1.20L
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> 1.20L
Page: [1]
Login
1.20L - 6/5/2006 2:39:58 PM
Hobbsy
Status: offline
Bob, I'm going to buy a 1.20L in a couple of days with a thought toward Dieselizing it, don't laugh too hard. I would like to know the bore and stroke. Also would one of your carbs with a smaller venturi fit the 1.20L. I have about 15 Diesel conversion have never damaged an engine yet. Thanks, Dave
_____________________________
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
       Post #: 1
RE: 1.20L - 6/5/2006 3:46:07 PM
bob27s
Status: offline
Hi Dave....
Thanks for writing.
email Dub directly at jettengr@sbcglobal.net for bore/stroke information.
As for a diesel, I'm not too sure I'd proceed with that without doing some detailed checking.
This engine is very unique.
It is AAC, ceramic coated pistion, very special fit-up that is not "as" heat dependant as some ABC/AAC engines.
Also, be advised, there are some very small o-rings used on the idle needle and the carb draw-bar - you would have to ensure that those were replaced with a diesel/petrolium compatible material.
The smaller .46/.50 size carbs will fit. The carb bodies are all the same size. The 1.20 uses a 9mm carb if I recall correctly. Dub can confirm that. You can order the engine per your requirements. The only issue may be, that Dub always test-runs every engine, and has performance marks he uses for evaluation. So obviously something of a special order will perform differently.
Anyway, drop Dub a line directly, request the info, and perhaps he can give you some direct information on the diesel capabilities.
Bob
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to Hobbsy)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.563RCU1
