MiamizFinest
FL, USA Status: offline
quote:
ORIGINAL: Jesse101 quote:
ORIGINAL: TeamLosiFan No, the rear end doesn't swing. It's really not a loose truggy. Mine seems to be planted very well. But yes, the on power push seems to be the only issue I have on handling. Other than that, I absolutely love my 5T. And I'm sure that the push issue is just my tuning inexperience. That's what I'm trying to find out now. How to lessen the on power push. I'll try a heavier center diff and see what happens. But what else will change with a heavier center diff? I don't wanna get everything all out of whack. i rarely mess with my diff oils when going from track to track, but i do adjust my caster and rear toe. if you are running on a small indoor track with tons of traction, i would run either the 2.0 to 2.25 rear toe block, 1mm spacer in front on your upper arms, if you need even more you can shorten your wheel base. tire selection is also big, see what the faster peeps are running. running 7-10-2 diff oils. also check your ride height. its trial and error and im still learning myself, but dont be afraid to educate yourself on what can effect what on your kit. a manual you might want to download that explains allot of setup changes is the Xray manual, it provides some detail on what does what. the Mugen truggy steers on a dime when set up correctly thats for sure! i have tried other drivers suggestions and setups and honestly i still went back to what i personally felt comfterable with. you might find a setup that fits you better. and thats all that matters u got it right not he money, i tryed useing other peoples set ups and it jsut didnt feel right (local guys) they i whent with my own and it made a huge diffrenceim very happy where im at right now and it funny becuase i got a friend with a prospec too and his set up is compltely diffrent yet we can pull off almost the same lap times and be very compatative with one another, yet we switched controlers ones he drove mine i drove his and we both where all over the wall it all comes down to how u drive
_____________________________
-= THE WORLD IS YOURS =-
