RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! Page: <<   < prev  151 152 153 154 155 [156] 157 158 159 160   next >   >>
Login
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/13/2010 10:48 PM
SilentSeven
Score: 100
Last Login: 3/4/2012
Status: offline
Well stated Amax.  For a pond runner like me, a bit more protection will be a good thing.
_____________________________
Miss Vegas Noob
Bellevue, WA
Hide Signatures
(in reply to amax)
       Post #: 3876
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2010 9:26 AM
SilentSeven
Score: 100
Status: offline
Well, made it out over the weekend to see JD and Beaverboy run some races.  Turns out Beaverboy's social calendar was maxed but did get a chance to chat with JD and watch him grease everyone with slick starting line moves.
Few pics just for grins.
Miss Vegas Noob
Bellevue, WA
Hide Signatures
(in reply to SilentSeven)
       Post #: 3877
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/20/2010 9:29 AM
SilentSeven
Score: 100
Status: offline
And last but not least, my own vegas running on a different lake...
Miss Vegas Noob
Bellevue, WA
Hide Signatures
       Post #: 3878
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/26/2010 8:51 PM
hal93
Score: 100
Last Login: 7/26/2010
Status: offline
look my miss vegas has this problem.  the propellor strut asdsembley has broken lol it sucks . does anyone know where to get a blue aluminum one.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Dan S)
       Post #: 3879
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/26/2010 9:20 PM
toyotatruckin
Score: 100
Last Login: 5/22/2013
Status: offline
looks like your running the drive dog way to close to the strut
http://www.youtube.com/user/toyotatruckin
www.aircapitolhobbies.com
Hide Signatures
(in reply to hal93)
       Post #: 3880
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/26/2010 9:22 PM
Serpents Den
Score: 100
Last Login: 5/15/2013
Status: offline
aye you need to run about 1/8 to 1/4 inch between drivedog and strut...
T-Rex 600N Hughes 500 TOW defender, 450SE Airwolf and 250 NYPD Hughes 500D
TC31, TS2, TS3, SV27
Hide Signatures
(in reply to toyotatruckin)
       Post #: 3881
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/26/2010 10:34 PM
chief3452
Score: 100
Last Login: 5/4/2013
Status: offline
Wow, that is trashed! It appears your strut has suffered from either not being tight in it's mounting tabs or your prop is really out of balance. You should check the balance on that prop before running with your new strut.
Hide Signatures
(in reply to hal93)
       Post #: 3882
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/27/2010 2:49 AM
TrEsPaSS
Score: 100
Last Login: 5/6/2012
Status: offline
Hey man, as stated by Toyota... your drive dog should not be positioned IN your strut. When the engine torques (twists it tighter) the cable is pulling your drive dog into the strut, obviously causing it to bind. I am suprised that your cable has not snapped vs. the strut. Purchasing a new strut will not help unless you back off the dog from the end of the strut. You need to give it about 1/8-3/16 of an inch. Below is about 3/16", this is a MVD modded with a Dynamite .32 so I chose to run the gap a little wider to make up for the torque, note the grease on the rudder that had been thrown from the cable.
< Message edited by TrEsPaSS -- 7/27/2010 3:11 AM >
Hide Signatures
(in reply to chief3452)
       Post #: 3883
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/27/2010 4:39 AM
FX4L2CX
Score: 100
Last Login: 2/28/2013
Status: offline
Additionally, you may even need a longer flex cable....I set mine up so that there is a 3/16 or so gap between the drive dog and the strut when the flexshaft bottoms out into the collet. If you just get a new strut at this point and leave a 3/16 gap, there may not be enough flex shaft going up into the collet and may slip....check and see.
Kev
Miss Vegas .18 CVR , JAE 12 .18TZ
Shrike 10 Cox/RJL .15 Conquest, Shrike 40 7.5Df
Hide Signatures
(in reply to hal93)
       Post #: 3884
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 8/26/2010 2:13 AM
tonywayne
Score: 100
Last Login: 2/13/2013
Status: offline
I notised on most picks thies stile boats the rudder is to the left of the prop. On my miss vegas it is on the right. Is this just pers pref or doe sit perform beter on the left?
You know you can’t spell when MS word don’t know what the ___ you’ve typed
Hide Signatures
(in reply to ka350kaptain)
       Post #: 3885
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 8/26/2010 4:31 AM
amax
Score: 107
Last Login: 5/14/2013
Status: offline
With the rudder on the left it tends to be a little more forgiving when correcting to the left, these boats are made to run in a Right Hand Oval so it's totally geared towards Turning Right. With the rudder On the Right it will Turn Right a little better at high speeds But will Pull the Left Sponson up Quicker if you have to Ease left to correct your Line to the next buoy,,(if your on a track).
Top Speed Hobbies llc. Gotta Need For Speed..
www.youtube.com/user/topspeedhobbies
Hide Signatures
(in reply to tonywayne)
       Post #: 3886
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 8/26/2010 6:14 AM
joseywales
Score: 100
Last Login: 8/22/2011
Status: offline
JD has a JAE.12 rigger??!!!
