deljon -> RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along (6/26/2007 11:27 PM)
Thanks 1Bruno, it works out pretty good, just need to safety wire them now, They're 1/3 scale. 1/4 scale would work, not much differance in size. On the full scale all the steel tubing where the covering is stuck to, it is wrapped with strips of material and doped. This gives a better surface for the covering to adhere to. So, for the scale effect I'm doing the same thing only using Nelsons Lite Fab covering. Will have some pictures later. Also working on an engine test stand, going to try to get some run time on the engine this weekend. Del
