teresos -> RE: Bernard Dumas' Canadair CL-215 (9/22/2007 2:17:26 PM)
Cockpit PART 3 After you glue the 3 levels together ,you must glue the whole construction on the notch and the side windshields ...photo 1... ( I used epoxy ). Finally , what you will see ,is shown in ...photo 2-3... Now, it's time to cut the frond windows. Use one piece of cartboard to create the mould of the first window. At the base of the window ,you must follow the curve of the fuse. Empty the cardboard to create the frame of the window.Put the cardboard on a lite ply , cut the 1st window .Reverse the cardboard, cut ,and you have the 2nd window ...photo 4-a-b-c ... If you want the front windows to have better contactwith the fuse, you must take out the angle from the inner side of the windows ...photo 5... I added two little pieces of 2mm sheeting, following the curve of the windows ...photo 6-7-8...
