RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Page: <<   < prev  43 44 [45] 46 47 48 49 50 51 52   next >   >>
Login
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/14/2011 9:48 AM
abufletcher
Score: 1576
Last Login: 5/19/2013
Status: offline
Have you guys seen these?
http://www.modelairplanenews.com/blog/2011/03/09/13-scale-scale-engines-from-nick-ziroli-plans/
Hide Signatures
(in reply to Canuck1)
       Post #: 1101
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/15/2011 1:46 AM
deljon
Score: 119
Last Login: 3/1/2012
Status: offline
My tip skids have been given a pretty good workout, have never broken one (yet). I personally have not had any
issues with the brass tab, I can see where it might.
What has happened with mine (more than once) there was more of a side load and kind of rolled the skid to the side
which bent the rear bracket, easily straighteded out and again nothing broke.
At this time I see know reason to do my next one any differant.
You're making great progress Craig..............
Del
_____________________________
FOKKERS FOREVER
Hide Signatures
       Post #: 1102
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/15/2011 4:06 AM
valleyk
Score: 101
Last Login: 5/14/2013
Status: offline
Funny Abu I just got that dummy engine and in the process of install. You can buy the engine in two configs. The whole engine (wt = 2.5 lbs) or just  four cylinder heads. Its solid sandable plastic and I needed to drill and dremel out to reduce wt under a pound. The mounting to air frame in front of gas engine is difficult but using a fhreaded coupling to gas enigne mounting bolts to extend a threaded rod for attachment did the trick. Also i got the busa guns done and that took a bit of time to finish. Now I need a pilot and no clue where to get one. Anyone have a 1/3 full body pilot they want to sell me?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to deljon)
       Post #: 1103
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/15/2011 5:35 AM
Canuck1
Score: 100
Last Login: 5/15/2013
Status: offline
Great pics Valleyk, thanks for posting them. Yes Del this does go fairly quick when I spend 5 hours a night in the basement
Worked on the outer wood struts. Managed to complete the bottom to mid wing struts this evening, lots of holes to drill and rivets to add.
First thing was to set them up properly. Using small bulldog clamps removed the strut from the brackets. Using them as my clamps drill a hole on each side if the strut. Issues with the holes aligning up exact are a problem if you bend them a little off. To remedy this, using a "T" pin I pushed it through the other side A small drop of med Ca and taped it into the hole. Did this for the first 3 rivets at the top, then alternated and got them all in. I peened them over as best I could on the other side. Happy with the way it turned out. I placed the nice rivet head facing in the outboard direction, easy to see as you look at the plane.
I then tapered the rear portion around the pin for a nice tight circle and fit.
I am happy with them. Tomorrow I will do the other 2 struts.
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to valleyk)
       Post #: 1104
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/15/2011 5:40 AM
abufletcher
Score: 1576
Status: offline
Looks fantastic! It's amazing how much work you can get done when you do a lot of work!
Hide Signatures
       Post #: 1105
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/15/2011 6:17 AM
Canuck1
Score: 100
Status: offline
I can normaly dedicate some good time at each building session. The snow is here so might as well build. Better than watching the TV
Craig
Eat, Sleep, Fly
Hide Signatures
(in reply to abufletcher)
       Post #: 1106
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/15/2011 6:42 AM
abufletcher
Score: 1576
Status: offline
I've got virtually endless time, but I find I can't stay focused enough for more than a couple of hours "in the shop" at a time. Often I'll do some building or detailing in the morning when I get up before heading in to work and then maybe another hour in the afternoon. At night I usually spend a couple of hours. But a lot of time is spent just figuring out HOW to do something.
No TV for me either.
Hide Signatures
       Post #: 1107
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/15/2011 7:00 AM
Canuck1
Score: 100
Status: offline
I know exactly what you are saying.
Some mornings I do some things before work. If I am doing a fair bit of epoxy work, then it is good to have it cure when I am not around.
I spend lots of time pondering the best way to tackle certain things...........then out of the blue, the lightbulb comes on.
Then there are other times this thread has showed me some great ideas, a note, the cable set up for the ailerons. There are a few good ideas.
I was just going to go with a single cable to each aileron, then using a balance cable to run the whole length of the wing, tieing in the ailerons.
