Glacier Girl
PA, USA Status: offline
Hang on, just got an e-mail from Hong Kong. Apparently all the new 30 amp esc's were shipped out without initial programming installed at the factory. Here's the revision from them if someone else runs into the problem. I'll try it tonight and see if it works. Brushless ESC User Guide(10A/15A/30A) Extreme Usage: 10A :max 10A 13A Burst 10 senconds 15A: max 15A 25A Burst 10 seconds 30A: max 30A 40A Burst 10 seconds Unit Size/Weight: 10A: 23mm*17mm*5mm 4g (without wires) 8g ( with wires) 15A: 32mm*24mm*7mm 11g (without wires) 21g (with wires) 30A: 32mm*24mm*7mm 11g (without wires) 23g (with wires) Voltage Scope: 4V-15V Battery: 4-10 NIMH 2-3 LIPO BEC Output: 10A—1.5A (instant 2A): 2 LIPO 4 mini servo actuator 3 LIPO 3 servo actuator 20A—2A (instant 3A): 2LIPO 4-5servo actuator 3 LIPO 3-4 servo actuator 30A-2A ( instant 3A): 2LIPO 4-5 servo actuator 3LIPO 3-4 servo actuator Protection Function: Auto choice 2-3 LIPO individual protection valtage: 6V/9V Auto choice NIMH, each cell protection valtage is 0.8V Safe start, wrong throttle position will forbid start. Temperature protection, a surface temperature of 110 degree will stop down. Non-control protection, stop down when without signal for 1 second. Character Description: Max-rotation, 2 poles inner rotation up to 300000 RPM. 12 poles outer rotation up to 50000 RPM. 14 poles outer rotation up to 42000 RPM . 8K PWM control, with rotation speed control curve. Fit for auto throttle and more remote Control equipments. 20A/30A with BEC and MCU power supply, the work is more security. Setup: -First, connect the motor and receiver to the speed controller -Remove battery power from the speed controller. -Turn on the transmitter. -Move throttle stick on full power position,(UP Position) -Reconnect battery power to the speed controller After 2sec you can hear BEEP showing LIPO auto-protection BEEP BEEP showing NIMH/NICD auto-protection BEEP BEEP BEEP showing select of brake BEEP BEEP BEEP BEEP showing re-setting of factory parameters. All sounding will continue, unless operation instruction. If the option is you need ,then move the throttle stick to lowest position. The engine will give a BEEP sound for approval. Then, if need other setting, put the throttle to the top quickly, and you will do the next choice. After all of your settings are ok, then waiting for 2 seconds, the engine will give out suitable approval sound of battery protection, and approve the throttle position. Then you may start. Factory parameters resetting function: When the characters such as the elec-adjuster acceleraton or diversion or throttle curve, etc are changed from the new product, a factory parameters setting can be made to get the best characters.
_____________________________
"The Missing Man Formation" Looking heavenward you cannot help but shed a tear...mornful...lonesome...a hole that screams out almost as loudly as the roar of the engines that pass over head.
