RC-Bearings
AZ, USA Status: offline
Perhaps you haven't paid attention to my earlier posts. I was involved with GMS when the 46 and 47 were first imported. The 46 and 47 are both made by GMS but they are not the same engine with a different bore. The head on the 46 used to be a cast design and was only changed when Tower started importing them. The porting on both engines is different with the 46 biased more towards high RPM power whereas the 47 will turn larger props more reliably in the midranges. The original GMS 46 would turn an APC 10X6 at well over 15k on 10% fuel. It would do this all day long with no tuning problems. As soon as Tower put the remote needle valve on it, the problems started. If you put the standard GMS carb on your Tower engine, you would eliminate the leaning problems. I did this on a couple of them. quote:
ORIGINAL: opjose The GMS engine is a slightly larger bored unit so it is understandable that it would have slightly higher power output. That said I was looking at one at the LHS with my own TH .46 in hand. The carb, muffler, body, head, etc. were both otherwise identical. Even the serialization stamping uses the same digit sequence and font. This is not a co-incidence. I'll bet that GMS merely produces them for Tower, and Tower merely repackages them in their own boxes. They are so close that calling the TH version inferior would be tantamont to also calling the GMS one the same. While the GMS outputs more power, I'll bet it has EXACTLY the same tuning "issue". I just MAY have to purchase one to check it out... Though I would not call it a tunning issue, as most engines have the same problem, including my O.S.'s, and this board is repleat with posts reaffirming this. It's a flow problem that could be solved by increased pressurization or a pump.
_____________________________
Steel and Ceramic bearings for model engines http://www.rc-bearings.com
