RE: DZY Engines
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: DZY Engines
Page: <<   < prev  1 [2]
Login
RE: DZY Engines - 3/15/2008 11:27:55 PM
tater1
Status: offline
Ahhhhh Sucess,found a leaky gasket on one cylinder,cleaned the carb,we checked the plugs it appeared that one cyl was running lean,tried partial choke and the engine ran at full throttle,after shutdown I then left the choke full open and the engine ran at full throttle,maybe a partial blockage in the carb that cleared itself,now both exhaust are normal and not just smoky on one side.anyway it seems to be running like a champ,now to maiden the bipe.
(in reply to rbearden56)
       Post #: 26
RE: DZY Engines - 3/16/2008 3:03:23 AM
PlaneKrazee
Status: offline
quote:
ORIGINAL: tater1
good to hear of your success with this twin,I bought one too,and nothing but problems getting it to run ,I set the needle valve2 turns each,finally started but seems to heat up and quit.then runs for awhile at somewhat idle speed when I try to advance throttle it sags and then seems to run out of fuel.I have tried needle valve settings as per the manual,no joy,checked all fittings for air leaks,all seems good.I also have a dl50 and it runs like a clock.I don,t know
Do you have a tach and can you get to the fuel line while it's running to pinch the fuel line like a glow engine to see if it is rich or lean? It does work. You may find the carb hign speed jet is plugged. If it runs ok up to 4000 rpm sags and quits the high speed jet isn't passing fuel. This was a problem with some of the first DL50 engines.
_____________________________
KB1DTB
AMA11123
(in reply to tater1)
       Post #: 27
RE: DZY Engines - 3/19/2008 9:20:02 PM
PlaneKrazee
Status: offline
For those who bought this engine new, was it run before you received it? Did it come with the velocity stack? Were the tops of the pistons discolored from running or exterior of mufflers stained with oil around the mounting screw lugs?
KB1DTB
AMA11123
(in reply to PlaneKrazee)
       Post #: 28
RE: DZY Engines - 3/29/2008 4:30:24 PM
qldviking
Status: offline
Hi I have one of these dzy48's, looks nice and run well on the stand. fired right up after priming and 3 flips. only gripe I have is the mounting lugs are weak, I broke one when it dropped on my lawn from 22inchs of my bench. otherwise after 3/4 gallon it spins a 20x8 bolly prop at 6950. I am making a 1/4 inch plate to bolt on the back of the motor casing using new longer bolts. the bolts on the motor look cheap and nasty so will also replace them. looks to be a good little motor otherwise
think outside the square? what square?
       Post #: 29
RE: DZY Engines - 4/2/2008 1:25:03 AM
PlaneKrazee
Status: offline
quote:
ORIGINAL: qldviking
If the case was machined billet like Andrew Coholic stated in his December 2007 Fly RC review you wouldn't have this problem. Either he got a engineering sample or he can't tell the difference between cast and billet.
When you think about it, why would any manufacturer bead blast a machined billet case?
KB1DTB
AMA11123
(in reply to qldviking)
       Post #: 30
RE: DZY Engines - 7/24/2008 1:43:32 AM
WILDGAS
Status: offline
quote:
ORIGINAL: rcdude7
Walt, that's great to hear beacause I bought a new DZY 48cc twin and having a source for parts is always a concern of mine.
I have not yet run the engine, it is mounted on my GP 1/3 pitts ARF waiting for nice weather and calm winds.
RCDUDE7, Do you have more pictures of your Pitts with this 50cc twin? I would like to know How can It see with cowling
Thanks a lot, Carlos
(in reply to rcdude7)
       Post #: 31
RE: DZY Engines - 7/24/2008 7:25:07 PM
walt892
Status: offline
Mine is down for faulty ignition unit. Flew the Pitts 3 times.... flew nice then motor crapped pout.
Lousy compression but still hand starts. Wonder why???
