RE: Offical Mugen MBX5T thread
Tower Hobbies
Logged in as Guest
  Printable Version
THUNDER TIGER EK4 1/8 SCALE WITH PRO-70BX - RTR
Seller:  RCJAX904
Details:   $400.00   |  1/8/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Offical Mugen MBX5T thread
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Offical Mugen MBX5T thread - 4/17/2007 5:40:15 PM
Sonyb
Status: offline
No not really ......sometime no matter what you purchase if you are not lucky...its not gonna work.....If you modiffied axial engine
you will enjoy it more....but if you got money to burn I suggest the RB928 truggy.....this engine makes your car Scream!!!!!!
(in reply to revo7617)
       Post #: 251
RE: Offical Mugen MBX5T thread - 4/17/2007 6:03:39 PM
MBX5T Maniac
Status: offline
All I'm going to say is that the MSR and MBX5T share only a few parts, being the diff cups, the bulkheads, and a few other things. In order to convert a MSR to a MBX5T, you will be spending quite a sum of muney
_____________________________
My toys: LST, Mini Inferno, XX-CR, GrassHopper, RC10, Rustler, MBX5T Prospec, Mugen MST-1
(in reply to Sonyb)
       Post #: 252
RE: Offical Mugen MBX5T thread - 4/18/2007 1:30:38 AM
celt
Status: offline
Hey Guys,
New to this thread/forum and just ordered an MBX5T-ProSpec and usually race an Xray XB8-TQ. Has anyone tried the GRP series tires for the truggy?
Do most of you start with the out of box setup? Diffs? Just want to get some research behind me so I'm ready to go when it gets here...
< Message edited by celt -- 4/18/2007 1:31:31 AM >
(in reply to MBX5T Maniac)
       Post #: 253
RE: Offical Mugen MBX5T thread - 4/18/2007 4:24:18 AM
MBX5T Maniac
Status: offline
Most people like to start with the setup provided with the MBX5T. I have 5k 10k, 2k in the diffs.
Also, when you build the diffs, it says to put these little S3 o-rings in the diffs. Don't.
(in reply to celt)
       Post #: 254
RE: Offical Mugen MBX5T thread - 4/18/2007 6:28:57 AM
myrc
Status: offline
Actually it says in the book only to exclude the S3 rings in the rear diff.Make sure you mark your diffs such as R for rear C for center and F for front. I am sure if you race buggy that this is only common sense.
quote:
ORIGINAL: MBX5T Maniac
< Message edited by myrc -- 4/18/2007 6:37:48 AM >
       Post #: 255
RE: Offical Mugen MBX5T thread - 4/18/2007 12:15:42 PM
celt
Status: offline
quote:
ORIGINAL: myrc
Thanks, I might have missed that.
(in reply to myrc)
       Post #: 256
RE: Offical Mugen MBX5T thread - 4/18/2007 12:59:57 PM
MBX5T Maniac
Status: offline
quote:
ORIGINAL: myrc
Correction: Don't use any of the S3 o-rings. I don't care what the manual says, but those o-rings shouldn't be put in.
I took this info straight from another site, b/c rcu won't let me link.
quote:
Here are some build tips for guys putting together a MBX5T (or buggy)
The biggest tip would be prepping the diff cups and double-gasketing them. Using like 3 different grit sandpapers (I use emery cloth) you want to sand the cups until they’re smooth as glass. I use 320 grit, then 800 grit and finally 1500 grit. Place the paper on a perfectly smooth table and hold the cup on the paper. Swirl it around in a figure 8 pattern. The idea is to get the cup perfectly smooth and flat. When you go up to 800 grit, you’ll quickly see the plastic get very shiny smooth. If you didn’t go long enough on the 320 grit, you’ll clearly see it. I then do a quick run with the 1500 grit and they’re dead straight. What this does is ensures the cup won’t leak against the ring gear or spur gear. Most people blame the leaky Mugen diffs on the o-rings, but 95% are at the cup (just take two cups and face them together and see the light in between them as you rotate them face to face). Remember, the cups are not machined, they're molded. Then double up the gaskets (Part # C0257). I use my screws 2mm longer than the manual and tighten up. They’ll NEVER leak from the cup (Tip comes from Chad Bradley).
