TERBObob
Joined: 1/12/2003 From: Oelwein, IA, USA Status: offline
The prop shaft looks like it might have a slight angle to it ( prop looks like its angled towards the sky ) Otherwise ... you might want to just send it to me and I will take about a year or so to test and set it up right for you .... ( only kidding ) Looks good Personally , I went those braided lines idea , and ended up taking them off .... reason - you can't see either the fuel , or water running thru , and also think they might end up causing glitching , if they are not 100 per cent tight on the barbs . Those prop blast water pick ups also seem to be lower than the prop hub ... And last , but not least ... not sure if you have any , but I don't see any floatation( most commonly used are those colored pool noodles ) Opps , take that back ... another thing I just noticed ... the drive dog seems to be butted right up against the strut . With a collet setup , you need to leave almost a 1/4 of an inch between the drive dog and the strut for when the flex cable needs to flex ( tighten up - shrink ) , otherwise , you will have binding and might rip the flex cable and do some serious damage to your hull .
< Message edited by TERBObob -- 6/8/2006 3:46:04 PM >
_____________________________
"experienced " is just another way of saying that you already did all the mess ups and should know better now !
