Blade CP: "Unfolding" Blades After Removing from Box
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Blade CP: "Unfolding" Blades After Removing from Box
Page: [1]
Login
Blade CP: "Unfolding" Blades After Removing f... - 6/6/2006 3:35:13 AM
NitroEddie
Status: offline
Hello all, just bought a CP and have a (stupid) question. After removing the heli form the box how does one know if the blades are perfectly in line with each other after you unfold (for lack of a better word) the blades?
I know this must seem like a silly question, so please go easy on this nitro monster truck guy.
       Post #: 1
RE: Blade CP: "Unfolding" Blades After Remov... - 6/6/2006 4:00:27 AM
nanner117
Status: offline
it doesn't really matter because as long as the blades are snug and not to tight centrifugal force will straighten them when the rotor head spins up
(in reply to NitroEddie)
       Post #: 2
RE: Blade CP: "Unfolding" Blades After Remov... - 6/6/2006 7:49:20 AM
AJ DRAGON
Status: offline
Hi
If I am not mistaken you grab the corners on the leading edge of both of the blades and then pull strait out. Then you tighten them down.
(in reply to nanner117)
       Post #: 3
RE: Blade CP: "Unfolding" Blades After Remov... - 6/6/2006 4:40:21 PM
duaneh1
Status: offline
You don't want the blades too tight, or it will be hard for them to track properly
(in reply to AJ DRAGON)
       Post #: 4
RE: Blade CP: "Unfolding" Blades After Remov... - 6/6/2006 4:58:23 PM
Zelatio
Status: offline
No, deffinently do not tighten them. Only tighten them if they are extremely loose. They were designed to be collapsing blades. They need that fre movement. Tightening them would be bad for it.
_____________________________
E-Flite Blade CP - E-Flite Blade CX - ThunderCat 31
(in reply to duaneh1)
       Post #: 5
RE: Blade CP: "Unfolding" Blades After Remov... - 6/6/2006 6:18:24 PM
NitroEddie
Status: offline
Thanks, guys. I had originally thought to leave them on the loose (but not too loose) side and let centrifugal force take it's course but wanted to be sure. I got her up and running and hovering without training gear (albeit with sweaty hands).
(in reply to Zelatio)
       Post #: 6
RE: Blade CP: "Unfolding" Blades After Remov... - 6/7/2006 12:35:02 AM
GaryH-Eugene
Status: offline
What I read was to hold the heli with the nose pointing straight up, the blades parallel to the ground and gently pull the heli downward - the blades are tight enough if they barely move when you stop. Does this make sense? Whoever posted it originally said it better than what I did, but it seems to work for me.
G
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.468RCU5
