Lunchboxer
MA, USA Status: online
quote:
ORIGINAL: JFACKY Lunchboxer, I wasn't suggesting that you eleminate the rest of the cooling devices, just add to the cooling by turning around the mount if it was possible. But as you said it is not. Understood.. I didn't mean that you suggested to get rid of the heatsink! It is not an ideal setup, i.e., using a 27T sport tune motor (27T = torque) and pull the optional high speed gearset.. as you are asking a lot from the motor, and it generates heat and shorten the runtime, so I wasn't sure why Tamiya offers this high speed gearset (I thought I'd try it out, it was like $8).. but I guess it is a "cheap" way of getting a pretty decent top speed out of the kit without going into mod motors.. If I put in a higher power motor in it, I'd change back to the stock spur/pinion combination, which is actually more geared for a 13 to 19T motor.. (that's what an article on Tamiya USA's website said..) Interesting...
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
