Extra 330S kit...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aerotech R/C Models Support >> Extra 330S kit...
Page: [1]
Login
Extra 330S kit... - 6/8/2006 2:05:35 PM
Steve Campbell
Status: offline
As I ponder my next model, the less and less I want to have just another cookie-cutter ARF aerobat. By this, I mean the same trim scheme as a thousand other ones. For several reasons, I'm limited to a 30% model; and there is a distinct lack of actual kits for this size model.
The Aero-Tech Extra 330S is the most intersting one that my limited research has turned up. The web site info is a bit sparse, so I would appreciate any insight from those who have built and flown this one.
From what I have been able to gather, this airplane has a basic built-up box (formers, stringers, & planks) fuselage, with foam turtle deck, etc., and foam wings that one must sheet. Correct?
Are the tail surfaces foam or built-up? Airfoiled?
I will be using a BME 50 with a canister muffler. Is the fuselage designed for a canister installation?
Answers to these questions, and any other observations, would be greatly appreciated.
       Post #: 1
RE: Extra 330S kit... - 6/8/2006 2:52:06 PM
Aerotech
Status: offline
Hello,
You will read good and bad as with any manufacturer. The smaller Extra Kit will not do well with a BME55 simply due to its weight. Balancing will be a challange and I believe you will end up adding weight on the nose. I would put min a 3W 60 or the EVO 80 has proved to be a powerhouse. I will help with any questions.
Best regards
John
(in reply to Steve Campbell)
       Post #: 2
RE: Extra 330S kit... - 6/9/2006 2:34:44 PM
Steve Campbell
Status: offline
I would be using a BME FIFTY; not the super-light 55. And a can...
As with the size issue, I'm locked in to this engine, since I have it already.
So, what's involved in modifying the kit for a single canister? And am I correct on the design/construction parameters noted in my first post?
(in reply to Aerotech)
       Post #: 3
RE: Extra 330S kit... - 6/9/2006 3:18:38 PM
Aerotech
Status: offline
Hello,
You really don't have to mdify anything. The laser cut holes are in the formers already. You need only to close it off. Let me know if I can help further.
John
       Post #: 4
RE: Extra 330S kit... - 6/9/2006 9:50:27 PM
Steve Campbell
Status: offline
Okay, thanks. I'll give you a call next week or so.
       Post #: 5
RE: Extra 330S kit... - 6/9/2006 10:38:20 PM
Aerotech
Status: offline
Hello,
Look forward to serving you.
John
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