Are you the person who got rings made from Bowman's Rings??
walt
respond to makenewagain@yahoo.com
(in reply to WILDGAS)
       Post #: 32
RE: DZY Engines - 7/27/2008 1:04:47 AM
rctom
Status: offline
I can tell you this much. THe DZY-100 twin is an absolute jewel.
I bought one to see if it was any good. Bolted it on a plane and went flying with it, I haven't had to do a thing to it. It starts in a few flips, idles very smoothly and reliably, spins up a 27-10 with plenty of power to haul around a 28 lb. Extra with unlimited vertical.
I have about 30 flights and well over 5 hours running time on it and it has never missed a beat, its performance is the equal of a DA-100 at half the price.
Now, not all DZY's are like this, the smaller ones seem to be less complete, but this 100 is a real peach.
TF
(in reply to walt892)
       Post #: 33
RE: DZY Engines - 7/27/2008 8:29:18 PM
PlaneKrazee
Status: offline
Frank Bowman made me a set of rings but I haven't run the engine yet.
KB1DTB
AMA11123
(in reply to rctom)
       Post #: 34
RE: DZY Engines - 8/3/2008 4:36:44 PM
jrjohn
Status: offline
quote:
ORIGINAL: rctom
TF
Tom, how about getting some information out on this engine. Weight, Power, RPMs , pictures, ect.... I've heard that DZY builds some awsome twins.
If we all think and say the same things, only one of us is necesary.
(in reply to rctom)
       Post #: 35
RE: DZY Engines - 8/3/2008 7:30:42 PM
rctom
Status: offline
quote:
ORIGINAL: jrjohn
OK here you go.
The weight including prop bolts and washer, carb and spark plugs installed is 5 lb. 11.5 oz. on my digital postal scale. The ignition is another 3.5 oz. putting te all up weight without mufflers at 5 lbs. 15 oz.
The mufflers that come with the engine weigh 4 oz. each.
I am offering the engine with an upgrade to the carb, shown, with good arms. This alone will save an hour or two of fooling around trying to hook up throttle and choke to servos. The upgrade will be installed free on the first few engines I sell.
On mine I measured the power in the first couple minutes of running time, it was turning 6300 rpm fresh out of the box but I don't recall what size prop I was using, it was a bunny prop, not a Vess. Flying, the engine hauls around a 28 lb. plane with authority, I was using a 27-10 something else and it flew great.
I has canisters on mine, 2x KS86-4. These seemed to stifle power slightly, it made more power on the stock mufflers. But they are so quiet I loved them and it still had plenty for any type of flying.
The DZY-100 is remarkably smooth, I'd have to say it's the smoothest engine at both idle and at full power that I have used.
Some of the photos shows the very nice cast case, which appears to be the only significant deviation from a straight DA-100 copy.
TF
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to jrjohn)
       Post #: 36
RE: DZY Engines - 8/4/2008 3:29:55 PM
Mitsu1
Status: offline
Tom, is the DZY 100 prop hub bolt pattern the same as the DA 100? I ask because there are some Chinese twins coming with a prop bolt pattern that's different from anything else, and this makes prop sharing with your other engines impossible and causes you to have to buy new props.
(in reply to rctom)
       Post #: 37
RE: DZY Engines - 8/4/2008 5:19:53 PM
rctom
Status: offline
quote:
ORIGINAL: Mitsu1
I'm glad you asked.
The standard DZY has a prop bolt circle that is about 1mm larger diameter than a DA-100. It's so close it looks like it's the same but the props won't bolt up without enlarging the holes. This is one of the things that had held up my decision to sell the engines, I knew this would be a problem.
DZY has agreed to change this for me. I have sent them a prop drill jig with instructions to make a hub that will fit it. They promised that they will be sending me new hubs for the engines that I have in stock and the one that I have sold, they say it should be ready in a few weeks.
I will provide the replacement hub to anyone who buys an engine, and a free 26-B prop to use for break-in so you don't have to spend money on a prop that can't be used on any other engine.
TF
(in reply to Mitsu1)
       Post #: 38
RE: DZY Engines - 8/4/2008 5:50:18 PM
Mitsu1
