RE: TS2 POST IT HERE...
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: TS2 POST IT HERE... Page: <<   < prev  3 4 5 6 7 8 [9] 10 11 12   next >   >>
Login
RE: TS2 POST IT HERE... - 5/2/2007 3:04 AM
jrizo1
Score: 100
Last Login: 3/22/2008
Status: offline
Hey guy's I am new with nitro boats and I just bothg a ts2
AquaCraft Top Speed 2 ARR Tunnel Hull Yellow
Futaba 3PM 3-Channel FM
O.S. .21 XM Marine Outboard
I will like to get help puting it togeder.
What else do i need to get it to run?
any advice will be aprecited thank you very much...
Hide Signatures
(in reply to wave waker)
       Post #: 201
RE: TS2 POST IT HERE... - 5/2/2007 3:26 AM
kb guy
Score: 100
Last Login: 1/10/2010
Status: offline
fuel, pump(several diff. types to pick from) elect starter, batt, glow plug driver,2 servoes(1 being a high torque)ca glue, batt. pack for receiver. what did i forget guys?????? CARTER
Hide Signatures
(in reply to jrizo1)
       Post #: 202
RE: TS2 POST IT HERE... - 5/2/2007 4:28 AM
jrizo1
Score: 100
Status: offline
Thank you for the the advice but whats is a carter?
Hide Signatures
(in reply to kb guy)
       Post #: 203
RE: TS2 POST IT HERE... - 5/2/2007 4:32 AM
kb guy
Score: 100
Status: offline
THAT`S MY NAME!!!! CARTER
Hide Signatures
       Post #: 204
RE: TS2 POST IT HERE... - 5/2/2007 4:35 AM
jrizo1
Score: 100
Status: offline
Do i need to get a pipe?
What is K&B i see it all over the forum?
Did i make the rigth choise with the engine?
How about the radio, is it the right one?
Hide Signatures
       Post #: 205
RE: TS2 POST IT HERE... - 5/2/2007 4:37 AM
jrizo1
Score: 100
Status: offline
Ohh i got it CARTER.
Hide Signatures
       Post #: 206
RE: TS2 POST IT HERE... - 5/2/2007 5:15 AM
unclecrash
Score: 100
Last Login: 3/15/2010
Status: offline
K&B Makes engines outboard and inboard.
_____________________________
I Ain''''t Buildin No TuG Boats
Hide Signatures
       Post #: 207
RE: TS2 POST IT HERE... - 5/2/2007 6:14 AM
Jerry Dunlap
Score: 100
Last Login: 3/12/2010
Status: offline
quote:
ORIGINAL: jrizo1
Have you looked at the Instruction Booklet that came with the TS2? I helped write that thing and it contains lots of useful information.
You don't need a tuned pipe. That radio system should work fine. The O.S. XM is an excellent engine.
JD(That's my photo on the box)
Hide Signatures
       Post #: 208
RE: TS2 POST IT HERE... - 5/2/2007 4:55 PM
macbane
Score: 100
Last Login: 3/11/2010
Status: offline
Hey jrizo1,
I'm in the process of putting my TS2 together. Here are some things that I found out: I found the template for the OS outboard to be slightly off. It the dimensions it says are very important did not match the dimensions that are on the template. I think the two top holes were too low by a 1/4 inch. I would measure to be sure.
Also, be very careful with the brass inserts that you epoxy into the transom: I found them to be a little weak.
And finally: don't be stupid like me and cut the steering push rods too short. I cut them twice and they were still too short!
Good luck,
John
Hide Signatures
(in reply to Jerry Dunlap)
       Post #: 209
RE: TS2 POST IT HERE... - 5/9/2007 2:31 AM
jrizo1
Score: 100
Status: offline
HI NEED HELP TO CENTER THE ENGINE
Hide Signatures
(in reply to macbane)
       Post #: 210
RE: TS2 POST IT HERE... - 5/9/2007 2:40 AM
wave waker
Score: 100
Last Login: 3/16/2010
Status: offline
quote:
ORIGINAL: jrizo1
mark the center of the transom, also mark the center of engine mount and align it,, then check the height of the mount make sure u have enough allowance when adjusting the engine height based to the prop line is parallel with the sponson bottom,then drill it for screws. hope this is what u mean.
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
Hide Signatures
       Post #: 211
RE: TS2 POST IT HERE... - 5/9/2007 3:11 AM
jrizo1
Score: 100
Status: offline
DOES ANY ONE HAS ANY PICTURES?
