ok mindcrime ill try again ok my two speed is not working
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> IRC Racing Support >> ok mindcrime ill try again ok my two speed is not working
Page: [1]
Login
ok mindcrime ill try again ok my two speed is not working - 6/16/2006 8:32:51 AM
rcworld2000com
Status: offline
ok mindcrime
i have tried the tightening the set screw
i have used lock tite
and i have even emailed surport
and i have aksed for help !!
so what do you know that i am not doing or doing wrong
       Post #: 1
RE: ok mindcrime ill try again ok my two speed is not w... - 6/16/2006 3:37:00 PM
huw4027
Status: offline
I am glad to see that you are changing your response and sincerely hope that you will get the support that you need to rectify your problem.
_____________________________
R/C IS GOOD, CLEAN FUN !!! - Too much to list !!
1/18,1/16,1/10,1/8 & 1/5 scales-nitro,gas & electric.
(in reply to rcworld2000com)
       Post #: 2
RE: ok mindcrime ill try again ok my two speed is not w... - 6/16/2006 4:18:11 PM
Mindcrime
Status: offline
rcworld, you said you have tightened the set screw....did you try to loosen it at all? there are 2 set screws, one that holds the assm to the shaft, the other one is at an angle. and is the adjustment, it should not be screwed in all the way, it will never shift like that...
as far as emailing support and not getting an answer, I appolagize.....we try to answer all emails, but perhaps we missed yours
let me know if you just tightened the set screw or tried adjusting it.....
IRC Racing
(in reply to huw4027)
       Post #: 3
RE: ok mindcrime ill try again ok my two speed is not w... - 6/16/2006 4:37:35 PM
rcworld2000com
Status: offline
yes i have tried tighting the set screw i moved it in a little maybe a 1/18 turn at a time then would run buggy again. eventullay the screw stop going in so i then moved it out a few times still no shift.. at atleast one i cant hear i would think i would be able to hear it like others yes?
and the screw i am moving in and out is the second screw the one at angle..
thanks for the help.
       Post #: 4
RE: ok mindcrime ill try again ok my two speed is not w... - 6/16/2006 5:23:46 PM
Mindcrime
Status: offline
rcworld, moving it out will make it shift sooner....if you try it again and it still won't shift PM me and we will figure it out...thanks
and yes you should be able to hear it shift
< Message edited by Mindcrime -- 6/16/2006 5:24:11 PM >
IRC Racing
       Post #: 5
RE: ok mindcrime ill try again ok my two speed is not w... - 6/16/2006 7:26:13 PM
rcworld2000com
Status: offline
no shift so i will pm yo u
       Post #: 6
RE: ok mindcrime ill try again ok my two speed is not w... - 6/16/2006 7:35:59 PM
huw4027
Status: offline
That is how problems are solved, all the best guys.
       Post #: 7
RE: ok mindcrime ill try again ok my two speed is not w... - 6/16/2006 10:27:51 PM
rcworld2000com
Status: offline
me and mindcrime are working on the problem.
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU1
