RE: Please post Saito 125 rpms..
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> RE: Please post Saito 125 rpms..
Page: <<   < prev  1 2 [3]
Login
RE: Please post Saito 125 rpms.. - 5/27/2008 10:21:26 PM
Flyer95
Status: offline
Changed the bearings on my SA125 for a few days ago as the stock ones had a bit radial endplay when moving prop.tips back and forward. Now this engine is turning a APC 16x6 @8500rpm great , same as OS120III with pump both running on 10% nitro and 20% oil castor/syntetic blend.
< Message edited by Flyer95 -- 5/27/2008 10:22:03 PM >
(in reply to bawls)
       Post #: 51
RE: Please post Saito 125 rpms.. - 6/3/2008 9:51:55 PM
bawls
Status: offline
quote:
ORIGINAL: Flyer95
I realize you are only using 10%, but has your RPMs on the APC 16x6 improved any?
(in reply to Flyer95)
       Post #: 52
RE: Please post Saito 125 rpms.. - 6/8/2008 10:01:20 AM
Flyer95
Status: offline
Think I gained about 200rpm after the bearings where changed. I say "think" just because my engines also turn more rpm sumer time which is now. The rpm change can be as great as +200-300rpm in hot wheather and thinner air compared to winter time and below 0-degree celsius. I also use a dubro 45-degree exhaust deflector that keeps the airplane clean but probably cost me 100-200rpm or so.
(in reply to bawls)
       Post #: 53
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
