guver
OH, USA Status: offline
It's too late for a formation charge, but a 300 ma charge for 15 hrs will insure that the cells are equalised or balanced. It is not necessary to discharge completely, but may be beneficial right after the c/10 charge. Then do another c/10 charge. I think that if you notice the run-time is gettting shorter then you must be dischargeing to a point at which you can tell and there's probably no useable capacity left. 3 or 4 other things that may be contributing to lower run-time is dimished battery capacity due to stress/abuse. You are not doing that using 3 amps charge. Dirty , worn driveline or motor getting worn, dirty. The only real way to tell is to test battery and compare to when new or compare to the label.
_____________________________
you hear that silence?
