jombo
CT, USA Status: offline
quote:
ORIGINAL: Gersh Quick question, my savage stalls after only a few minutes of running, it stalls when i let it idle, after that its really hard to start, if turn the idle up the truck moves on its own, any help on what to do? it might be the lsn too lean, try riching it up a bit. i found that the pinch test is pretty accurate, pinch the fuel line and it should take 4 to 6 sec for it to turn off the motor.some times if your lean on the low end you may be rich on the high end. warm it up and try some full throttle runs if its wanting to stall or does, your too lean on the high end;but if it dosent want to go and just sounds its drowning its too rich. good luck.
_____________________________
ka-chow lst2, there is no substitute lst forums, ground pounders rc
