RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it... - 7/5/2006 11:32:05 PM
toyotatruckin
Status: offline
Im not sure about King as its name says it all "MISS".lol Hay I had a post booted yesterday and it was to you james, "off topic" was the reason It was some pictures of the tc31 that i took running.....NO, it was not a miss vegas, But it was on topic as we had been talking about the race that me and you are going to have WITH the miss vegas sunday. So all-in-all it was a miss vegas topic as it has everything to do with seeing the performance of the miss vegas against another RTR boat with mods! Correct me if Im wrong here!
_____________________________
Mike-R&D
Dominator models
(in reply to TwistedLiquid)
       Post #: 126
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it... - 7/5/2006 11:42:32 PM
dirtysouth31
Status: offline
cant wait for the vid twisted..i am compiling what i learn here and i have ordered the grim racer fin and the lead weights thanks to james advice,all i need now is a prop and new coupler!!!!!!!
and by the way im still a stock vegas for the moment,but the other day just for giggles got into a little race with a v24.well i smoked this guy and was feeling preety good about it considering the price difference.until i was told that a nitro will beat a gas anyday. is that true??
uh yeah..what was i saying???
       Post #: 127
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make i... - 7/6/2006 12:06:55 AM
Tomi
Status: offline
Hey james,,
It's all stock. we're running with a bit of negative on the prop. You said running 5mph is running lean, but after we get it in a good turn, it just hauls booty. It just wants to load up all the time. Most of the time we're lucky to get it to haul butt, other times we're just waiting for it to kick in.
We just changed out the clunk to a airplane clunk so hopefully that will help a little bit. We're ordering up a Miss LLama fuel tank for it too.
Also, we get a bit of water in the hull. Is there a way to drain the water while the boat is running?
-Tomi
(in reply to dirtysouth31)
       Post #: 128
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make i... - 7/6/2006 12:15:07 AM
Grimracer
Status: offline
Vegas Fans.
Let me see if I can help clarify a few things as well. Thanks for your help James while we were out racing.
First.. Please if you remove the foam from your cowl make sure you put some in the cowl some other place. It does not take much to make the cowl float but losing a cowl is a bummer.
The biggest issue with the cable coupler is not the size or weight.. it’s the run out. If you look close and you are taking time to align the coupler take the time to check the flywheel and collet as well. The weight of the factory coupler is not such a bad thing if you are lookin for pure speed. The extra weight will help the boat launch the prop.
If your boat is speeding up in the corners and bogging in the straights first make sure you are plenty rich. Then start tucking the rudder under the boat. Just a small amount at a time! (note) you might have to clearance the top (leading edge) of the blade to get enough movement. What this does is starts to pin the back of the boat in the corners making it easy to set the needle. Also it’s a good idea to sharpen the bottom of the rudder. You do not want the rudder acting as a lifting point. It makes plenty of lift the way it is.
The Grimracer Turn Fin needs to be sharpened as well. Leading edge (outside only) and bottom as well. Make it as sharp as you can. I use 150 grit on a block to cut it to shape and finish up with 400 wet and oil.
I have yet to blow off a Miss Vegas. I really like the boat and it’s a blast to drive.
BTY.. the wings on the boat weigh over 6oz.. if you like and don’t mind the looks try running your boat with them off.. The CG on the boat is quite aft and the removal of the wings will help adjust this. Make sure you keep the wings in good shape however for show time.
ROCK ON
Grimracer
Aquacraft Boat Desiger
O yea.. Grimracer says.. NEVER SWIM FOR A DEAD BOAT.. PLEASE
Aquacraft Boat Designer
(in reply to Tomi)
       Post #: 129
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/6/2006 12:50:23 AM
t munn
Status: offline
guys ,
last night i greased my vegas driveshaft and where the metal part of the shaft runs in the bottom of the strut.
i tightened it up good and pulled on it firmly as the directions stated.
i went about 3laps or 500" and the whole assembly came out of the coupler and i lost everthing from the coupler back to the prop.
i replaced it with parts from my other the vegas that was purchased between 2 of us for parts.
it stayed in for the rest of the night so i figured all is well.WRONG......
I went to try my boat again tonight and the same thing happened so no testing.
I tightened the shaf exatly as per directions, left the space between the washer and strut and puuled to check tightness.
is this a problem anyone else is having?
am i doing something wrong ?
is the miss llumar coupler a better setup?
will aquacraft replace them?
Man i am bumbed i waited months for my boat.
(in reply to Russ Williamson)
       Post #: 130
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/6/2006 2:28:58 AM
Jerry Dunlap
Status: online
In all the running I've done with Miss Vegas boats, and that's a bunch, I've never blown a flex drive out of the coupler. I do tighten the $#^! out of the coupler when installing the flex cable into the coupler. We ran the pi$$ out of 6 Miss Vegas hulls at the IMPBA Internats and never blew out a flex drive.
