borneobear
Joined: 6/8/2006 From: Selangor, MALAYSIA Status: offline
Spockie-Tech, I use 'Play Dough' to make the initial shape (s). . Its kiddies stuff, cheap, easily available and does not stick to epoxy. I think that Tamiya stuff of yours would be much better. To build the structure, I apply the epoxy first - make a thin layer. Then I apply fibre glass cloth over this layer. The fibre glass will absorb the epoxy. Add additional epoxy to add more fibre glass layers. Wait until the epoxy dries, then remove the Play Dough. WALAAH! You have a structure! Using this simple technique, you can have the wall as thin as you like. To smoothen up the surface for painting, I sometimes add CA and powder. Grind to shape, sand paper smooth, then paint. Good luck!