I do like the idea of a servo to each aileron independant from each other. A little bit of redundancy can be a good thing.
OMG its midnight, time for bed
Craig
Eat, Sleep, Fly
Hide Signatures
       Post #: 1108
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/15/2011 10:45 AM
vogel605
Score: 100
Status: offline
quote:
ORIGINAL: abufletcher
Yeah....what he said double for me...
If everything seems to be going well, you have obviously overlooked something.
Ohio Dawn Patrol (just do it)
Hide Signatures
       Post #: 1109
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/16/2011 12:14 AM
cjthomas
Score: 100
Last Login: 7/22/2012
Status: offline
Hi Craig, I put two servos in because the original had two cables per aileron coming down into the fuse, and to get deferential aileron for adjustment. And you're right, there's allot of good ideas in this thread. Charlie
Hide Signatures
(in reply to vogel605)
       Post #: 1110
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/16/2011 7:03 AM
Canuck1
Score: 100
Status: offline
cjthomas
I like your set up. Looks like it would work pretty smooth, and the redundancy, by chance one servo craps out on you.
Tonight I finished the upper wooden struts. Gave them a quick spray of turquoise paint. They look great.
I hung them on the pins in reverse so they have a good place to dry.
Craig
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
(in reply to cjthomas)
       Post #: 1111
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/28/2011 5:55 AM
Canuck1
Score: 100
Status: offline
Been a while since I have posted.
Bottom and mid wing are built, and covered with Koverall. 2 coats of polycrylic, first coat right out of the can, and the second slightly thinned with water.
I will apply a few more thinned coats after the fake rib stictching is done.
Interplane struts are done, and painted. Will do the cacle bracing after all is clearcoated. with the struts as you see in the picture, it is pretty solid.
Next is the construction of the ailerons, then the linkage fabrication. That should take a bit of fiddling around to get the set up I want. Then I can finish the top wing.
So much more to do, it is fun, when it starts to look like a DR1
Craig
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1112
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/28/2011 7:12 AM
abufletcher
Score: 1576
Status: offline
The Koverall looks very good. Did you use it with Stix-it? Unfortunately, Stix-it is another of those flammable model supplies that makes it extremely difficult to have shipped or bring into Japan. I used to use BalsaLoc (and have in emergencies resorted to white glue). What will you use for the final fuel-proofing?
Hide Signatures
       Post #: 1113
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/1/2011 7:02 AM
Canuck1
Score: 100
Status: offline
Yes, I used stix it. It worked very well for attaching the Koverall.
For fuel proofing I was just thinking on doing the landing gear area, engine firewall area, etc. I dont think I will need to do the whole plane. However might change my mind
Was just thinking on a few aerosol cans from Top Flite, they are easy, and work pretty good. My second option is Klasskote.
Last few nights I have been doing the ailerons. They are constructed, hinges are attached. Have not mounted them yet or completed a final sanding. I was not happy with the 1/8th aluminum tube for the outer ends. I was kicking around a few ideas, either make them up of laminated wood or wrap them with carbon fiber. I went with the carbon fiber wrap. I had a sheet of it, so I just removed the strips from the matted piece, wrapped it around the aluminum. Used thin CA to secure it to the aluminum. It turned out well. Willl post some pics tomorrow.
Craig.
Eat, Sleep, Fly
Hide Signatures
       Post #: 1114
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/1/2011 5:12 PM
deljon
Score: 119
Status: offline
quote:
ORIGINAL: Canuck1
Craig.
Hey Craig, you're moving along quite nicely..........
On mine I sprayed the whole plane with Min wax clear satin, have not had any issues of the fuel hurting the paint.
The carbon fiber wrap sounds like a great idea, I think I'll do that on my next one...........
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 1115
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/1/2011 5:27 PM
abufletcher
Score: 1576
Status: offline
I forgot that you guys are using gasoline engines on these monsters. The polycrylic should be fine.
