RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/17/2006 3:27 AM
GBS Customs
Score: 100
Last Login: 9/24/2006
Status: offline
OK here is the link to the video. may take 10 minutes for there site to optimize it.
Updated link with better quality vid.
Sunday Driver. ( Vegas and hammer run)
< Message edited by GBS Customs -- 7/17/2006 4:48 AM >
Hide Signatures
(in reply to GBS Customs)
       Post #: 226
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/17/2006 3:56 AM
TwistedLiquid
Score: 100
Last Login: 8/30/2006
Status: offline
Welcome coastie to the Vegas forum....If someone has a Vegas for sale...I am sure they will let you know, but you can look on the web....but good luck we love Vegas boats....
Ok I believe this has been cover, but here is what with did with the Vegas Tank...Screw on lid would be nice but hey...everything is fixable...
You need:
1/2 inch long small bolt and nut
Rubberband
The lid on the Vegas is all good ...till it looses the oil from filling the tank...on the O ring in lid. As fuel is burned the oil leaves the oil ring in lid..and you got leak. So here is a simple cure to stop it from leaking air.
1.)On the tank lid there is a small hole like a tab in the front the lid. Get your 1/2 inch long bolt and nut "size that will fit thru hole in lid. Stick the bolt from under neath so the bolt is sticking up thru the lid now..place the nut on the bolt and tighten.
2.)Now release the the front gas tank screw...so you can barely lift it...
3.)Double over your rubber band so it is two layers thick.
4.)Place the rubberband under the front gas tank screw down tab.
5.)When you replace the screw, you should have the rubber band just sitting there waiting the be hook on the lid.
6.Pull the rubberband up and slip it over the bolt you just installed.
7.) We put a little plastic nub of hose over the bolt head to help the rubberband to last longer..the bolt threads do wonder to a rubber band at high speed...so wrap it..also make sure your rubber band under the tank is not hung up on wood block...it will slip between the block and tank..making it last longer.
7.Your done...you got a tight lid.
Now you have two fittings in your tank.
One is pressure....One is fuel
Pressure comes thru the lid
Fuel comes out top rear of tank.
These fittings unscrew and can be removed
Be CAREFUL!!!! not to slip when removing..there plastic
We use regular white thread tape and replace the fitting..never leaked again, and the tape is not harmed by Nitro fuel. Remember to wrap the tape backwards to avoid when replacing the tape unwhinding from fitting...
you can check your tank for leaks by replacing all the fitting with tape and rubberbanding the lid. Just remove the pressure line from the muffler. blow thru it with your thumb over the carb intake...you should have no leaks..if so you will hear it...dont blow hard..no need...the pressure from the pipe is minor, but very important...
Happy Boating..
Click to see fullsize image.
Click for fullsize
< Message edited by TwistedLiquid -- 7/23/2006 3:41 PM >
_____________________________
James
TWISTED LIQUID RACING
Hide Signatures
(in reply to coastie-03)
       Post #: 227
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/18/2006 10:19 PM
dirtysouth31
Score: 100
Last Login: 11/9/2008
Status: offline
since this vegas is so new and i cant seem to find the parts i need(tower) where can i get drive dogs and prop nuts from.i tried tower no luck (late july) DOESNT HELP WHEN YOUR WHOLE DRIVESHAFT AND PROP AND WELL YOU GET THE PICTURE IS AT THE BOTTOM OF THE POND.fine design wont answer or return calls where else do they sell these items.i have had nothing but problems with my 300 dollar boat.tanks leaks,coupler let loose and damn rudder wont stay on straight,it wants to run to the right or left whatever she feels like doing.its the pin holding rudder on thats not right!!!!!cannot get to line up.i can not a have a race and try to adjust the trim to track her straight and drive at the same time.thats like talking on the phone and driving at the same time..the only person that i can get an honest answer from in here is james.
uh yeah..what was i saying???
Hide Signatures
(in reply to TwistedLiquid)
       Post #: 228
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/18/2006 11:13 PM
brownvhf
Score: 100
Last Login: 3/31/2009
Status: offline
Try www.offshoreelectrics.com as they probably will have what you need and are good people. Not sure on the spelling but its close. Jerry
[Repaired link]
< Message edited by Ron Olson -- 7/19/2006 5:25 AM >
Hide Signatures
(in reply to dirtysouth31)
       Post #: 229
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/18/2006 11:41 PM
TwistedLiquid
Score: 100
Status: offline
Hello Dirty...the reason we and answer and others dont is because most of them are out racing and attending events. This happens in the R/C boat business. When they are on they catch up and answer. We are here on a regular basis. Now with your Vegas , dont get discouraged...theres hope...here is a few tips for those who are new to the R/C Powerboat hobby.
