RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
Page: <<   < prev  117 118 [119] 120 121 122 123 124 125 126   next >   >>
Login
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make ... - 5/16/2008 3:32:31 AM
Sean Bowf
Status: offline
If they are brand new boats, you should not be going full throttle at all. You need to run about six tanks of fuel through the engines to get them broken in. What I do...is set the HSN at 3 turns out. I run two tanks through it at this setting. After the second tank, I go in an eighth turn and run another tank. I keep doing this until the engine is broken in and running well. If the motor is gettig up on pipe in the first few tanks (normally won't), I back out of the throttle so it is not going full throttle. There is a lot of friction in the first few tanks that won't be there after the engine is broken in. So you need to take it easy on the engine while breaking it in.
After about 4 or 5 tanks you will see it pick up in speed. At about 6 or 7 tanks it should pretty much be broken in and running well. Most of the AQ engines I have got seemed to run well at about 2.25 to 2.50 turns out on the HSN when they are freshly broken in. For some reason, as the engines get wore out, they seem to like richer settings until they finally let go. As a general comment, running the engine a little rich is a lot better than running it lean (it will last a lot longer). So once you find the boats fastest needle setting, you might want to back it out an eighth of a turn to run a little rich.
Just my 2 cents, I am sure if you ask 10 different people how to do it, you will get 10 different answers.
As to props...I got a lot of cavitation from the stock plastic prop...but as I recall, it was mainly just in the turns. Another guy told me that he pushed the prop deep to keep it from cavitating. I run the Octura Y535s on my kids boats at about 3/4 of an inch deep (bottom of the hull to the center of the stuffing tube where it goes into the strut). I used to turn the steering a little back and forth if it cavitated during the launch. Might just be in my head, but it seemed to help the prop grab a little better.
Hope this helps,
Sean
< Message edited by Sean Bowf -- 5/16/2008 3:55:57 AM >
_____________________________
Miss Vegas V2 - .12 outrigger hydro - CMB .45 speedmaster mono - CMB .21 seaducer mono
IMPBA member
(in reply to Dan S)
       Post #: 2951
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make... - 5/16/2008 2:14:38 PM
shawnp2k
Status: offline
Thanks for the input Sean, but i cant even get it on plane long enough to go anywhere, We give it a good toss its starts off on plane then falls off, plows through the water and practically sinks it self. I understand what your saying about not having the full power there, but i cant even get it onto plane and both boats are doing this.
(in reply to Sean Bowf)
       Post #: 2952
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make... - 5/16/2008 2:34:22 PM
Ron Olson
Status: offline
Is anybody besides me still curious of the mods that Russ did to make the Aquacraft .18 faster? Sure, it voided the warranty but some of us don't care!
Come on Russ, time to tell us. I could see where the OS .18 carb could help as it's larger than the Aquacraft.
Member, Southwest Michigan Model Boat Club.
(in reply to shawnp2k)
       Post #: 2953
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make... - 5/16/2008 3:10:09 PM
Jerry Dunlap
Status: offline
quote:
ORIGINAL: shawnp2k
With the stock prop, try running the prop depth at 7/8" below the bottom of the boat.
JD
       Post #: 2954
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make... - 5/16/2008 4:48:46 PM
Jerry Dunlap
Status: offline
quote:
ORIGINAL: Ron Olson
Russ is in China at this time. I installed the O.S. VZM in the boat Russ now has. There were no mods to the hull.
JD
(in reply to Ron Olson)
       Post #: 2955
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Mak... - 5/16/2008 5:04:25 PM
Ron Olson
Status: offline
Jerry, way back towards the start of this thread he mentioned a mod that would void the warranty so he must have done something internally to wake it up a little more. I'm kind of thinking intake timing on the crank or some sleeve work.
Oh well, I guess that we're going to have to wait for him to get back home.
(in reply to Jerry Dunlap)
       Post #: 2956
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Mak... - 5/16/2008 5:33:09 PM
f16man
Status: offline
I think he was talking about removal of the head shim, the transfer ports on these engines are pretty small so I remove some material and conture the port and sleeve for better flow, between that and a exaust port and header alignment we picked up some rpm ,,,,,,=more speed he he
       Post #: 2957
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 5/17/2008 9:28:22 PM
rclover95
Status: offline
what do you guys think of this as a retreival boat?
Click to see fullsize image.
Click for fullsize
(in reply to Russ Williamson)
       Post #: 2958
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 5/18/2008 1:26:29 AM
Dan S
Status: offline
if you remove the front bumper and the net that should work.
Dan.
(in reply to rclover95)
       Post #: 2959
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 5/18/2008 9:53:20 PM
rclover95
Status: offline
hey guys, i didnt want to start a hole new forum for this one gestion so i thought i would just through it in her. can you tell me what kind/style this boat is?
Click for fullsize
< Message edited by rclover95 -- 5/18/2008 9:54:15 PM >
       Post #: 2960
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Mak... - 5/18/2008 11:22:30 PM
Ron Olson
Status: offline
It looks like an Insane hydro, www.insaneboats.com .
       Post #: 2961
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 5/19/2008 2:39:18 AM
Sean Bowf
Status: offline
quote:
ORIGINAL: rclover95
Gas (LS27?) sport hydro.
Sean
IMPBA member
       Post #: 2962
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 5/19/2008 2:58:48 AM
rclover95
Status: offline
quote:
ORIGINAL: Sean Bowf
quote:
ORIGINAL: rclover95
Sean
ron said above(Insane hydro?) and left me a site. the ls27 like you said sean, where can i find that at. i really like this style boat.
       Post #: 2963
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 5/19/2008 3:14:43 AM
rclover95
Status: offline
HOW HARD DO YOU THINK IT WOULD BE TO WORK THE REAR SECTION OF A MV TO GET THAT LOOK?
       Post #: 2964
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 5/19/2008 5:29:47 AM
Sean Bowf
Status: offline
quote:
ORIGINAL: rclover95
I dont know what LS stands for...but best I can figure, it just means 27 CC gas engine or smaller. The site Ron linked sells engines..both stock and modified.
Sean
< Message edited by Sean Bowf -- 5/19/2008 5:54:43 AM >
IMPBA member