Hide Signatures
       Post #: 212
RE: TS2 POST IT HERE... - 5/9/2007 4:08 PM
jrizo1
Score: 100
Status: offline
THERE IS A CRACK ON THE BACK OF MY HULL BY THE DRAIN HOLE WHAT SHOULD I DO? IS BRAND NEW OUT OF THE BOX.
Hide Signatures
       Post #: 213
RE: TS2 POST IT HERE... - 5/9/2007 4:31 PM
Jerry Dunlap
Score: 100
Status: offline
quote:
ORIGINAL: jrizo1
The crack is more superficial than structural. It is along the seam line and the paint will sometime break along the seam.
You have a couple of options:
1. I've covered cracked seam lines in RTR boats with MonoKote Trim Sheet the same or near the same color.
2. Return the boat for a replacement hull. Instructions for returning the hull are in the Instruction Manual.
There are photos in the IM showing how the holes are drilled in the transom for mounting the engine.
JD
Hide Signatures
       Post #: 214
RE: TS2 POST IT HERE... - 5/9/2007 6:50 PM
jrizo1
Score: 100
Status: offline
THANK YOU FOR YOUR HELP , I TOOK IT TO THE HOBBY SHOP AND THEY GAME A NEW ONE.
Hide Signatures
       Post #: 215
RE: TS2 POST IT HERE... - 5/9/2007 6:54 PM
jrizo1
Score: 100
Status: offline
HEY GUYS WILL A SPEKTRUM High Torque, Metal Gear Servo Z590 WITH 80OZ IN TORQUE WILL DO THE WORK ?
Hide Signatures
       Post #: 216
RE: TS2 POST IT HERE... - 5/9/2007 8:27 PM
Jerry Dunlap
Score: 100
Status: offline
quote:
ORIGINAL: jrizo1
YES
JD
Hide Signatures
       Post #: 217
RE: TS2 POST IT HERE... - 5/9/2007 10:04 PM
jrizo1
Score: 100
Status: offline
IS NOT TOO WEAK?
Hide Signatures
       Post #: 218
RE: TS2 POST IT HERE... - 5/10/2007 12:08 AM
Jerry Dunlap
Score: 100
Status: offline
quote:
ORIGINAL: jrizo1
IS NOT TOO WEAK?
80 oz. in. of torque is sufficient for a 3.5 OB.
JD
Hide Signatures
       Post #: 219
RE: TS2 POST IT HERE... - 5/10/2007 1:23 AM
jrizo1
Score: 100
Status: offline
now how do i conect all the gas and water lines i am a litle confused?
Hide Signatures
       Post #: 220
RE: TS2 POST IT HERE... - 5/10/2007 4:03 AM
jrizo1
Score: 100
Status: offline
now my throttle servo is movin backwores wy?
Hide Signatures
       Post #: 221
RE: TS2 POST IT HERE... - 5/10/2007 4:28 AM
wave waker
Score: 100
Status: offline
quote:
ORIGINAL: jrizo1
ur radio might have a reverse servo, try to check it and set to other way.
to trace the fuel line from the fuel tank, one line will go to the carb, the other line will go to the muffler for pressure, make sure this thing will not interchange...now for waterline assuming ur using OS motor at the end of the cavitation plate there is a water pick-up, connect a tube there and the other end to the one of the nipple fitting in the cylinder haed.
there is also an oiler line coming from the bottom side of the muffler to the side of the lower unit.
Hide Signatures
       Post #: 222
RE: TS2 POST IT HERE... - 5/10/2007 4:34 AM
jrizo1
Score: 100
Status: offline
How do i chech if i have a revers servo?
Hide Signatures
       Post #: 223
RE: TS2 POST IT HERE... - 5/10/2007 4:37 AM
jrizo1
Score: 100
Status: offline
WAVE WAKER
THANK YOU I JUST FOUND WERE TO CONECT THE LINE I WAS MISSING.
NOW I JUST HAVE TO FIX THE SERVO ISUE.
Hide Signatures
       Post #: 224
RE: TS2 POST IT HERE... - 5/10/2007 5:51 AM
Jerry Dunlap
Score: 100
Status: offline
quote:
ORIGINAL: jrizo1
WAVE WAKER
Most TXs have serve reverse tabs somewhere on the front /top of the TX.
JD
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.281RCU1
