Substitute for Castor that widely available
Tower Hobbies
Logged in as Guest
  Printable Version
Used Quadra 35 with Spring Starter and Muffler - RTF
Seller:  gdeezer
Details:   $140.00   |  10/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Substitute for Castor that widely available
Page: [1]
Login
Substitute for Castor that widely available - 6/5/2006 1:48:17 PM
whiskey29
Status: offline
Methanol and castor is easy to find in my country.
But I want to run my engine on Synthetic, I hate the gum in castor.
But there is no Synthetic OIL that made special for R/C available here.
Is there any other OIL probably any brand that can be used and mix well with Methanol ?
Probably something for motorcycle or other common engine ?
       Post #: 1
RE: Substitute for Castor that widely available - 6/5/2006 5:26:59 PM
hpi apollo
Status: offline
Klotz KL-200 Techniplate all synthetic, if you have had alot of gumming up problems, then you prolly havent used a good quality castor oil
_____________________________
95% of statistics are made up on the spot
(in reply to whiskey29)
       Post #: 2
RE: Substitute for Castor that widely available - 6/5/2006 6:16:37 PM
Sport_Pilot
Status: offline
People confuse gum with the varnish left after oil sits up. The gum in castor is greenish and is residue from the seed hulls.
“I Saw Elvis at 1000 Feet” John Force
(in reply to hpi apollo)
       Post #: 3
RE: Substitute for Castor that widely available - 6/5/2006 11:22:38 PM
hpi apollo
Status: offline
the varnish is really a bad thing either, ask fuelman, he has told me that its a protective layer that coats the parts, so if you ahve a lean run, its a bit more forgiving
(in reply to Sport_Pilot)
       Post #: 4
RE: Substitute for Castor that widely available - 6/6/2006 6:01:44 AM
downunder
Status: offline
All castor is degummed during the manufacturing process so it's impossible to get ungummed castor. The green colour actually comes from any brass that's been in contact with castor for a long time...years usually. I've found it on brass fuel tubing in very old tanks. Over very long periods, like in an engine that's been stored, the castor slowly oxidises and gets thicker until it's almost solid but it's then a very good preservative. As Sport_Pilot said, the brown on the sides of pistons isn't gum, it's a lubricant. Castor is the only oil (animal, vegetable, mineral or synthetic) that has this property and it continually forms different lubricants up to about 850F when it calls it quits and decides to burn. Synthetics last until about 450F then flash into vapour when they fall to pieces and then burn.
If you can't find the usual synthetics like Klotz then look around for jet turbine oils. Not all will mix with methanol though.
       Post #: 5
RE: Substitute for Castor that widely available - 6/6/2006 3:49:18 PM
whiskey29
Status: offline
Thanks, What I meant was the brown residue left if you store the engine and makes everything sticky. Although easy to clean, it's better if I have to forget cleaning at all.
I use regular nitroed fuel for aerobatic flying. The self-mixed fuel is for trainer, for new people in the hobby, since getting premixed fuel for R/C is quite expensive here.
The cost of self mixed fuel is about 1/3 to 1/4 of fuel with nitro.
The castor that I bought from chemical store is qualified to use for medicine.
Yep green color is the brass mixed with castor after a while, or if it sits too long.
Jet fuel oil ? Hmmm that would be harder to find...
Any other idea may be ?
THanks
(in reply to downunder)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
