borneobear
Joined: 6/8/2006 From: Selangor, MALAYSIA Status: offline
Note in the above pic, the motor mounting has been replaced with a metal mount. Here's why: After the Trex main gear went in, I noted that there was no space for the motor to be mounted. The two servos at the front limited any forward movement of the motor on its mount. Therefore, i had no choice but to extend the motor mounting area. And the only way I could do that was to cut the frame at the motor mount, and add another frame frontage to it. Here's a picture of the sacrificial frame where I took the front from. Very sad... It was a brand new USD 11.40 #36 frame.... oh well....