1.) You are new to this hobby and with anything new you have to learn. With the Vegas it is a 300.00 boat correct. If you want a bad boat with nothing to upgrade...There are thousands of them here and on the net...BUT!!! They are NOT!!! 300.00
In general a (RTR) is ready to run, but not like you want...this is what makes it fun...A combination of learning tips and gaining skills. What would there be if you were a super racer and had the best boat right out of the gate, no one could beat you on the planet??? ...YOU WOULD BE BORED!!!
2.) The Vegas is a superior design by AquaCraft and Jerry Dunlap, althought we are proud of our own stuff for the Vegas ...The Vegas for $300.00 is a steal...And a wonderful model to start on in the R/C world.
3.) I have been inform that if your boat has a defect that cause you to be unhappy...Please contact the customer service dept at AquaCraft. The only way that AquaCraft can make your boat better is to know your issues. Without this the boat will never change. people like Jerry refers back to AquaCraft what he see here, but he is one person. Live by the term the squeaky wheel gets the oil. So instead of showing anger in the boat, Ask AquaCraft to help fix your anger...They are very helpful and have replaced a Miss Vegas for us in four days...
4.) Last but not least...give people time to answer you here. We all want to help you enjoy your Vegas . In my case I am here often, but its because we are in our production shop with the internet...we check...alot. But like in Grim Racers case he races and attend events around the U.S. So internet is impossible for him and Jerry, but when they get a chance...they are here. i want to qoute a comment Jerry Dunlap said to me on the phone last week "James, the biggest thing a designer wants to see...is people liking his product..." So post your problems and let someone answer you...
Do like we do...have fun making them the best Vegas out there...
Tower has the drive shaft you need here Vegas Drive Shaft.
or we do
vegas .html"> Vegas Drive Shaft
I think its funny though...Jerry's reason for not being here is....he drives a Zamboni ice machine at rec center....I WONDER IF HE AUTOMATICALY GOES AROUND THE FLOOR RIGHT? AND HOW FAST?
James
Hide Signatures
       Post #: 230
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 12:36 AM
Jerry Dunlap
Score: 100
Last Login: 3/19/2010
Status: offline
The Zamboni makes turns to the right and blasts around the rink at a blinding 7 mph .
It is extremely important to really tighten down on the flex coupler that come with the Miss Vegas . What seems sufficiently tight just might not be sufficient to hold onto the flex cable.
JD
Hide Signatures
       Post #: 231
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 12:42 AM
SigMan
Score: 100
Last Login: 3/17/2010
Status: offline
CANT WAIT TO GET MINE. IT WILL BE MY FIRST BOAT....WOOHOO! I LIVE CLOSE TO EVANSVILLE INDIANA AND THEY HAVE A BIG BOAT RACE THERE EVERY YEAR, MAYBE I'LL BE READY BY NEXT SUMMER...WISH ME LUCK!
Club Saito Member #1
AMA# 542304
Hide Signatures
(in reply to Ron Olson)
       Post #: 232
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 2:06 AM
TwistedLiquid
Score: 100
Status: offline
Hey you can get you a used Vegas from Tower if you join as a member I think....Jerry may know the link. it allows you to buy a Vegas that has been refit and ready to go run....
James
Hide Signatures
(in reply to SigMan)
       Post #: 233
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 2:09 AM
TwistedLiquid
Score: 100
Status: offline
Well Jerry the Ice machine not near as fast as your Vegas
James
Hide Signatures
(in reply to Jerry Dunlap)
       Post #: 234
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 5:16 AM
Jerry Dunlap
Score: 100
Status: offline
The Tower Hobbies Super Savers Club is a good investment. You get free shipping on any order over $150, plus some of the Scratch and Dent boats are only available to Super Saver members. Last month I bought a new Miss Vegas for a friend through Super Savers and Tower Discounting and paid $240 and no shipping.
I haven't seen any Miss Vegas hulls yet on Scratch and Dent. But, I'm sure there will be. You need to check on a regular basis because the boats could only be listed a short time if someone buys them quickly.
JD
Hide Signatures
       Post #: 235
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 1:17 PM
t munn
Score: 100
Last Login: 1/24/2010
Status: offline
Be VERY careful with the purchase of a scratch and dent boat from tower.I bought a ts2 and a miss vegas with "carton damage only".
The ts2 was an easy fix and tower cutomer service looked after me.
The vegas was severly damaged and after several e-mails and pictures I was very fairly dealt with but it is my last boat purchase from scratch and dent.
They were only marked down a small bit so,It's not really worth it when you Can get a new vegas as a club member for $240.00
Over all and up until the miss vegas color isues and damaged boats i must say towers is a decent place to purchase from.
Terry
Hide Signatures
       Post #: 236
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 10:57 PM
piper_chuck
Score: 100
Last Login: 10/7/2009
Status: offline
quote:
ORIGINAL: Jerry Dunlap
There a couple RTR Miss Vegas a few weeks ago, listed as "box damage". They actually stayed there a couple days before they got gone. I posted a heads up in one of these threads. Didn't hear whether an RCU member got one or not.
AMA 87959, IMPBA 19650 CD, IBDBG #2, local 12
There's A Reason I'm Behind You. You're About To Be Lapped!!!
Hide Signatures
       Post #: 237
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 11:29 PM
xstream70
Score: 100
Last Login: 9/12/2006
Status: offline
Here is pics of the start of my new paint job..............sorry my cam sucks
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to piper_chuck)
       Post #: 238
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 11:30 PM
xstream70
Score: 100
Status: offline
and some vids of it before new paint.
Hide Signatures
(in reply to xstream70)
       Post #: 239
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 11:46 PM
Jerry Dunlap
Score: 100
Status: offline
That's one way to change the orange/white scheme to something real eye catching.
I hope others who paint their Miss Vegas boats will post photos like yours and a couple of previous posts.
JD
Hide Signatures
       Post #: 240
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 11:47 PM
xstream70
Score: 100
Status: offline
oops I guess I can not post vids,.........sorry
Hide Signatures
       Post #: 241
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/19/2006 11:48 PM
xstream70
Score: 100
Status: offline
Thanks Jerry
Hide Signatures
       Post #: 242
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2006 12:49 AM
GBS Customs
Score: 100
Status: offline
here are pics of mine
vegas /">GBS Racing Miss Vegas
and pics of a bad day at the pond.
A Bad Day at the pond.
will be placing an order with twisted soon for the whole package. should i get the 2 or 3 blade prop?
Hide Signatures
       Post #: 243
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2006 1:02 AM
SigMan
Score: 100
Status: offline
r these boats easy enough for new boaters, thinking of getting one for my wife also?
AMA# 542304
Hide Signatures
       Post #: 244
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2006 1:08 AM
xstream70
Score: 100
Status: offline
some more.....................
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 245
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2006 1:33 AM
xstream70
Score: 100
Status: offline
I would say they are pretty easy and fun ............have you ever had any kind of nitro rc sigman?
< Message edited by xstream70 -- 7/20/2006 1:34 AM >
Hide Signatures
       Post #: 246
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2006 2:35 AM
TwistedLiquid
Score: 100
Status: offline
WoW!!!!!!!!
Super job on the paint work...and the "Bad Day At The Lake" I call that a good day....your rudder on the Vegas could be gone...
Is the Vegas good for a newbee...well sure....its like any other boat, you have to learn it....The best thing about a Vegas is....No two are alike...I know the Vegas is gaining speed here in Wichita...But just for the record...our Vegas will stay....its color...Orange/White
James
Hide Signatures
       Post #: 247
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2006 2:40 AM
Bruce Frost
Score: 100
Last Login: 12/1/2006
Status: offline
I'll post pictures soon, I just need to find someone to do a cool flame job on it. I went orange and blue for the Fighting Illini.
Bruce Frost
Hide Signatures
       Post #: 248
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2006 2:44 AM
GBS Customs
Score: 100
Status: offline
quote:
ORIGINAL: TwistedLiquid
WoW!!!!!!!!
Twisted what prop do you recommend on your site??? the 2 blade or the 3? My style is basicly this... i like to get out of the hole fast and into the straights. drag basicly. i just want to know what one to get with the whole package deal.
and i'm a new vegas owner and they are AWESOME. just have replacement parts on hand. it's alot cheaper than my EMAXX. never know when that turtle would pop up and take out a prop or a rudder.
Hide Signatures
       Post #: 249
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2006 4:42 AM
toyotatruckin
Score: 100
Last Login: 3/20/2010
Status: online
If im thinking right the 2 blade, but run it by james first as he has tested them more! Oh man the turn finn we have from h20 for the vegas is mind blowing, and It will be up soon!
http://www.youtube.com/user/toyotatruckin
www.aircapitolhobbies.com
Hide Signatures
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.375RCU1
