RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Page: <<   < prev  43 44 45 46 47 48 49 50 [51] 52   next >   >>
Login
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/11/2012 2:11 AM
Canuck1
Score: 100
Last Login: 5/15/2013
Status: offline
Thanks Ray.
I need a steadier hand with my pictures
Craig
_____________________________
Eat, Sleep, Fly
Hide Signatures
(in reply to dnomyar253)
       Post #: 1251
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/11/2012 2:55 AM
Canuck1
Score: 100
Status: offline
Did some cleaning up of the lettering on the fuselage, both the Port and Starboard side.
Craig
Click to see fullsize image.
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to Canuck1)
       Post #: 1252
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/11/2012 3:12 AM
valleyk
Score: 101
Last Login: 5/14/2013
Status: offline
Craig looks great. Where did you get those small eyelets. Could use some for my pup.
Hide Signatures
       Post #: 1253
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/11/2012 3:18 AM
Canuck1
Score: 100
Status: offline
Picked the eyelets up at Michaels craft store.
They are 1/8 dia, perfect for this scale.
Craig
Eat, Sleep, Fly
Hide Signatures
(in reply to valleyk)
       Post #: 1254
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/11/2012 3:53 AM
Canuck1
Score: 100
Status: offline
Currently working on the seat belt adjustment before I secure the belts, and seat.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1255
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/19/2012 4:17 AM
Canuck1
Score: 100
Status: offline
Finally finished up painting of the ailerons.
Painting is now complete
Craig
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1256
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/19/2012 1:38 PM
geezeraviation
Score: 110
Last Login: 4/29/2013
Status: offline
Completing the painting always leads to a deep sigh doesnt it? A major step, its looking real fine Craig.
Doc
Happy landings, Doc Hou Tx
The second rule of modeling is there is no such thing as an insignificant savings in weight
Hide Signatures
       Post #: 1257
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/19/2012 3:06 PM
axialair
Score: 100
Last Login: 9/23/2012
Status: offline
This is a magnificent construction, I like so much your work and your attention to bring all particulars so close tothe real thing.
I hope you'll enjoy soon the first flight with this fantastic model.
Alessandro
Hide Signatures
(in reply to geezeraviation)
       Post #: 1258
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/19/2012 3:08 PM
axialair
Score: 100
Status: offline
Alessandro
Hide Signatures
(in reply to axialair)
       Post #: 1259
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/19/2012 11:40 PM
WacoNut
Score: 175
Last Login: 5/20/2013
Status: offline
Craig,
She is looking really good. Can't wait to hear the maiden report.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 1260
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/20/2012 4:24 AM
Canuck1
Score: 100
Status: offline
Thanks guys.
Maiden will to be for a while, due to winter, as well as I am just beginning to start the assembly.
Then there will be the standard running in the garage to check everything out, rpm, nuts, bolts, linkages. I am pretty particular to go over everything well before hand.
I have my Locktite list made up, so nothing is left undone.
Still have some small things to do, but getting close.
Craig
Eat, Sleep, Fly
Hide Signatures
(in reply to WacoNut)
       Post #: 1261
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/20/2012 2:01 PM
dnomyar253
Score: 100
Last Login: 12/6/2012
Status: offline
Graig,
I was looking at the slide show yesterday on this thread and saw a few things you did that I really liked and will be doing on my 1/4 scale DR 1
You have done a great job on your DR 1 keep up the great work. O yes your pictures are great also.
Ray
Hide Signatures
       Post #: 1262
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/30/2012 11:58 PM
Canuck1
Score: 100
Status: offline
Thanks Ray
She is pretty much done, for now, balance seems good, still need to confirm weight, think I am around 35 lbs.
Just need some good weather, and some steady nerves.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1263
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/31/2012 12:39 AM
WacoNut
Score: 175
Status: offline
Congrats on the fine build Craig, can't wait to hear how the maiden goes.
Later!!
Anthony
Hide Signatures
       Post #: 1264
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/31/2012 12:43 AM
valleyk
Score: 101
Status: offline
If your GTM dr1 flys like mine then:
Gradually add throttle with elevator in neutral position. Once tail comes up the torque will swing her slightly left. Correct with right rudder and slowly feed in up elevator not too fast because this bird wants to jump into the air.
Once airborne turn with rudder and aileron. I personally don’t like to mix them. I had other people fly her and they all say how well and realist she fly’s. Stalls are gradual at very low speeds so pretty stable up there.
The landing approach is the hard part. If you plan to flare out early and touch down on skid and gear you will lose directional control almost immediately. I like to come in slightly nose down and flare out just before wheels touch. Land on the main gear with tail up then cut throttle with full up elevator and grind that skid into the ground to slow down. Pray your wing skids don’t get bent.
Hide Signatures
       Post #: 1265
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/31/2012 1:15 AM
Canuck1
Score: 100
Status: offline
Thanks valleyk
I remember the same issues with my Zeroli DR1. Combination of throttle, elevator and rudder. You have to fly it on the ground for sure and it should lift off pretty quick.
