QQ documentation on CG.
So, do you take the CG (7 5/8" = 19,36cm) from the end of the wing or from start of the wing, like in the picture show below (orange or green ?).
thank you.
Click to see fullsize image.
Click for fullsize
< Message edited by Rezagh -- 10/23/2006 5:23:39 PM >
       Post #: 1
RE: Need CG confirmation - 6/4/2006 7:05:24 PM
Rezagh
Status: offline
Hi There,
Download the new manual at http://www.qqaircraft.com/downloads/manuals/85yakmanual.pdf
Look at page 43.
It's from trainling edge. Basically your green line but from the trailing edge(at Wing Tip). Look at the pic in the manual.
Thank you,
Reza
< Message edited by Rezagh -- 6/6/2006 3:24:30 PM >
_____________________________
Quique's Aircraft Company
(in reply to bart-rennes)
       Post #: 2
RE: Need CG confirmation - 6/6/2006 10:38:49 AM
bart-rennes
Status: offline
Found the solution, thank you resa.
(in reply to Rezagh)
       Post #: 3
RE: Need CG confirmation - 6/6/2006 10:59:37 AM
BaldEagel
Status: offline
WARNING
The C of G on the 85" is measured at the wing tip not the root its taken from the TE of the aileron forward to the LE of the wing, but at the TIP of the wing.
Mike
No matter what anyone says 100% is the maximum you can get.
       Post #: 4
RE: Need CG confirmation - 6/6/2006 3:18:10 PM
Rezagh
Status: offline
Mike,
Page 43 clearly shows where the CG is measured from. Thank you for your conern.
Reza
(in reply to BaldEagel)
       Post #: 5
RE: Need CG confirmation - 6/6/2006 5:22:38 PM
BaldEagel
Status: offline
Rezagh
Barts pic shows he is measuring from the Root not the tip, I do not think the pic in the manual or the words of explanation are clear and obviously Bart thought the same.
Mike
       Post #: 6
RE: Need CG confirmation - 6/7/2006 8:24:52 AM
bart-rennes
Status: offline
I found the CG, but my problem is that it is centered at the back. Very hard to center it correctly, my motor is a ZDZ50 NG, and the motor weight is more heavy than a DA50 !! I set all batteries just behind the motor...
Normally with a DA50, is it well centered by default ?
       Post #: 7
RE: Need CG confirmation - 6/7/2006 8:30:51 AM
BaldEagel
Status: offline
Bart
Most guys with a 3lb or under motor have not had a problem with the C of G location, all the batteries are normally on the motor box, you may need to move your batteries rearwards to compensate for your heavier engine.
Mike
       Post #: 8
RE: Need CG confirmation - 6/7/2006 8:47:55 AM
bart-rennes
Status: offline
The problem is that it is not enough heavier on the motor !
       Post #: 9
RE: Need CG confirmation - 6/7/2006 9:20:29 AM
BaldEagel
Status: offline
Bart
If I understand you correctly, you are saying your battery is not heavy enough to compensate for the weight of the motor, if that is the case I can only suggest you buy two larger capacity batteries, what have you got at the moment?
Mike
       Post #: 10
RE: Need CG confirmation - 6/7/2006 3:24:28 PM
Rezagh
Status: offline
Bart,
It depends on howmuch your motor sticks out. What size stand off are you using? What's the clearance between back of your prop or spinner plate to the cowl? I'm guessing you might have the motor too close to cowl.
If you can email me more detailed info and I will be more than happy to walk you through it. Some pics also would help.
Thank you,
Reza
       Post #: 11
RE: Need CG confirmation - 6/7/2006 3:30:54 PM
bart-rennes
Status: offline
Thank you, i will post tomorrow when i will get my new muffler which is a little bit more heavy than the one i have now.
       Post #: 12
RE: Need CG confirmation - 6/9/2006 12:51:40 PM
bart-rennes
Status: offline
So i received my new muffle today and test the CG, i put all batteries and all weight i can in the motor box but i need more weight: 0.77 lb at least.
Here a photo of the motor installation with all batteries (not fixed yet).
Thank you for your support.
Click for fullsize
       Post #: 13
RE: Need CG confirmation - 6/9/2006 1:21:31 PM
exeter_acres
Status: online
are you measureing the CG without the prop, prop bolts and spinner?? they will make a big difference
Extreme Flight RC tech support
"Some are born great, some achieve greatness, and some hire PR officers."
       Post #: 14
RE: Need CG confirmation - 6/9/2006 1:35:11 PM
bart-rennes
Status: offline
i'm measuring the CG with everything (prop, bolts, spinner,...) the picture is for resa to see motor installation.
(in reply to exeter_acres)
       Post #: 15
RE: Need CG confirmation - 6/9/2006 1:59:23 PM
jdavera
Status: offline
Hi Bart,
I had the same problem than you and I use the idea on the picture below and work for me. The picture is from a extreme flight Yak, but I did it in my Yak 85 QQ, no photo yet.
Click for fullsize
       Post #: 16
RE: Need CG confirmation - 6/9/2006 5:06:31 PM
BaldEagel
Status: offline
Bart
make sure your prop driver is approximatly 165mm in front of the engine mounting bulkhead, this will give you the required 37mm clearance between the prop and cowl, I no its a big clearance but it seems its required for prop airflow efficiency.
Mike