Hide Signatures
       Post #: 1116
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/1/2011 6:51 PM
WacoNut
Score: 175
Status: online
Del,
Great thread, I just re-read the entire thread again today. I am going to be building a 1/4 scale. I just sent Glenn an e-mail begging for the re-release of his 1/4 kit if not I will have to go with the Balsa USA. Anyhow I will be doing mine in the stock streaked camo pattern as you did on yours and I would really like to use latex. Do you have any eperience with latex and doing the streaking? I am asuming put down the tan base color and let it dry then thin the olive drab and start steaking. I think I will do all the streaking and then add the white fields and crosses and field markings.
Would love the 1/3 DR1 but I already have a 1/3 Waco and Cub taking up alot of storage space.
Thanks!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 1117
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/1/2011 7:17 PM
deljon
Score: 119
Status: offline
Thanks Anthony, glad you enjoyed the thread, it was a lot of fun doing it.
Yes, I have used latex on a couple 1/4 Dr.1s, it works just fine, accually it's faster as it dries fast and you can do all the
coats,(layers) in one day. However the glow fuel did start attacking the clear polly after a while, so you might want to check
into something else to fuelproof.
The reason I went with the enamel on the 1/3, I figured it would hold up better with gas engines. So far so good.
I know Glenn told me he was going to rerelease the 1/4 Dr.1, but if he told me the time frame I'm afraid I forgot (ole guy memory thing).
I think it's going to go together simular to the 1/3 scale.
Del
FOKKERS FOREVER
Hide Signatures
(in reply to WacoNut)
       Post #: 1118
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/1/2011 7:35 PM
WacoNut
Score: 175
Status: online
Thanks Del,
I have a new DLE-30 in the box for the Fokker. I will be using gas and do not expect any issues with the latex. I used clear poly on my Waco and Cub and have not noticed any ill effects from gas. I just make sure I clean the planes as soon as I am finished flying.
I will wait and see what Glenn has to say before placing my order for the BUSA kit. I am afraid this is taking a back seat to the SE5a.
BTW: I live in the Cincinnati area, I live outside of Blanchester and work in BlueAsh. I may have to pay you guys a visit at the field one of these days.
Later!!
Anthony
Hide Signatures
       Post #: 1119
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/2/2011 1:39 AM
valleyk
Score: 101
Status: offline
I also used latex for creating the streaking effect.
http://www.youtube.com/watch?v=tRwOWRi0KcI
Hide Signatures
       Post #: 1120
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/2/2011 6:50 AM
Canuck1
Score: 100
Status: offline
I will also be using a latex enamel. Sample wing turned out great, as well as the landing gear wing.
After getting back from a bit of Christmas shoppping, decided to put one more wrapped layer of carbon fibre on the 1/8 aluminum tube for the ailerons. I think this will add some good strength, and the weight is next to nothing.
I placed the ailerons on the trailing edge, need to cut the aluminum tubing for the bolts before I can attach the aileron. That will come next when I get some more time.
Craig
Nice video clip valleyk.....................looks good
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Eat, Sleep, Fly
Hide Signatures
       Post #: 1121
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/2/2011 12:39 PM
WacoNut
Score: 175
Status: online
Thanks for the video it looks great,
What barnd of latex did you use and do you have the paint formulas for mixing?
Thanks!!
Anthony
Hide Signatures
       Post #: 1122
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/2/2011 1:47 PM
deljon
Score: 119
Status: offline
quote:
ORIGINAL: WacoNut
Later!!
Anthony
That's not too far away, I live up near Oxford. My favorite field for WW1 flying is the Aero Modelers over at Harrison, (home of the Ohio Dawn Patrol).
Two grass runways, nice shaded grove along the flightlines. Nice bunch of WW1 guys also, (Barry paid me to say that )
I think they have open guest flying on Mondays.
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 1123
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/2/2011 1:51 PM
WacoNut
Score: 175
Status: online
If I can get my DR1 built and ready for flying this spring I will try to hook up and do a little flying. Next big challenge will be figuring out how to fit all the big planes in the trailer.
Later!
Anthony
Hide Signatures
       Post #: 1124
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 12/2/2011 3:38 PM
Horsepoweraviation
Score: 100
Last Login: 5/13/2013
Status: offline
quote:
ORIGINAL: WacoNut
Later!
Anthony
You will have plenty of Fokker company..........
HPA
Click for fullsize
OHIO DAWN PATROL
July 19-21 2013
Hide Signatures
       Post #: 1125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
