RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE?????
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE?????
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/19/2006 6:38:32 PM
grunho
Status: offline
alright then if you already decided that you are going to 4wd at least change your name so people don´t get confused
_____________________________
if you didn´t break anything its because you´re not playing hard enough
(in reply to 2WDrifter)
       Post #: 76
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/19/2006 8:00:31 PM
driftdriftdrift
Status: offline
seriously dude dont buy an xmod. you'll want that money later on to get a 1/10th
Do It Sideways Fool
(in reply to grunho)
       Post #: 77
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/20/2006 12:17:51 AM
Auslide
Status: offline
Agreed: 1:10th is a Far Better Size and At least You will be able to get a Wider Range of CHassis, Parts and be able to attend Drift meets..
We Look forward to seeing what you end up getting..
There is Nothing Wrong with Nitro, but for Drift they are not the Best.
They require more Matenience, More room and You cant attend late night Drift meets or most Indoor meets with a Nitro
Electric Shaft Drive is the Only way to go for Car park meets and Drift meets..
Just make Sure they have no Exposed Gears like a TB-02 or TT-01 or TL-01 less Chance of a Pebble Ruining a Days Sliding
< Message edited by magnat -- 7/20/2006 12:20:54 AM >
(in reply to driftdriftdrift)
       Post #: 78
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/20/2006 6:16:49 PM
2WDrifter
Status: offline
ill still drift or tail out with 2wd so its not important to change my name. x mods also have aftermarket upgrades like stacked FET's carbon fiber chassis, lipolys, alum wings, aluminum diffs, aluminum parts for the wheel links and billet shocks, drift tires(not radioshak ones) motor upgrates(20t to 40t) turbos, aluminum steering links, better servos for steering, battery holders, AWD aluminum driveshafts, nylon gears, sheilded and unsheilded bearings, AWD "dogbones", stiffer springs, etc.
4wd will ALWAYS = OWNAGE
(in reply to Auslide)
       Post #: 79
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/20/2006 9:10:32 PM
grunho
Status: offline
helloooooo , it was a joke ease up bro
       Post #: 80
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/21/2006 6:23:15 AM
color0
Status: offline
2WDrifter, Xmods are still crap, unless you upgrade the electronics to something proper. Even an Iwaver board, or preferrably a Mini-Z board will do.
I'm still working on my MR02, the setup goes as follows now:
Front tires: drift, sanded down, adapted to Square inch-ups
Rear tires: GPM 55
Wheels: Square inch-up for MR02
Front spring: Atomic disk damper spring, red (medium)
Rear t-plate: 3racing medium
Rear damper: Atomic disk damper, duralube, green (soft) springs both sides
Differential: GPM 12 ball
Motor: hybrid, uses Hyper dash 2 armature
I'm taking short video clips each run, so that I might have a long, well-edited video to show you guys by the time school starts. I can keep the tail out at 40 degrees or more, for 10 feet or more, so I know I can do this. If I had more space to run, I'd bring out the mod car and go 20 feet each drift; but right now the mod car's useless.
Greyscale Racing
       Post #: 81
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/21/2006 6:34:30 PM
2WDrifter
Status: offline
they make lots of aftermarket electronics packages for those things. just go to www.atomicmods.com
(in reply to color0)
       Post #: 82
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/21/2006 9:54:37 PM
color0
Status: offline
Which shows you've never had one... Xmods have 32 steering steps (vs. 512 in a proper system) and 5 functional throttle steps. Completely useless for good drifting. You need hobby-grade electronics from the get go to make an Xmod a decent RC. You probably should get a Mini-Z AWD if you're into 1/28 scale drifting.
Greyscale Racing
       Post #: 83
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/22/2006 5:55:53 PM
2WDrifter
Status: offline
the board upgrades will make transitions on the steering and throttle smoother and anyway, i drive on full throttle and full steering(tapping the controls of course)
< Message edited by 2WDrifter -- 7/22/2006 5:56:55 PM >
       Post #: 84
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/23/2006 7:36:20 AM
color0
Status: offline
2WDrifter, you just won't understand until you get one. That crap from Atomicmods is only good for hotter motors and power, and wasting cash on larger wires. It doesn't help throttle smoothness, nor steering smoothness.
And if you drive full throttle and full steering all the time, you're not going to get anywhere with drifting. Sorry if I came across harsh, but there are just certain things that won't work in RC'ing. And certain things (like Atomicmods) that you shouldn't waste your time and money with.
Listen to the guy above me and get the $90 TT01... by the time you get an Xmod capable of precise drifting, it'll cost you over $100.
Greyscale Racing
       Post #: 85
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/23/2006 7:40:12 AM
em x 6 racer
Status: offline
Color0 I can drift at full throttle with my 1/10 scale tt-01d. Sorry if you meant a smaller scale than that. But it is possible bud. I have a vid to prove it.
       Post #: 86
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/24/2006 4:19:00 PM
2WDrifter
Status: offline
i dont hold the throttle on full ALL the time. i constantly blip the throttle to full during a turn.
(in reply to em x 6 racer)
       Post #: 87
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/24/2006 10:22:45 PM
color0
Status: offline
emx6, I meant at 1/28 scale. It's near-impossible to get the line right with an Xmod (which I've been drifting for 2 years+) if you pull full-throttle 100% of the time. It's definitely not efficient, though that's not exactly what most people look for.
All I really needed to know was that you guys blip/modulate the throttle at some point during the turn; but I can guarantee (unfortunately) that it's nowhere compared to the work one has to do with an RWD drift.
Greyscale Racing
       Post #: 88
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 7/24/2006 10:25:17 PM
em x 6 racer
Status: offline
Thats what I figured just wanted to make sure.
       Post #: 89
RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE????? - 10/19/2006 11:19:08 PM
adam-69
