Bridi Kaos vs Utter Chaos ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Bridi Kaos vs Utter Chaos ?
Page: [1] 2   next >   >>
Login
Bridi Kaos vs Utter Chaos ? - 12/24/2002 10:12:15 AM
CCRC1
Status: offline
Can anybody who has built and flown both of these aircraft tell me what the differences are. Do they use the same airfoil? I have acquired an Utter Chaos kit an I am getting ready to put it on the bench. I would like to make a few minor modifications to include changing it to a tail dragger. If you have built and flown the Utter Chaos what engine recommendations do you suggest.
       Post #: 1
Kaos differences - 12/24/2002 2:41:20 PM
EXCAP232
Status: offline
The Kaos planes have the airfoil / wing in common which is what maked it a Kaos. The tailfeathers are different from the original to the Utter model. The best tailfeathers were on the Ultimate which was distributed by Direct Connection. Bad fuse design which was very narrow and had a joint a the fuse side that was a real weak spot. A good 60 2S or a 90 4S is a good match for the plane. You may want to add some length to the landing gear as the newer engines will swing more prop than the original so clearance is a problem. I sold my Ultimate Kaos after about 300 flights complete with some added fiberglass and carbon fiber to keep the fuse together. Still have the plans which show the tail dragger (conventional gear) set up. Will send you a copy of that part if you need it.
EXCAP232
(in reply to CCRC1)
       Post #: 2
Bridi Kaos vs Utter Chaos ? - 12/24/2002 8:53:48 PM
CCRC1
Status: offline
Excap232 I sent you a PM.
(in reply to CCRC1)
       Post #: 3
Bridi Kaos vs Utter Chaos ? - 12/30/2002 1:42:58 AM
Rob Kelly
Status: offline
CCRC1 I have built and flown the Killer Chaos and it flies great. I'm using an OS.50 and it is the perfect set up, plane weighs 4 LB 14 OZ ready to go(less fuel).
I just picked up an Utter Chaos and will use the same combo but wiill keep it a tricycle gear.
I love four strokes but on the Chaos series I think the OS.50 is by far the best choice. I live at 5,000 ft and I can hand launch my Killer when feeling frisky so power is not an issue.
Good luck and keep it light, that's the ticket to a great flying Chaos of any description.
Rob
(in reply to CCRC1)
       Post #: 4
Bridi Kaos vs Utter Chaos ? - 12/30/2002 3:22:41 AM
firemedic305
Status: offline
Rob how do you think the os61fx will do on the utter Chaos. I am building one know and am trying to pick an engine 61fx of 91fs. Gary
(in reply to CCRC1)
       Post #: 5
Bridi Kaos vs Utter Chaos ? - 12/30/2002 5:36:51 AM
Rob Kelly
Status: offline
Gary, go with the OS .50 you will love it trust me. The .50 weighs 17 oz with muffler and has 1.8 hp. The FX 61 weighs 23.6 OZ and has 1.9 hp. I know you can't always believe hp numbers but these should be relative and having seen both engines in action I believe them. I have two buddies here in Colorado and we all bought the Killer Chaos's at the same time and they all have the .50 and they ALL fly great! All three weighed right at 5 LB mine a little under as I chose to go with one aileron servo. All the .60 and 91 would do is add weight and you get no benefit.
Good luck and keep it light!
Rob
(in reply to CCRC1)
       Post #: 6
Not i........ - 12/31/2002 9:09:01 PM
Flyboy Dave
Status: offline
....no way I'd put a .50 in a .60 size pattern plane. If I
didn't have this pile of .60's at hand....I'd put a Tower
Hobbies .75 in it....side-mounted of course.
_____________________________
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to CCRC1)
       Post #: 7
Bridi Kaos vs Utter Chaos ? - 12/31/2002 9:31:07 PM
Rob Kelly
Status: offline
Flyboy, why do you need a .60 or .75 in a 5 LB plane? Besides, the OS .50 has the same power as the OS .60. I guess if you want a lead sled then your way ought to do it! :-)
Rob
< Message edited by Rob Kelly -- Dec 31 2002 5:06PM >
(in reply to CCRC1)
       Post #: 8
Bridi Kaos vs Utter Chaos ? - 12/31/2002 9:36:57 PM
Flyboy Dave
Status: offline
Performance .
Click to see fullsize image.
Click for fullsize
Revver Bro #4.
(in reply to CCRC1)
       Post #: 9
Bridi Kaos vs Utter Chaos ? - 12/31/2002 10:09:06 PM
Rob Kelly
Status: offline
Flyboy, I guess we take different paths but we end up at the same place, having fun flying !
Enjoy!
Rob
(in reply to CCRC1)
       Post #: 10
Bridi Kaos vs Utter Chaos ? - 12/31/2002 10:21:38 PM
Flyboy Dave
Status: offline
You too, Rob....have a ball with your plane. I have 2
"Killers" in the pile, also. "lead sled"
And have a very Happy New Flying Year !!!
Dave.
< Message edited by Flyboy Dave -- Dec 31 2002 9:10PM >
Revver Bro #4.
(in reply to CCRC1)
       Post #: 11
Bridi Kaos vs Utter Chaos ? - 1/1/2003 12:47:45 PM
Rob Kelly
Status: offline
Flyboy, looks like your coming up on midnight. Happy New Year!
We had a nice Fireworks display here tonight. It did interrupt my building though! Utter Chaos is coming along nicely!
Rob
(in reply to CCRC1)
       Post #: 12
Bridi Kaos vs Utter Chaos ? - 1/1/2003 12:53:16 PM
Flyboy Dave
Status: offline
Back to ya, Rob....the Utter Kaos is a sweet plane.
Click for fullsize
Revver Bro #4.
(in reply to CCRC1)
       Post #: 13
Bridi Kaos vs Utter Chaos ? - 1/1/2003 9:28:51 PM
CCRC1
Status: offline
Guys, have either of you flown the original KAOS, and how does it compare to the newer UTTER CHAOS. I have flown the original a long time ago and found it to be a solid performing sport plane! I was looking at a Saito .72 4s for mine. I have one in a Somethin Extra and it has power to spare. The Utter Chaos should be in the same weight range (5 - 51/2 pds). I know a lot of you are looking at SPA events so you can't use the 4s but I am looking for a solid, take to the field every time I go airplane.
(in reply to CCRC1)
       Post #: 14
Bridi Kaos vs Utter Chaos ? - 1/2/2003 1:54:57 AM
firemedic305
Status: offline
You can use a 4s in SPA up to .91 Gary
(in reply to CCRC1)
       Post #: 15
kaos/OS50 - 1/4/2003 7:00:58 PM
jeide
Status: offline
Here's a couple of pics of Rob tossing the Kaos. The OS50 pulls it like a rocket,of course, under 5lbs doesn't hurt either. Jim
Click for fullsize
(in reply to CCRC1)
       Post #: 16
another - 1/4/2003 7:02:49 PM
jeide
Status: offline
Inverted toss.
Click for fullsize
(in reply to CCRC1)
       Post #: 17
