RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/22/2006 12:18:11 PM
Babblefish7
Status: offline
Del,
I think you have this thread thing down, It looks great so far with great pic's. I cant wait to see what Glenn will be sending you in parts next. I will be watching and takign notes. Thank you Del and Glenn for sharing this whole process with us.
Mark Petersen
_____________________________
Ok which dot up there is mine?
(in reply to deljon)
       Post #: 26
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/22/2006 7:24:55 PM
bookmaker
Status: offline
Wow, Del,
You have a real humdinger of a project going on. Glenn put it in good hands. Great work so far.
Let's see, how many parts to that kit? Hmmm!
Dale
       Post #: 27
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/22/2006 9:30:43 PM
deljon
Status: offline
Mark and Dale.........Thanks for the comments guys. This is going to be one fun project. I'm having fun already.
I'm planning on going to Rhinebeck this year, so where ever I'm at on the build I will bring it along.
Lee.........I put the rudder assembly on Miss Mary's food scale and it said 1 1/4 ozs. I knew it was light but had no idea it was that light.
Del
(in reply to bookmaker)
       Post #: 28
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/23/2006 12:47:41 PM
Babblefish7
Status: offline
Del,
I cant wait to see how far you will have gotten when you roll into Rhinebeck, try to drag Glenn up this year with ya. Are you going to be keeping a count on all the parts that Glenn is going to send you so you know how many parts are in the kit? Can I get an up close shot of the pins on the hinge to see how held in place and rolled over at the ends? Keep the funn going.
Mark
       Post #: 29
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/23/2006 3:24:24 PM
deljon
Status: offline
The second half of the elev is laminated and dried. It came out great. After looking at the plans closer I decided to set the elev aside and build the stab. Reason being, you need to have the hinge gap determined before you can trim the top part of the elev so that it lines up with the leading edge of the stab.
Mark.........Don't know at this point how many parts will be in the kit as Glenn still has parts to design.
And also it depends on how detailed he wants to get in verious areas. He is keeping track of all the parts he sends me.
Are you talking about the pins that go through the locking collars??
Del
(in reply to Babblefish7)
       Post #: 30
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/23/2006 5:36:30 PM
Babblefish7
Status: offline
Sorry Yes that is what I was referring to.
Mark
       Post #: 31
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/23/2006 8:32:07 PM
deljon
Status: offline
This is as close a shot I could get Mark. You can see both sides of the pin. I slightly mushrooned the pin, but also put a dab of thick CA on it.
       Post #: 32
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/24/2006 2:14:32 PM
jagran
Status: offline
DEL,
Absolutely first class stuff..
I will be watching your progress with great interest and enthusiasm.
Grahame
       Post #: 33
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/26/2006 1:03:32 AM
deljon
Status: offline
Thanks Grahame, good talking to you again on Skype.
Here's most of the stab just tacked together. Since the ribs have a airfoil shape, I spaced everything up off the plans using some 1/4 square stock.(It works for me). Will check everything for squareness then add the leading edge.
Del
(in reply to jagran)
       Post #: 34
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/26/2006 1:29:16 AM
deljon
Status: offline
Here you can see how the spar (5/16 dowel) is passed through the ribs. No cuts or splices. Also you can see a part of the leading edge which is 1/4 dowel.
Here is the almost finished stab, just need to double check all glue joints and a little touch up sanding. It is a very strong structure and weighs a whoping 3 1/2 onces.
Now back to the elevator...............Del
< Message edited by deljon -- 6/26/2006 1:30:33 AM >
       Post #: 35
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/28/2006 1:10:12 AM
deljon
Status: offline
I got both elevator halves all layed up, came out real nice. Next you need to slide all the hinge parts and horns on the 5/16 carbon tube. As with the rudder hinge parts are located and the collars pinned. The control horns will be glued later.
Here's a close up of the center hinge.
       Post #: 36
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/28/2006 1:15:25 AM
deljon
Status: offline
Here's the first half of the elev. mostly tacked up. Again I spaced the parts up off the plans as the parts will not lay flat.
The first balsa lamination is notched out so all the ribs fit nicely.
Del
       Post #: 37
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/28/2006 6:40:48 PM
Lucky Dog
Status: offline
Del,
Really looking nice. I've picked up some great building tips from you even in these first few posts. Keep up the good work!
Cheers,
Mike Bealmear
       Post #: 38
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/28/2006 9:15:02 PM
deljon
Status: offline
Thanks Mike, always happy to help when I can. I've gotten lots of good tips from these building threads, happy to pass them on.
Del
(in reply to Lucky Dog)
       Post #: 39
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 6/29/2006 12:24:32 PM
