fuel tank cap o ring air anfd fuel leak leak
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> IRC Racing Support >> fuel tank cap o ring air anfd fuel leak leak
Page: [1]
Login
fuel tank cap o ring air anfd fuel leak leak - 6/17/2006 6:18:29 AM
rcworld2000com
Status: offline
I have one other question my fuel tank is leaking around the lid door. it used to close tightly now i can tell it has way less resistance when closing someone said to tighten the screw un the cap but that has not helped.
i have to keep pressure on the cap just to get the motor to start or it leaks so bad there is not enough back pressure to push fuel in to the carb..
do you know what size that o ring is maybe i can find a new one.
do you have any idea why the ring would go out. i have probaly only ran 10 tanks after break in..
Derrick
       Post #: 1
RE: fuel tank cap o ring air anfd fuel leak leak - 6/17/2006 10:08:32 PM
huw4027
Status: offline
Boy oh boy you seem to be very unlucky with your Vulcan.
_____________________________
R/C IS GOOD, CLEAN FUN !!! - Too much to list !!
1/18,1/16,1/10,1/8 & 1/5 scales-nitro,gas & electric.
(in reply to rcworld2000com)
       Post #: 2
RE: fuel tank cap o ring air anfd fuel leak leak - 6/18/2006 12:06:26 AM
rcworld2000com
Status: offline
the vulcan is fine .. the two speed is what was broke.. the set screw for the shift point was cross threaded when manufactured..
and as for the tank well i guess i have bad luck
       Post #: 3
RE: fuel tank cap o ring air anfd fuel leak leak - 6/22/2006 7:38:09 PM
Mindcrime
Status: offline
Sorry Derrik, RC-Boss told me you were asking about me, for some reason my email notification isn't working...I'm not sure what size the o-ring is, and we do not sell them.. (only with tank assm.)...I will PM you when the 2-speeds are back in stock.
IRC Racing
       Post #: 4
RE: fuel tank cap o ring air anfd fuel leak leak - 7/16/2006 2:14:04 PM
HYPERGOBLIN
Status: offline
Derrik,
You would need 10mm (ID) x 14mm (OD) silicone o-ring, I got mine from a local hardware store - o-ring set.
Tightening the screw underneath the cap work as well (to an extent - if you're o-ring is not busted)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
