RE: New QQ-Yak 86"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> RE: New QQ-Yak 86"
Page: <<   < prev  1 2 [3]
Login
RE: New QQ-Yak 86" - 8/30/2006 11:33:13 PM
AirTech
Status: offline
I'm sold. When will you all be taking pre-order deposits?
(in reply to Rezagh)
       Post #: 51
RE: New QQ-Yak 86" - 8/30/2006 11:44:09 PM
Rezagh
Status: offline
No pre-orders just yet but I will annouce it when they are on the ship Thank you for your support.
Reza
_____________________________
Quique's Aircraft Company
(in reply to AirTech)
       Post #: 52
RE: New QQ-Yak 86" - 8/31/2006 9:02:48 AM
damnedfastklaus
Status: offline
Hi,
is it correct, that the old 85´´ has a fix stab and the new 86´´ has a removeable one ??
Bye Klaus
greetings from germany
       Post #: 53
RE: New QQ-Yak 86" - 8/31/2006 6:01:28 PM
Rezagh
Status: offline
Hi There,
Welcome to our support forum. Yes, the 86" has removeable stab so it will be easier to transport.
Thank you,
Reza
(in reply to damnedfastklaus)
       Post #: 54
RE: New QQ-Yak 86" - 9/1/2006 12:37:21 AM
Bob Pastorello
Status: offline
Quit TALKING about it, and DELIVER IT!!!!!!!!!!!!!!!!!!!!
Bob Pastorello www.rcaerobats.net
       Post #: 55
RE: New QQ-Yak 86" - 9/4/2006 5:42:31 PM
out152
Status: offline
how about a 40cc or 45cc motor?
(in reply to Bob Pastorello)
       Post #: 56
RE: New QQ-Yak 86" - 9/10/2006 8:49:49 PM
Rockyaged
Status: offline
Rezagh...
Great job and response timing to our questions and statements.. they must have
you tied to the computer... )
In your initial post of this thread, you mentioned "around" 20 modifications, and I'm
sure that those you mentioned were considered major modifications. I am curious
about the rest of the mods. If you could provide some generalization as to the remaining
mods, I am sure there would be others as appreciative as I for your input in that area.
I am in the process of comparing 50 CC models for purchase, and this new Yak compares
very well with the rest.
Gerald
       Post #: 57
RE: New QQ-Yak 86" - 9/21/2006 2:38:53 PM
wings19
Status: offline
Ok its been 11 days since the last post here, any dates yet? lol
I'm getting a new yak for sure, its driving me nuts trying to decide... I think this one is going to win! One thing that held me back from the 85 is that it seemed to take a lot of work to get it into the air so its nice to know this will be easier to build! Will this one use robart pin hinges? One thing I really like about a lot of models out there is that they use robart hinges and they have the holes pre drilled!
< Message edited by wings19 -- 9/21/2006 3:02:52 PM >
-Nick
(in reply to Rockyaged)
       Post #: 58
RE: New QQ-Yak 86" - 9/21/2006 3:32:28 PM
Rezagh
Status: offline
Hi There,
Holes are cut out for you. It will use flat (klitz) hinges. The 85" wasn't that hard to build. The only things that need to be done by builder was the tank tray and throttle servo tray, everything else was fit and glue. Anyhow, this one will be even easier to build. We are hoping by the end of this year. Any changes, I will let you know.
Thank you,
Reza Gh.
(in reply to wings19)
       Post #: 59
RE: New QQ-Yak 86" - 9/21/2006 4:13:36 PM
BaldEagel
Status: offline
Rezagh
What size cannister will the 86" be capable of using?
Mike
No matter what anyone says 100% is the maximum you can get.
       Post #: 60
RE: New QQ-Yak 86" - 9/21/2006 4:16:18 PM
Rezagh
Status: offline
How you doing Mike,
MTW 75 with double bent 1" drop full size header. No cutting.
Thank you,
Reza
(in reply to BaldEagel)
       Post #: 61
RE: New QQ-Yak 86" - 9/21/2006 5:04:43 PM
BaldEagel
Status: offline
Rezagh
I am doing OK, with the interest being shewn in the new 86" I am supprised its not out already you should have good sales on this one.
Thanks for the info
Mike
       Post #: 62
RE: New QQ-Yak 86" - 9/21/2006 5:07:37 PM
BaldEagel
Status: offline
Rezagh
Sorry to come back straight away but is that the MTW TD75 @ 355mm long or the TD75K @ 275mm long?
Mike
       Post #: 63
RE: New QQ-Yak 86" - 9/21/2006 5:23:32 PM
wings19
Status: offline
What is the length on this new yak?
-Nick
       Post #: 64
RE: New QQ-Yak 86" - 9/21/2006 5:45:35 PM
Rezagh
Status: offline
Mike.
I think it is the TD75 not the K!
wings19,
I don't have the dimension info yet. It is very close to the 85".
Thank you,
Reza
       Post #: 65
RE: New QQ-Yak 86" - 9/21/2006 6:01:02 PM
BaldEagel
Status: offline
Rezagh
The other difference between the two is The TD is 55mm dia and the K is 70mm dia this would make a difference to the width of the chamber if it has closed side's. Is it a closed compartment or open to the atmosphere? does it have a width restriction? sorry to ask all this but my 85" Yak with a BCM wrap around is so noisy its got to go, even though its flys like no other.
Mike
       Post #: 66
RE: New QQ-Yak 86" - 9/21/2006 6:06:33 PM
Rezagh
Status: offline
I think it is closed chamber with high temp clear plastic that makes the can visible towards the bottom (I don't know if production would be like that yet). It is the 55mm dia. not 70mm. I think the 70mm would be little big to fit there.
       Post #: 67
RE: New QQ-Yak 86" - 9/21/2006 6:13:26 PM
BaldEagel