Hide Signatures
(in reply to amax)
       Post #: 3887
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 8/26/2010 8:37 AM
Jerry Dunlap
Score: 105
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: joseywales
No, JD was launching a JAE 12 rigger.
JD
Hide Signatures
(in reply to joseywales)
       Post #: 3888
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 8/26/2010 9:09 AM
joseywales
Score: 100
Status: offline
Aw shoot! Thought you would be on the darkside!
Hide Signatures
(in reply to Jerry Dunlap)
       Post #: 3889
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 10/17/2010 3:43 PM
res3567
Score: 117
Last Login: 7/3/2011
Status: offline
What do we have here? Two Vegas....one is the Duece, and the other is the original. The Duece requires you use either the Tiger drive starter or  belt. The original is good ole pull start. When doing a quick run at the pond and wanting to travel light, the original Vegas makes it conveinant. So....for any of you who have the Duece.....and blew upthe engine, you might consider a new engine with the pull start. The Duece is my cousin's and the original is mine. The Tiger Drive is stripped out in his, so I gave him my belt starter. It is more equipment to pack at the pond....along with fuel and other things. And oh yea....the engine in his ....well....it starts and idles....put it in the water....and it dies under load. It was not broke in properly, and the throttle arm broke on one run. When he went to retrieve it...it was wide open....for a few seconds. I have tried every adjustment. I think the engine is history. I wil try to sell him on the idea....but he likes the SuperTigre. I am not saying the Duece is  bad boat, just giving my opinion on the differences on both boats.
Click for fullsize
Hide Signatures
       Post #: 3890
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 1/10/2011 11:53 PM
scuba6
Score: 100
Last Login: 12/21/2011
Status: offline
New guy here. Am wanting to put a macs 3.5 pipe on my MV. Woundering do i need a header? Does this pipe have to be modded to fit? Read thru this tread till my eyes hurt. Lots of good info(to much to take in!) And does it require any other parts to make fit. Seen something about a fitting in exhaust for fuel tank breather to. Along the lines of drilling a hole.(dementions would be great) thanks in advance! By the way GREAT SITE!
Hide Signatures
(in reply to res3567)
       Post #: 3891
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 1/11/2011 5:18 AM
amax
Score: 107
Status: offline
quote:
ORIGINAL: scuba6
Do you have the Vegas or the Deuce?
If you have the Vegas with the AQU .18 and the 90*header with no flange you will be able to use the MACS Pipe with no problem installing it. You will need to Cut the MACS Pipe between 8-3\4"in to 8-1\2"in measuring from the Stinger(the small outlet end) Forward. The longer you leave the pipe the more bottom end torque you will have(and you can always trim more off later if you want ) the shorter you cut the pipe the Higher the RPM Range you will be able to reach, But you Loose bottom end as you gain Top end. It's best to start long and work your way down.
The Pressure fitting should go at the fattest part of the pipe, drill a 1\8"in hole and thread it in,, But don't over tighten it and strip it out. I Like to seal mine in place with a dab of Silicone.
Hide Signatures
(in reply to scuba6)
       Post #: 3892
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 1/11/2011 6:29 AM
toyotatruckin
Score: 100
Status: offline
Personally with all the different little hardware parts out there id double check and make sure of what you have before drilling.
Hide Signatures
(in reply to amax)
       Post #: 3893
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 1/11/2011 9:21 PM
scuba6
Score: 100
Status: offline
Its not a duece just mv. Thanks guys gonna order the stuff this week.
Hide Signatures
       Post #: 3894
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 2/16/2011 6:31 AM
tonywayne
Score: 100
Status: offline
no body racing the vegas anymore? Im in the prosses of rebuilding an old vegas with moded go 18. ill upload some pics of my progress sone.
< Message edited by tonywayne -- 2/17/2011 12:38 AM >
Hide Signatures
       Post #: 3895
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 2/17/2011 3:14 AM
res3567
Score: 117
Status: offline
Still running mine..... with a Go .18, ran it this past weekend......tell me bout yo boat......
Hide Signatures
       Post #: 3896
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 2/17/2011 5:47 AM
tonywayne
Score: 100
Status: offline
i think its a first gen i bought form a local. Its going through alot of hull work and im doing the 1/4 sponson mod. custom radio box, 6oz sulivan tank, and will be running a go 18 with moded head, bored carb an light port work. Im also posting over in the deuce thread asking about my shaft problem. thanks http://www.rcuniverse.com/forum/m_8749167/anchors_10341999/mpage_10/key_/anchor/tm.htm#10341999
Hide Signatures
       Post #: 3897
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 2/18/2011 4:29 AM
res3567
Score: 117
Status: offline
Ok.....Amax is a guru on the Go engine, and Toyotatruckin knows alot about flexshafts. You are in good hands here......
Hide Signatures
       Post #: 3898
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 2/21/2011 6:34 AM
tonywayne
Score: 100
Status: offline
Whats the weight of some of thies boats coming out to be?
Hide Signatures
       Post #: 3899
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 2/23/2011 2:36 AM
res3567
Score: 117
Status: offline
According tto the Aquacraft website....the MVD is about 5lbs.......
< Message edited by res3567 -- 3/2/2011 3:17 AM >
Hide Signatures
       Post #: 3900
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
