kamirdawg -> RE: CARL GOLDBERG 77" EDGE 540 (4/22/2008 3:26:43 AM)
Hi jrotor. Well, on my Extra 330, I used JR sport ST126MGs @6volts they put out 142oz/in of torque. I put them in at the aileron, and elevator position. They run around $33.00 apiece. I used the Hobbico CS-150 in the pull/pull rudder position. That is a strong enough servo for this plane, at 193oz/in @6 volts, runs around $40.00. It works well enough for sport flying, and some basic aerobatics. [:)] Now if I was to re-tool this plane, or start over with a new one, like the Edge, or Yak 54 in this size range, I would probably go with the Hitec HS5645MGs. They are 168oz/in @ 6volts, I think they cost about $55.00. I would suggest that these be used in the ailerons and elevators. I'd still use the Hobbico CS150 for the rudder. Ok, now with that said, you'll note that there are 2 servo pockets in each wing. You only need to use the inner 2. You may want to use the outter 2, and add the extra servos in the future, but for easy, fun/sport style flying, 2 is really all you need. [)] If you get feeling real daring, and want to upgrade later, I'd move the HS5645s from the tail, to the outter aileron pockets, and add HS5945MGs, to the elevator position, they put out 181oz/in @6 volts and are $90 apiece. For the pull/pull rudder, I'd move up to the Hitec HS5955TG, 333oz/in @6 volts. This is high dollar, $115.00[X(] (hip tip: Buy the Hobbico CS170, IT'S THE SAME SERVO, for $90)[:D] [X(] I didn't mention that all the Hitec servos listed here, and the Hobbicos are digital. The JR sports are analog. Do your research, and make your decision. But you should definately use a 6 volt system with this plane. That will be the only way to get the torques you need, and go easy on the bank account. Just one thing[sm=71_71.gif] What are you powering this plane with? I'm using the Moki 1.35. It works well, and I've got a Moki 1.80 to add later. These are great engines, if you can get them used, all the better. I highly recommend either for your Edge, if you haven't made a choice yet[:D] Let's hear how it goes for you. Ken [sm=shades_smile.gif]
