RE: Skyshark 82" P40 Buildup
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Skyshark 82" P40 Buildup
Page: <<   < prev  1 2 3 4 [5]
Login
RE: Skyshark 82" P40 Buildup - 3/16/2007 3:37:41 AM
kurt969
Status: offline
oh man would I
that would be great
did you find any other pics. or drawings, documentation
for this p40. I found that same profile a couple years ago but havent
been able to learn anything about it or its squadrin.
email: kurtsmail@charter.net
thanks
(in reply to fockewulf37)
       Post #: 101
RE: Skyshark 82" P40 Buildup - 3/16/2007 12:56:40 PM
fockewulf37
Status: offline
Here is a neat picture that shows the wheel of the P-40. Not the usual cover. The Dubro Wheels can be painted to look like this....
Ty
Click to see fullsize image.
Click for fullsize
_____________________________
http://fockewulf37.googlepages.com/ty%27splanes
(in reply to kurt969)
       Post #: 102
RE: Skyshark 82" P40 Buildup - 5/12/2007 5:07:09 AM
kochj
Status: offline
I can't say that the p-40 wan't a fav plane of mine untill I saw a yellow aircraft all done up. then I saw this p-40 and I will sya that I liked this one as well.
If I bought the Economy Pricing p-40 from shyshark, what else would I need? It just seems that you end up paying 350$ more for some control rods, control horns, and a 150$ spinner?
I have put the TF p-51 ARF together. Would I need the wood blocks and such for the servos , if I got the budget version of this plane?
Anyone help?
Justin
Winning isn''t everything, it''s all there is.
       Post #: 103
RE: Skyshark 82" P40 Buildup - 5/12/2007 7:44:53 AM
fockewulf37
Status: offline
Justin,
Go to this link and make an offer of $400. They will usually accept this offer for the full kit. I paid $400 plus shipping for mine. Its really a great deal on this plane. Its a great kit and the plane flies really well....So don't buy the economy kit its not worth it.....
http://cgi.ebay.com/82-P-40N-ARF-by-Skyshark-R-C-50cc_W0QQitemZ280021591831QQihZ018QQcategoryZ19164QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Ty
(in reply to kochj)
       Post #: 104
RE: Skyshark 82" P40 Buildup - 5/12/2007 9:41:23 PM
kochj
Status: offline
Thank you much.
i just don't understand how there is such a price increase between the regular and the budget.
I think I should at least phone them and ask. Honestly, I am not goingto pay 780$ for this plane alone. I just have too many planes to warrent that amount. For 400$ I would buy it, as that seems more resonable. > Heck I can purchase a KMP TigerCat w/retracts, or the KMP Adam aircraft 500 for 800$ and they come with very nice air retracts. These are also complete fiberglass surfaces... These planes will fly on a .90 4-stroke or a G26 cc engine, not a 50-75cc. You see where you start to add things up, if you would purchase the 780$ for this plane. Not to mention the 800$ for the sierra retracts.... wow.
These are just some of the things I have began to think about when I thought about buying this plane. Not that I don't like the plane by any sorts, but one has to be thrifty when you start to add up all the aircrafts you have in you hangar.
Justin
       Post #: 105
RE: Skyshark 82" P40 Buildup - 12/21/2007 1:29:13 AM
n9331v
Status: offline
I am working on one of these P40's for a friend. Can anyone give me an idea how the tail wheel retract pull pull system is set up pictures etc. With the Rev 50 have you guys installed the servos in the tail or not.
Mooney N9331V
(in reply to kochj)
       Post #: 106
RE: Skyshark 82" P40 Buildup - 12/21/2007 1:56:08 AM
fockewulf37
Status: offline
ask and you shall recieve.....
I hooked this all to one servo....
Ty
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to n9331v)
       Post #: 107
RE: Skyshark 82" P40 Buildup - 12/21/2007 2:05:38 AM
Kirk RC
Status: offline
Per FW thread I also put all my servos in the mid fus and not in the tail. For some reason SS/Mike likes to do this but in both the P-40 and Cristian Eagle putting them in the tail resulted in much needed nose wt so whats the point?? Maybe as an ARF its easier for most people to just plop them in the tail and not mess with cables and push rods.
       Post #: 108
RE: Skyshark 82" P40 Buildup - 12/21/2007 2:12:01 AM
n9331v
Status: offline
WOOOWWWW that was some fast replies. The pictures sure do help and I will go ahead and mount the servos in the mid section as yours. I am using the century gear and noticed the tail wheel sits pretty much straight down unlike my TFP 51 that is more raked. Do you guys think it would help to add more angle to the tail wheel or does it taxi fine as is.
Thanks again
Mooney N9331V
(in reply to Kirk RC)
       Post #: 109
RE: Skyshark 82" P40 Buildup - 12/21/2007 2:36:03 AM
Kirk RC
Status: offline
I took 1/4 inch off the strut of my Sierra tailwheel and also bent it back.As it came the plane was way to flat on the ground and would of nosed over easier then is already does.
       Post #: 110
RE: Skyshark 82" P40 Buildup - 12/21/2007 2:37:10 AM
fockewulf37
Status: offline
you should put some angle on it...It does tend to bounce alot with the stock set up...This wa a problem with the real plane I have read too...
ty
       Post #: 111
RE: Skyshark 82" P40 Buildup - 12/21/2007 2:42:08 AM
fockewulf37
Status: offline
I also did a complete build on this plane that has most all of my pic's...
http://www.rcuniverse.com/forum/m_5241580/anchors_5241580/mpage_1/key_/anchor/tm.htm#5241580
ty
       Post #: 112
RE: Skyshark 82" P40 Buildup - 12/21/2007 3:28:19 AM
n9331v
Status: offline
I will go ahead and modify the tail wheel. I will also check out the build thread.
Mooney N9331V
       Post #: 113
RE: Skyshark 82" P40 Buildup - 12/22/2007 4:06:15 AM
kennyh345
Status: offline
this is a great flying plane mine has a g62 and it screams your going to love it, flying is very predictable but the control surfaces are touchy. someone tell me how to upload pics and I'll post my finished bird
       Post #: 114
RE: Skyshark 82" P40 Buildup - 12/22/2007 5:04:56 PM
aghost
