RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 7/27/2006 3:47:28 PM
deljon
Status: offline
After I drilled all the holes, I took it back apart to do a little more sanding to smooth out the "turning" marks in the alum. I first used an orbital sander with 150 grit paper, then went over it again with 250 grit. After that I wet sanded it by hand with the 250 grit. It came out pretty smooth, but I think I'll go back over it with 320 grit wet sanding. Probably don't need to but will anyway.
Once I sand it again I'll reassemble using the brass brads, bending them over and lightly tapping them down. You can then clip off some of the excess if you like, then use some epoxie and go over the back side to secure all the "rivets".
(in reply to deljon)
       Post #: 76
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 7/27/2006 10:11:20 PM
bookmaker
Status: offline
I had not thought of using those little bar clamps to hold things together while drilling. I have several and will definitely use them when I get to that stage.
Dale
       Post #: 77
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 7/30/2006 4:23:53 PM
abufletcher
Status: offline
Can someone post the website for Glenn Torrence Models. I always have a heck of a hard time finding it through Google.
       Post #: 78
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 7/30/2006 4:58:05 PM
V2PLUS10
Status: offline
www.flygtm.com
Randy
(in reply to abufletcher)
       Post #: 79
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/2/2006 10:53:51 PM
deljon
Status: offline
Dale.....I use those clamps alot. I have three differant sizes
Ok, back to the cowl, I now have all the "rivets" in, bent and epoxied.
Here it is from the front, I gave the whole thing a good wet sanding with 600 grit paper and it's ready to prime.
(in reply to V2PLUS10)
       Post #: 80
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 9:37:21 PM
jtisch
Status: offline
Del,
Looks great, as usual for you. It looks like the front plate of the cowl extends down a little further than the one that came in my 1/4 scale kit, which is an improvement. Looking at different DRIs that front cowl plate seems have have had different lengths as production went on. It is much easier to cut it down than to add more on.
Would you believe I did all the holes in my cowl with a pin vise? I was living in an apartment at the time and didn't have a drill press or electric drill then. I may not always be the brightest bulb on the X-mas tree!
Can't wait for the fuselage to start! Do you have the plans for it yet? One thing I did on my 1/4th size fuse was to replace all the cross members in the cockpit area with dowel, to better represent tubing. Perhaps you noticed from the photo over at the 'Drome.
Keep up the good work!
J
_____________________________
WWI Aviation T-shirts
       Post #: 81
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 9:55:14 PM
deljon
Status: offline
J.....MAN that is a lot of drill'n with a pin vise. It was worth it though wasn't it??
Yes, I noticed the dowels in the cockpit area. when I get the plans I'm going to do the whole fuse with dowels just as Glenn did with the DVI. It really makes the whole framework look authentic............
Del
(in reply to jtisch)
       Post #: 82
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 10:01:11 PM
bookmaker
Status: offline
When you get around to it, I have some very close up photos of the cowl hold down cable connections to the firewall. They were taken of the E.V replica in Alabama, but I'm sure they are the same for the DR I.
Dale
       Post #: 83
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 10:07:00 PM
deljon
Status: offline
I would love to see them Dale
Del
(in reply to bookmaker)
       Post #: 84
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 10:10:38 PM
bookmaker
Status: offline
OK, I'll get my D VIII photos together.
BTW, I really like the DRI project.
Dale
       Post #: 85
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/10/2006 5:12:58 AM
jtisch
Status: offline
quote:
ORIGINAL: deljon
You bet, I'm doing the rib taping now , so the cowl drilling doesn't seem so bad now.
       Post #: 86
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/20/2006 3:07:09 PM
jo-go
Status: offline
Hi Del,just discoverd your wonderful work-I have a 1/3 fokker DVI kit on order which I shall receive in October and I am very exited about the project since it is practically identical to the DRI{fuselage and rear end}I am currently scratch building the spandau guns and I am happy sofar with the result--the barrel cooling slots required absolut concentration on the milling processafter having plotted the individual slots on paper ,and it went ok, cocking levers,top hatches and safety catches are as per fullsize funktional,what woories me a bit wher to get the right gunmetal paint --found out the original ammo dimensions { 80,6mm total length]so next week I will tackel making the casings from 4.5 mmDia brass tubing and bullets using hardwood dowling--all great fun but took me sofar oodles of hours!- But at least I won't have to worry about them once the kit is built--Glenn does fantastic work also and it is a pleasure to watch your progress! --best wishes and keep it up!-regards jo-go
       Post #: 87
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/24/2006 1:51:27 AM
WinterHawke
Status: offline
Just a couple of photos from this last weekend's trip to Muncie, IN - Del brought the Dr.1 bits along with his for Show-and-Tell:
First up, a hard-at-work von Delby surveys the scene:
And Del's handiwork so far:
That is one very big cowling, y'all!!
Can't wait to see what comes next, Del!
'til later,
Lee
Arguing with a Scale Judge is like wrestling a pig in the mud - After an hour or so you figure out the pig enjoys it!
(in reply to jo-go)
       Post #: 88
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/24/2006 2:12:12 AM
Prop Nut
Status: offline
Del.....why is it that you look grumpy in all the pictures that I (and Lee it would seem) took of you?
Click to see fullsize image.
Click for fullsize
< Message edited by Prop Nut -- 8/24/2006 2:05:09 PM >
Scope? Listerine? Or Prop Wash?
(in reply to WinterHawke)
       Post #: 89
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/24/2006 2:39:46 PM
WinterHawke
Status: offline
quote:
ORIGINAL: Prop Nut
Dunno - probably 'cause he only got to fly eight times on Friday, and it got a bit too windy on Saturday afternoon!!! I have seen him happy at times:
He just doesn't like to be not flying - imagine that!!!
Dave, great picture of our von Delby - had a great time last weekend hanging out with everyone.
'til later,
Lee McD
(in reply to Prop Nut)