I also have thicker 5mm (S5) o-rings for the out drives. These are tighter than the stockers. The real key is to use grease on them (the thicker S5 o-rings or the stock S5 o-rings) and in the slot on the outdrive shaft. Of course, do NOT use the small S3 o-rings.
I use the stock Mugen brake linkages so I put a slight z-bend in the upper rod to get it fit right. You won't be able to easily adjust the rear brake bias with the z-bend, but remove the small 2x10mm screw and twisting it is very easy. I usually get it set right and then adjust the front in or out. I know most guys love the Kyosho linkages. If you’ve had the Kyosho, you may like it and want to fit them on the Mugen. The Mugen uses fuel tubing where the Kyosho has those little springs. I’d like to change mine over to try the springs, but don’t have a Kyosho to see how it goes. Maybe someone else that switches can post pics.
The kit should also have shims to get the ring & pinion mesh set. They go outside the 8x16 bearings on each side and just add pressure to get the ring gear closer or further away from the pinion. They are 14mm x 16mm by .1mm thick. On the buggy, I always used two on the diff cup side to push the ring gear away from the pinion. But I've heard that the new 46/10T ring & pinion on the MBX5T doesn't need them. Regardless of what anyone else uses, always check the backlash on your car.
The rest of the car goes together like butter. New shocks are SWEET!
Best regards,
Tony P.
(in reply to myrc)
       Post #: 257
RE: Offical Mugen MBX5T thread - 4/19/2007 1:19:56 PM
celt
Status: offline
It would seem that all the setups I see use maximum droop. How does it handle with all that weight transfer?
       Post #: 258
RE: Offical Mugen MBX5T thread - 4/20/2007 1:26:20 AM
MBX5T Maniac
Status: offline
That's what the Swaybars are there for.
(in reply to celt)
       Post #: 259
RE: Offical Mugen MBX5T thread - 4/20/2007 12:34:07 PM
celt
Status: offline
Swaybars offer side-to-side resistance to body roll, not forward to back.
They do nothing to inhibit weight transfer front to back.
       Post #: 260
RE: Offical Mugen MBX5T thread - 4/20/2007 1:14:04 PM
MBX5T Maniac
Status: offline
The swaybars actually limit the suspension downtravel, so when they are installed, you aren't getting maximum downtravel.
Excuse, I made a mistake, in combining body roll and weight transfer.
I'm not exactly sure what you are asking though. What do you want to know?
(in reply to celt)
       Post #: 261
RE: Offical Mugen MBX5T thread - 4/21/2007 5:30:51 AM
celt
Status: offline
Down travel (droop) can be adjusted to limit weight transfer with the droop screws on the inner portion of the arms. I know on vehicles this wide, with this much travel, they can get the "dives" with this much suspension. If you limit down travel, you can limit front to back weight transfer - a huge tuning option in on-road cars.
I guess what I'll do is try max travel just short of extending the shocks and see how it goes from there...
       Post #: 262
RE: Offical Mugen MBX5T thread - 4/22/2007 12:20:00 AM
nascardad24
Status: offline
That fuel filter that you have on the pressure line, did you remove the filter in it? If not, I'd recommend it.
Fuel filters on the gas line, was thinking about getting a check vaulve for the pressure line though.
Getting ready for round one of the pro series next weekend, so much stuff and little time. Pretty much just checking things off the list and breaking in the mamba. Will be its first outing (mbx5t) and what better way to do it than at the pro series.
Kyosho STRR~Futaba~Sirio~Acer Racing~BCE~
Horsepower sells engines, Torque wins races
       Post #: 263
RE: Offical Mugen MBX5T thread - 4/23/2007 12:13:30 PM
celt
Status: offline
I noticed when building the brake linkage, the rods at the servo end are mounted close together but at the brake cam end thay are forced apart. Do most just run them that way and they are fine or do you modifications for better fit? Or do you do what Tony P. suggests and replace it all with Kyosho parts.
(in reply to nascardad24)
       Post #: 264
RE: Offical Mugen MBX5T thread - 4/23/2007 5:03:25 PM
revo7617
Status: offline
Guys, Im getting my MBX5T standard edition tommorrow, any suggestions on the build up proccess??
REVO7617
Mod. Revo / OS.18TZ
(in reply to celt)
       Post #: 265
RE: Offical Mugen MBX5T thread - 4/24/2007 2:49:44 AM
