borneobear
Joined: 6/8/2006 From: Selangor, MALAYSIA Status: offline
This process was repeated on the other side of the slider block, but at a much smaller size (I only need to insert the slider block from one side). Anyway, after making a big enough opening, I went to my engineering friend, and he whipped out a slider block that fit exactly the hole that I'd made (don't ask me how he did it, cuz I don't know). The top two are the 'normal' pitch slider block, while the bottom is the special block made to fit the modded washout base:
