deljon
OH, USA Status: offline
Next I cut out some old iron-on fabric I had laying around (not sure which brand). First I ironed the center so the fabric is anchored good the pulled it tight (well somewhat tight), rolled the tire back some and with a dull screw driver (a pop-cycle stick would work good also), pushed the fabric down between the tire and rim probably about 1/4". Took my little heating iron and went all around the rim, then trimmed any excess sticking up. I then used the heat gun to shrink it all. Got some wrinkles around the edge of the rim that wouldn't come out but I'm sure the real one had wrinkles in them too (Thats my story and I'm stick'n to it). Since one row is a tad higher I used the small iron again and made a couple passes up and down the tooth pick then hit it with a cool rag so the lower ones would stay in place. Very happy with the results, gives the illusion of a staggered double row of spokes. If I knew that they would come out so good, I'd taken a little more time with them. For the back I just did the fabric without the toothpicks Del
