drunkenbushman
Joined: 11/4/2004 From: SydneyNew South Wales, AUSTRALIA Status: offline
quote:
ORIGINAL: bleary Well I weakened last night and picked me up one of these cheapo badius type things on ebay.I'm gonna rip out all the crap 27mhz stuff,and put in one of my spare Align 2500kv brushless motors,and whatever lipo will will fit inside.Those wings look like prime candidates for aelirons,and with some carbon reinforcing,I should have a cheap little rocket.If the wing has too much lift too it,I may even make up a speed 400 pylon racer type wing out of balsa and glass....then I will need a new tail and rudder I spose...Looks like a good customising project though as long as there is enough room in the fuse for the electrics.I allready have a couple of similar type planes,one with aelirons,one without,and they are quite quick with the right setup,although the fuselages are fairly tight for the electrics.Hopefully this one is slightly bigger,it looks like it may be. What you think lads? good idea? That thing is going to hoon bleary, will the wings hold up or will you have to reinforce?
_____________________________
Flying inverted down under is just like flying right way up up over.
