RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 1/19/2007 11:57 PM
deljon
Score: 100
Last Login: 11/5/2009
Status: offline
OK, got the four I-Beams glued up and spliced into two spars.
Care must be taken when spliceing for this wing. The wing from tip rib
to tip rib is 71 1/4". The two beams that make up the spar are 36" each
so that only allows no more that a 3/4" splice. That don't seem like a lot,
but with the ply splice supports on the inside of the beam and the spar
webbing in the center section will probably be 1/16 ply. So that should
make for a very strong joint.
As with the top wing will now square up and align each rib just tacking them
as I go. Will then recheck all the alignments and glue permanently.
Ribs all glued up and webbing glued in top and bottom.
LE and TE glued in place. The front of the two ply ribs will not be glued in place until the wing is fitted to the fuse.
Reason being they will need to be set at an angle for clearance of the landing gear. That angle will be determined when the wing is properly aliened with the fuse.
Del
< Message edited by deljon -- 2/4/2007 10:57 PM >
_____________________________
FOKKERS FOREVER
Hide Signatures
(in reply to US185Damiani)
       Post #: 151
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 1/20/2007 2:47 AM
abufletcher
Score: 1517
Last Login: 11/8/2009
Status: online
I'm sure that will be strong enough. But it seems to me that it might be preferrable to use three sticks and make two longer slices at other than the center point. For example, there could be one long piece in the center and then two shorter sections sliced on towards the wingtips.
As I said, I'm sure this will be fine but since this is the prototype it's always good to consider options for the future of the kit.
Hide Signatures
(in reply to deljon)
       Post #: 152
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 1/20/2007 2:59 AM
deljon
Score: 100
Status: offline
Don......I beleave Glenn's reason is a cost factor. Having the spruce sticks
milled I guess is not cheap. I think he wants to have the best quality kit
at the most reasonable price possible.
With the splice in the middle, there will be a hold down bolt on each side of
it, plus you will have the added strength of the inter wing struts.
With the ply webbing in the center section should be a very strong wing.
Del
FOKKERS FOREVER
Hide Signatures
(in reply to abufletcher)
       Post #: 153
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 1/20/2007 3:10 AM
abufletcher
Score: 1517
Status: online
That sounds like a very reasonable decision. I just remembered someone mentioning this other option in a thread I started a while ago on spar splicing.
Hide Signatures
       Post #: 154
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 6:57 PM
deljon
Score: 100
Status: offline
Got another box of goodies yesterday. Got the parts for the middle wing.
Started glueing up the I-beams for the spars last night. So, shouldn't take
too long to frame this one up. Construction the same as the other two, so
no need to duplicate pictures. One area of difference is the center section
where the curved cutouts are. When I get there will show that part.
The reason that I haven't totally finished framing the other wings is Glenn
is waiting to get the fittings for the inner wing struts from the vendor. These
need to be bolted to the spar before its closed up with the webbing. Same for
the tip skids.
I've heard that some are not getting the pictures when the go to the site.
I get them alright on my computer, I don't have an answer for that problem??
Later
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 155
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 7:02 PM
abufletcher
Score: 1517
Status: online
Yeah, the photos on the other pages are there but the ones on p.7 are missing for me. I'm on a Mac using Safari.
Hide Signatures
       Post #: 156
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 7:05 PM
deljon
Score: 100
Status: offline
I'll try an edit and repost and see if that helps.
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 157
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 7:11 PM
deljon
Score: 100
Status: offline
Ok, just deleted and reposted the pictures, Did it help????
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 158
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 9:41 PM
WinterHawke
Score: 100
Last Login: 11/7/2009
Status: offline
Del,
Photos on this page now are coming through fine - probably one of them internet things
Looking forward to seeing your handiwork in person this weekend, as I'll be in town for a visit.
'til later,
Lee
Arguing with a Scale Judge is like wrestling a pig in the mud - After an hour or so you figure out the pig enjoys it!