I'm not saying it cannot happen, because it obviously did. I just have not experieced that problem and probably because I really cinch down on the cable.
JD
(in reply to t munn)
       Post #: 131
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it... - 7/6/2006 2:41:43 AM
TwistedLiquid
Status: offline
DirtySouth...I hope you beat the V24...it only does 18 mph.....
James
TWISTED LIQUID RACING
       Post #: 132
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it... - 7/6/2006 2:46:04 AM
TwistedLiquid
Status: offline
Thats OK Mike.....I know it was deleted...but heres the thing...it might be off topic, but when I put the Video up on Monday after Sundays race....Lets see how many times its viewed...Ha Ha.....it will be on the topic then....See Ya at the lake.....
James
(in reply to toyotatruckin)
       Post #: 133
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/6/2006 2:49:39 AM
t munn
Status: offline
thanks jerry,
I could not beleive it either i loosened it nice to get the shaft way into the coupler,tightened it so far that it jammed the 10mm wrench and had to wiggle it out then I gave it a REAL good pull and it never budged on the shore.
is it possible that I am putting the shaft too far in the sleeve with the slot in it.i did not think so because i only had the 1/8" in between the washer and the strut.
I ordered some parts but man i do not want to be loosing more and the down time sucks.
I am going fishing with a very large magnet since the water is only about 10' deep and i have a goog idea where they fell off
I have very good mechanical skills but is there a "trick" that i might be missing?
Terry
(in reply to Jerry Dunlap)
       Post #: 134
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make i... - 7/6/2006 3:12:39 AM
TwistedLiquid
Status: offline
Hello Vegas Fans!!!!
Let me see if I can help clarify a few things as well....We have no GrimRacer parts on our 8 Vegas boats....
James
(in reply to Grimracer)
       Post #: 135
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast! - 7/6/2006 3:43:52 AM
TwistedLiquid
Status: offline
OK....Terry let me solve your issue on losing the driveshaft....first it has nothing to do with the coupler being tight or not tight.....Vegas I am sure is not aware of this, but because we test the boats...we are....
We got our new Vegas boats today....the factaory has made a big boo boo....the shaft is backwards....AquaCraft or the shaft maker for them....has put the prop dog on the wrong end...LOL...I know you are saying huh?
Well it simple...look at you Vegas shaft {in your old Vegas}....it is spiral in shape....if it is put in backwards...it pulls its self out, just like a screw backing out of its hole....what happends is it cant pull out...so it shreds and forces the coupler to release the shaft because it un-whines...we started our new Vegas at lake mead today...and the shaft came out on land...here is what we noticed....the shaft is catching on the coupler joint where the shaft tube and the strut meet....it destroyed our our shaft tube...I dont know how many Vegas shafts got out like this, but I am sure when AquaCraft becomes aware of this...they will help in fixing it.....we took a old shaft and put it in the Vegas...no issues....when placing the old shaft and new shaft in the same view it was very clear the issue...but for half hour we were like what the hey!!!!
So barrow a old one....but remove the strut to see...she is still clean on the end of the driveshft tube....if not it will mark up you new one....
P.S. We want to hold a IMPBA EVENT at lake Mead....nice place...to many tourist.... Bring a umbreela..it's freaking hot....lol
James
       Post #: 136
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make i... - 7/6/2006 5:04:11 AM
Ron Olson
Status: offline
James, posting the video is no big deal. You can use any place including your site to link the video to as long as any member doesn't have to sign up to view it. This site recommends two places but I haven't had any luck with uploading vid's to either one of them. Photo Bucket did work fine for me though and doesn't require a membership to view them.
Member, Southwest Michigan Model Boat Club.
       Post #: 137
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make i... - 7/6/2006 8:43:30 AM
TwistedLiquid
Status: offline
Yes we will place it on our site....since this site is not working as you say....we will get it up along with some Lake Mead, Nevada Video of me chasing a 54,000 Ski Nautic...you should see the look on his face, when we pass him......LoL...when he returns to shore...he yells out..how much is one of those things....I responded...53,700 less then your boat...
PRICELESS
James
(in reply to Ron Olson)
       Post #: 138
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make i... - 7/6/2006 2:27:00 PM
Grimracer
Status: offline
Terry let me seek if I too can add some light to this subject.
When you tighten the coupler did you notice if the larger outer part of the coupler was running into the smaller part.. near the end of the threads on the smaller inner part.. When the coupler is tight you should still see threads on the smaller coupler. If you do not see threads when the coupler is tight the coupler is bad.
Also..
All the cables for the Miss Vegas are left lay.. Even if the MFG was to turn the cable around before assembly it would still be a left lay cable.. It does not matter witch end you assemble the stub shaft too it can not be installed backwards. With the direction the engine turns the cable is constantly tightening its self. In essence shrinking as its used. This is the reason you need to leave a gap between the back of the strut and the drive dog on the stub shaft (prop shaft). A good rule of thumb is to leave a distance that is one dia of the shaft.. i