Landings are always fun, three pointing it is not an option as far as I am concerned. I will want to land on the mains, and do a good controlled roll out. And as you say, once the tail is down, control is lost.
I always have my controls separate, not keen on mixing the two together.
So over all you found it a pretty good flier? I think with the under cambered wings, and the positive incidence it should lift of pretty quick.
Looking forward to the first flight, and I think it will fly pretty nice, and look good up there.
Craig
Eat, Sleep, Fly
Hide Signatures
       Post #: 1266
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 3/31/2012 1:31 AM
valleyk
Score: 101
Status: offline
One other thing Craig,
Before I maidened mine I spoke with vertical grimace and he adviced me to get more positive incidence on the elevator. I put a few washers on the two front elevator mounting scews to prop up the elevator to give an additional 1 deg positive incidence. I'm glad i did that becouse I still had to trim down elevator when flying. Also I had 2.5 degree right thrust and 2.5 degree down thrust on the engine.
35 lbs sounds like alot of weight but there is so much wing area you'll be flying probably a little above half throttle with G62. Mine flys at a quarter throttle with da 100. Just forget about the wieght believe me.
Hide Signatures
       Post #: 1267
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 5/8/2012 5:02 AM
Canuck1
Score: 100
Status: offline
Good news.
Maiden complete, was an awesome flight, she just purred along with the g-62, 26 x 8 zinger prop.
Like you said Valleyk, lots of down elevator needed to trim it to level flight.
The washers are a good idea, just for that extra degree.
Once I had it trimmed out, it just flew real nice, and looks so good in the air.
No pictures unfortunately. Only issue I had was the bracing wire on the inner struts loosened a bit, could hear the noise after about 15 minutes so I landed.
Landed real nice almost by itself, a click of extra power, and she settled right in, so I am pretty happy
Take off was okay, once you add power you need to keep the power on, and increase it, if you reduce the power she will take on a whole new life of its own, no issues once it is rolling and tracking, the rotation is very smooth.
Did a low power stall into the wind, just increased the angle of attack, reduced power and it just mushed nose down, wings level.
Craig.
Eat, Sleep, Fly
Hide Signatures
       Post #: 1268
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 5/8/2012 5:51 AM
abufletcher
Score: 1576
Status: offline
Congratulations on a successful maiden of a wonderful model! (I'd give you several thumbs up emoticons but those haven't worked on RCU in over a year). Well done!
Hide Signatures
       Post #: 1269
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 5/10/2012 4:43 AM
dm8221
Score: 100
Last Login: 5/4/2013
Status: offline
Hi Craig
Sent you a PM
Cheers Don
Hide Signatures
(in reply to abufletcher)
       Post #: 1270
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 5/10/2012 5:21 AM
Canuck1
Score: 100
Status: offline
Hello Don
I plan on going out Sunday, sent you a pm.
Craig
Eat, Sleep, Fly
Hide Signatures
(in reply to dm8221)
       Post #: 1271
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 5/10/2012 11:58 AM
WacoNut
Score: 175
Status: offline
Congrats on the maiden.
I am still trying to figure out the landing on my 1/4 scale, I keep it on it's wheel but I am being really hard on the tail skid as I have broken the mounting loose twice. I have it reinforced good for the 3rd try.
Later!!
Anthony
Hide Signatures
       Post #: 1272
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 5/16/2012 3:38 AM
valleyk
Score: 101
Status: offline
Glad to here all went well. Its fun to give advice here when you have the same model. I haven't  flown mine in over 6 months because I keep thinking I should upgrade to the new life a123 batteries. NIMH batteries shelf life is not too good for my lack of flying. I wish we had a nice grass field here in colorado instead of a wide paved runway. Its really an easy plane to land in grass but almost impossible on the pavement due to long uncontrolled roll outs ending up into a ground loop and scraping up the lower wings. Hope you make a video would love to see her in the air.
I happen to see the maiden flight of the 1/3 busa dr1 in this forum and was not impressed at all looked sluggish.
Hide Signatures
       Post #: 1273
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 5/16/2012 4:41 AM
Canuck1
Score: 100
Status: offline
Valleyk
Every time I go to the field the winds are pretty strong, so I am still waiting on my second flight.
The grass did make the roll out pretty short, about 10 to 12 feet, well that's what it looked like.
I thought the BALSA DR 1 looked pretty good, not sure what you mean by sluggish, vertical performance mightbe a little weak but it ooked pretty scale to me.
Just my 2 cents.
Hope to get some in flight pictures soon.
Craig
Eat, Sleep, Fly
Hide Signatures
       Post #: 1274
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 5/19/2012 1:53 AM
dm8221
Score: 100
Status: offline
Hi Graig
Did a road trip to the bremner field as it was the mothers day weekend my time was limited ,not to mention the wind would not help in your attempts to fly. Hope to meet and see your plane fly as the winds don't look good for thew long weekend.
Cheers Don
Hide Signatures
       Post #: 1275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
