RE: Bernard Dumas' Canadair CL-215 (Full Version)
All Forums >> [RC Airplanes] >> Seaplanes
Message
g_boxwood -> RE: Bernard Dumas' Canadair CL-215 (6/4/2008 4:29:33 PM)
Great work George!
Nice looking, scale in actuation and perfectly working!
Moreover the nose-well-sealing may not be that difficult in the end... thumbs up!
Ciao nubiros!
The 2 90SPs seem overkill to me: they're heavier then the 60s (which are heavier than a standard 4-stroke .70 ) and the torque/prop dia they output is unnecessary.
The 60SPs are fine, heavier than .40-.45s 2-stroke and than .70s 4-stroke, more expensive too, but they look scale inside the cowl and they turn more scale multi-bladed props: please bear in mind that the reccomended 3-blade prop the 60s turn (APC 13.4x13.5) fits by a 1/2" or so before eating the fuse... while the 3-bladed 15.75x13 the 90s turn will surely cut through it!
HTH,
Kmot -> RE: Bernard Dumas' Canadair CL-215 (6/6/2008 2:07:00 AM)
Nice work on the landing gear teresos!
prokyz -> RE: Bernard Dumas' Canadair CL-215 (6/8/2008 1:31:29 PM)
Maybe my thread will be stupid, if so, please excuse me.
Is it possible for the front gear movement to be smoother?
I have no experience with retracting gears, so I just ask.
Another question: where am I able to get FESTO components or other brands' components for retracting gears?
THX guys.
teresos -> RE: Bernard Dumas' Canadair CL-215 (6/9/2008 1:23:46 AM)
quote:
ORIGINAL: prokyz
THX guys.
Hi , prokyz
I'm using the Robart 167VR Variable Rate Control Valve to control the air flow to cylinders
http://www.robart.com/air_systems/valves.aspx
This is Festo for Czech Republic : http://www.festo.com/INetDomino/cz/cs/35130f6d71a7d9e5c1256b5d0054f2a0.htm
Festo cylinders have various mounting options, with or without additional mounting components.
They have a diameter of 8 ... 63 mm for double-acting and single-acting cylinders , standard stroke lengths 10-15-20-25-etc but you can
order any stroke length from 1 to 500 mm and any mounting type you want.
Also the DSNU type cylinders have a magnetic ring build inside with the piston.With an external magnetic sensor
(extra order ...25 euros in Greece) you can use it as a switch for landing lights.
Take a look at festo catalog , they have a wide range of components and all in mm
George
schiorro -> RE: Bernard Dumas' Canadair CL-215 (7/8/2008 1:44:04 PM)
Hello everybody, after about 1 year of work, that's my CL-415.
Thank's to all post in this Thread it was very usefull for building mine.
Some data:
Model: Aeronaut Cl-415
Weight: 2.8KG;
Radio: Futaba FF9
Riceiver: r149DP;
Servos: 5 Hs82MG(Ailerns,rudder,elevator,front gear); 2 hs75BB(landing gears ); 1 Digital Hyperion servos for Flaps(programmed for slow motion).
Engine: 2 Brushless Lipotech 1416 with 4 blade prop; 2 ESC speed 60 (calculated Thrust about 2.5 KG);
Power - Radio: FlightTech 8AMP;Lipo 7.2V 1200
Power - engines: Lipo 3300
Lights: home build microcontrolled linked to channel 8 (Beacon, Landings, wing nav; Nav rudder);
Painted skill: Italian "Protezione civile" I-DPCG (1/72 Italian Kits resampled to 1/17)
Some pictures attached...
By
Emiliano
drewhosick -> RE: Bernard Dumas' Canadair CL-215 (7/8/2008 1:53:36 PM)
Beautiful job on the plane
Strykaas -> RE: Bernard Dumas' Canadair CL-215 (7/8/2008 4:26:05 PM)
quote:
ORIGINAL: schiorro
Some data:
Weight: 2.8KG;
Radio: Futaba FF9
Riceiver: r149DP;
By
Emiliano
Blah blah blah... where are the spinners [8|] ? [8D]
schiorro -> RE: Bernard Dumas' Canadair CL-215 (7/9/2008 8:06:19 AM)
I'm still finishing the plane, the prop hub is home made and the spinner also...[:D]
Bye
Emiliano
nubiros -> RE: Bernard Dumas' Canadair CL-215 (7/12/2008 5:38:40 PM)
hi guys
tell me st about two below engines:
1- the engine that mentioned in the map ( maybe with 1.4 bhp )
2- rcv60 - sp (0.9 bhp)
can we replace second one with first one for maximum weigh ( 6 kg )?
anothe question:
difference between engine power (bhp) and engine volume (cc)? and which item is more important for selecting the engine?
which material can be replace with AL-7075? [&o]
WALKERS210-RCU -> RE: Bernard Dumas' Canadair CL-215 (7/13/2008 7:34:00 AM)
Fantastic job on the plane. One question, are the props variable pitch. These pictures have re-lit a fire in me to start building again.
schiorro -> RE: Bernard Dumas' Canadair CL-215 (7/16/2008 10:01:04 AM)
The props are Aeronaut camcarbon with profile variable pitch.
This is the test flight I had saturday...
Canadair CL415 RC video
Strykaas -> RE: Bernard Dumas' Canadair CL-215 (7/16/2008 12:15:03 PM)
Nice! Time to take it to the lake :)
Kmot -> RE: Bernard Dumas' Canadair CL-215 (7/16/2008 3:57:30 PM)
Bravo schiorro! It's fantastic! [sm=thumbup.gif]
loukos -> RE: Bernard Dumas' Canadair CL-215 (7/17/2008 6:50:12 AM)
Stunning models, does anyone do a laser cut kit for these plans?
schiorro -> RE: Bernard Dumas' Canadair CL-215 (7/24/2008 8:17:42 AM)
Thank you,
I'm now doing some waterproof controls for water takeoff...[sm=drowning.gif] and I hope to have enought thrust for water takeoff.
bye
Emiliano
fourmje -> RE: Bernard Dumas' Canadair CL-215 (7/30/2008 1:38:06 PM)
Hi schiorro,
Beautifull job on your canadair, congratulations !
Could you tell me more about the retractable landing gear, is it home made ? I am looking for the same for my aeronaut canadair(ordered since 23 june and not yet received).
Thanks a lot,
jerome
Page: <<   < prev  7 8 9 10 11 12 13 14 15 [16]
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.28125
