bob27s
OH, USA Status: offline
The tower .46 engines are good, well designed powerplants. Your problem here - TOO much prop. The engines have to be allowed to turn up. They have a larger carb, and some agressive porting and timing. Break them in on a 9x6 on the bench. At least 15 minutes. Take them up near peak rpm, then back-off about 1000 rpm. Then move on to a 10x6. Run again at least 10 minutes. Find peak rpm, back off around 600. Get the run time on them under controlled conditions. At the middle of that last tank of fuel, take the time to make final adjustments to the low speed mixture so you get smooth transition and a good idle. Then move on to installing it in the plane. Prop selection - 9x7, 9x8, 10x6. The 10x7 is a good prop, but my experience is that it tends to be a bit too much load for the Tower 46 engine, especially when new. You can run more prop on it, but by virute of your post where you are having some issues, start of with the smaller prop. The engines have to turn up over 14,000 peak rpm at full throttle to run properly. This by virtue of the semi-tuned muffler. It provides a bit of boost up around 14,500 to 16,000 rpm. Select a prop that allows the engine to run above 14,500 peak ground rpm, set the high end needle so it is back-off around 600 rpm from that, and it runs like a champ. The engine needs a hot plug. The OS 8 is too cold. K&B 1-L , McCoy56, and even the 4-cycle plugs work well (why the mirical plug tends to work ok too). I hope this is helpful Bob
_____________________________
Bob Brassell Jett Engineering - Engine Mfg Support Forum Host