Hide Signatures
       Post #: 159
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 11:01 PM
Babblefish7
Score: 100
Last Login: 8/19/2009
Status: offline
Del,
The build is coming along just great. Would love to see some pics of the stuff from far back to get a better idea of the size of this monster. I wish I had room for these big guys. Have you heard from Glenn when you will be getting the fuse to build? The build looks great so far keep posting.
Mark
Ok which dot up there is mine?
Hide Signatures
(in reply to WinterHawke)
       Post #: 160
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 11:16 PM
deljon
Score: 100
Status: offline
Mark.......Can you get the pictures starting on page ONE?? These are all the ones that I've posted.
If I remember right the top wing is 96"
Should be getting the fuse. plans pretty soon, I think he's working on them now.
He's going to offer two ways to do the fuse. longerons. 5/16 square stock or 5/16 dowels.
I chose to do the dowels for a more scale appearance. If you chose the dowels, he suggests that you go to Lowes or Home Depot where you can get 4' long ones, that way you don't have to splice them.
The reason for not including the 4' dowels in the kit is it would cost more because shipping for a 4' long box would cost a whole lot more.
Later
Del
FOKKERS FOREVER
Hide Signatures
(in reply to Babblefish7)
       Post #: 161
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 11:39 PM
Prop Nut
Score: 100
Last Login: 10/6/2009
Status: offline
Whooo Hooo! Del, I am looking forward to this summer. I should have my 1/3rd scale Sopwith Tripe done by then. We can have a ball at Dayton and Muncie (a furball that is). Sir Percy says that the number of 1/3rd scale planes is exploding this winter.
< Message edited by Prop Nut -- 2/1/2007 11:45 PM >
Scope? Listerine? Or Prop Wash?
Hide Signatures
       Post #: 162
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 11:50 PM
deljon
Score: 100
Status: offline
Hey David....Sure looks like it' shaping up to be a great summer.
GREAT TIMES WILL BE HAD BY ALL.
Hey, why don't ya do a thread on the Tripe, would love to see it.
Del
FOKKERS FOREVER
Hide Signatures
(in reply to Prop Nut)
       Post #: 163
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/1/2007 11:59 PM
Prop Nut
Score: 100
Status: offline
Things are not good here right now, so my building is on again and off again. I do hope to finish it by fall, in time for Ohio and Indiana.
Hide Signatures
       Post #: 164
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/4/2007 3:38 AM
WinterHawke
Score: 100
Status: offline
quote:
ORIGINAL: Babblefish7
Del,
Mark
Hey, Mark . . .
Got a chance to visit the Fokker Factory - aka Del's Basement this weekend, and got some pics of von Delby and his bird:
Del holding the top wing (without wingtips, it darn near reaches the ceiling!):
Top wing, lower wing, with Del holding the cowling:
And a bit closer, with the stab as well:
Hide Signatures
       Post #: 165
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/4/2007 3:42 AM
WinterHawke
Score: 100
Status: offline
And just a few more:
Del with the bottom wing (again, no tips on it yet):
A bit closer - that's the rudder and subwing hiding back there!:
I think Del's enjoys his work!!!:
Best regards,
Lee McDuffee
the WinterHawke
(and bye the bye - Winter around these parts really bites!
< Message edited by WinterHawke -- 2/4/2007 3:45 AM >
Hide Signatures
       Post #: 166
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/4/2007 2:21 PM
Babblefish7
Score: 100
Status: offline
Hey Lee,
Those pictures are great. You can really get in idea of how big 1/3 scale really is. I definitely need to stay with ¼ scale and with two-piece top wings. Lol I can’t wait to see the finished project at Dayton this year.
