RE: Skyshark 82" P40 Buildup
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Skyshark 82" P40 Buildup
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Skyshark 82" P40 Buildup - 6/23/2006 8:24:27 PM
Hellcat716
Status: offline
I would just cut the balsa out and glue 1/4" thick plywood strip into the aileron and then screw the control horn into the the plywood. I have used this procedure many times with no problems.
< Message edited by Hellcat716 -- 6/23/2006 8:25:03 PM >
(in reply to pettit)
       Post #: 26
RE: Skyshark 82" P40 Buildup - 6/24/2006 5:05:44 PM
MK_IX
Status: offline
Just installed the right aileron servo utilizing an aluminum servo mount manufactured by Sierra and distributed through Skyshark (also directly through Sierra). As you can see in the attached photo, I attached the aluminum servo mount directly to the aileron servo hatch cover. Note: Since the aluminum mount is the same width as the hatch cover, you will need to removing a portion of the inner lip on two sides of the hatch opening. I like the idea of the aluminum mounts vs using wooden blocks to mount the servos. I plan on installing them for both aileron and flap servos.
Click to see fullsize image.
Click for fullsize
(in reply to MK_IX)
       Post #: 27
RE: Skyshark 82" P40 Buildup - 6/24/2006 10:06:40 PM
jeffk464
Status: offline
Wow, thats a nice looking servo mount.
(in reply to MK_IX)
       Post #: 28
RE: Skyshark 82" P40 Buildup - 6/25/2006 3:29:43 AM
Thunderbolt47
Status: offline
Hey Dick, where are all the little elves at that build your planes for you. You are a busy man. let me know when you test fly her.
_____________________________
"Over Macho Grande Sir".... "Oh no, I''ll never get over Macho Grande"
(in reply to jeffk464)
       Post #: 29
RE: Skyshark 82" P40 Buildup - 6/26/2006 11:43:35 AM
pettit
Status: offline
Those little elves are out somewhere sawing and filing away on some metal parts that will someday turn into the Revolution 50 engine.
I have the wing just about complete, the Sierra retracts are mounted and working. All I need is some 1/4" wheel collars to keep the Sierra wheels in place.
It'll be a few weeks before even thinking about flying. Maybe by then, this rain will stop!
< Message edited by pettit -- 6/29/2006 2:58:51 PM >
Dick Pettit
Associate Editor, R/C REPORT Magazine
"You Can Buy Better,
But You Can't Pay More"
(in reply to Thunderbolt47)
       Post #: 30
RE: Skyshark 82" P40 Buildup - 6/29/2006 2:57:13 PM
pettit
Status: offline
Another news flash! Tailwheel retract mounted, tail servos are in place and total weight minus engine and fuel system is just under 14 pounds.
Here's some Photos!!!
Click for fullsize
Click for fullsize
Dick Pettit
       Post #: 31
RE: Skyshark 82" P40 Buildup - 6/29/2006 4:57:02 PM
Kmot
Status: offline
Finally, a warbird ARF with proper sized wheels/tires!
Ahhh......screw it!
       Post #: 32
RE: Skyshark 82" P40 Buildup - 6/29/2006 5:15:56 PM
pettit
Status: offline
I agree about the wheel size, but not shown are the neat "moon disk" hubcaps that are included with the Sierra wheels.
Dick Pettit
(in reply to Kmot)
       Post #: 33
RE: Skyshark 82" P40 Buildup - 6/30/2006 1:04:55 PM
AirplaneMan04
Status: online
Pettit, that bird is sreaming for a paint job.... do u plan on repainting it
or doing any scale work like full cockpit, pilot, sliding canopy or anything?
       Post #: 34
RE: Skyshark 82" P40 Buildup - 6/30/2006 1:10:13 PM
pettit
Status: offline
Nope. I build these models as the manufacturer designed them, not as I would design them.
That's the only way for me to write an honest product review.
As for a "paint job", according to a book about P-40's flown by the Chinese Air Force (this one was one of them), the green paint with blue striped tail and blue/white Chinese insignia (not applied yet) are 100% scale.
I guess that weathering could be applied, but not by me.
Here's that artist rendition of the full scale plane. Looks mighty "clean and green" to me...
Click for fullsize
< Message edited by pettit -- 6/30/2006 2:46:01 PM >
Dick Pettit
(in reply to AirplaneMan04)
       Post #: 35
RE: Skyshark 82" P40 Buildup - 7/31/2006 1:04:32 PM
pettit
Status: offline
First test flights on Skyshark P-40N. Revolution 50 with APC 22-8 provides plenty of power. Fully aerobatic, military style.
22 pounds, 43 oz/sq ft loading, but don't worry about those numbers. Very stable at high or low speeds
Takes off in about 200 feet on grass, unless you forget to hold full up elevator!
Flaps work like throwing out an anchor. Lands great, slowly and under 100% control
Here's some photos:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Dick Pettit
       Post #: 36
RE: Skyshark 82" P40 Buildup - 8/3/2006 9:32:35 PM
cadconversions
Status: offline
Great looking bird, guess it flies as good as it looks.
Kevin
       Post #: 37
RE: Skyshark 82" P40 Buildup - 8/5/2006 3:12:31 AM
Hellcat716
Status: offline
How are the flying charachteristics compared to the Hangar 9 P-47 ARF?
       Post #: 38
RE: Skyshark 82" P40 Buildup - 8/6/2006 3:02:42 AM
Meschmidt
Status: offline
Mr. Pettit, glad to hear she's an exellent flyer as I figured it would be. Finally been able to do some work on mine. Strengthened the motor box and made spacer to achieve the 9 1/4" firewall to spinner backplate length for the BME 50. Installed flap and aileron servos, joined wing together and installed belly pan. Filled bellypan with expanding foam to help prevent collapsing on gear up landing. the Sierra retracts are a work of art and look to be plenty tough. Made a pull-pull tailwheel as I did not want to fool with a retract tailwheel. I repainted the plane with Behr flat latex "groundcover". Did some weathering and panel lines on bottom of wing and fuselage. The markings are not correct for the "N" model but decided on this of the many P40 schemes. Spinner will be same color as plane. Hope to have a few flights before the Bomber Field meet in mid September. Also a picture of a real P40 with same color scheme. Paul