Thanks Lee
Mark
Hide Signatures
       Post #: 167
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/5/2007 4:41 AM
flyingrazor
Score: 100
Last Login: 7/2/2009
Status: offline
Hey Del - you seem to have more building room than me... what's up with that ? looks real good. Having you stand by the wings does give us the size of things. 1/3 scale does open some doors for more scale detail, in that, you can find some off the shelf parts that can plug right in... at 1/4 scale a lot of them have to be fabricated which does run up costs. Actually, the triplane is rather small compared to some other 1/3 scales out there. You look at the wing chord and wonder is it really 1/3 scale. Meaning you multiple by three and now it's full scale and your climbing in to fly it. Not that much wing... but times three wings, there is plenty...
Hide Signatures
       Post #: 168
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/5/2007 2:20 PM
bhole74
Score: 100
Last Login: 9/22/2009
Status: offline
Hey Lee,
Thanks Lee
Mark
This might give you an idea of how big it's going to be.
Can you name the characters in the pic? LOL!
Click to see fullsize image.
Click for fullsize
< Message edited by bhole74 -- 2/5/2007 2:21 PM >
Had I known that flight was going to cost me $100 per second, I wouldn't have flown 30 seconds!
Hide Signatures
       Post #: 169
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/8/2007 6:23 PM
deljon
Score: 100
Status: offline
Can't quite make out the guys, but the airplanes sure look familiar. Howdy Guys
Got the mid wing mostly framed up, same proceedure as the other two except the center section.
The rear of the two center ribs where the arch attaches will also be set at an angle .
Each cutout or arch will be laminated using 1/16 bass wood and 1/32 ply. Should make for a very strong structure.
Again will use the provided cardbard template or pattern to get the proper radius on the arch.
Del
< Message edited by deljon -- 2/8/2007 6:24 PM >
FOKKERS FOREVER
Hide Signatures
(in reply to bhole74)
       Post #: 170
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/9/2007 12:11 AM
TKFOKKER
Score: 100
Last Login: 11/4/2009
Status: offline
Hey Del- Your Fokker is looking very nice, I can't wait to build an airplane I can put together with glue. I'll tell ya building everything out of metal is not alot of fun. I don't know what I'll build after the D-8 is done. I'm very interested to see how your fuse comes together using dowels. I always wanted to try that. You should have the finest fokker triplane on the planet when your done! Keep up the good work, Tom
Hide Signatures
       Post #: 171
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/9/2007 12:20 AM
deljon
Score: 100
Status: offline
Thanks Tom..........Hey, maybe that's why yer gett'n so much done, you ain't be sniff'n no glue lately!!!!!!!!!!!
Seriously, ya gotta love the way Glenn engineers a kit. Really a fun build.
Del
FOKKERS FOREVER
Hide Signatures
(in reply to TKFOKKER)
       Post #: 172
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/9/2007 6:41 PM
deljon
Score: 100
Status: offline
Ok, after much consideration I decided to change the color scheme from Muller's to Baumer's.
While I still like Muller's scheme, I like Paul Baumer's 204/17 (early version) much better.
There's also a color rendition in Osprey's book #40, Dr.1 Aces of WW1, pages 36 & 44 figures #11
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 173
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/10/2007 2:29 PM
WinterHawke
Score: 100
Status: offline
And the nice thing about this particular colorscheme is that you'll only have to mask and paint 11 of them iron crosses
'morning, Del - I too really like this scheme - there's a lot going on, but it still will feature that fabulous Fokker streaked camoflage. One other nice thing about it is that at least you have the serial number, and therefore the werke number, instead of having to guess.
Lee
Hide Signatures
       Post #: 174
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 2/10/2007 5:08 PM
deljon
Score: 100
Status: offline
Tom.......This will be my first time using dowels for a fuse., just love a good challange. We know it's doable cause Glenn did it on the DVI. Will make for a very nice scale appearance.
I should have it about ready to cover by Toledo. I will have it there in the bones in Glenn's booth, hopefully with engine, cowl and servos installed. At least that's the plan. (But like Lee always likes to point out, Gen.Custer had a plan).
Lee.......You know me, I just love to build wings and paint crosses.
Accually Baumer's scheme was my first choice, then went with Muller, you know how I like stripes, Then decided to go back with the first choice.
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.375RCU1
