g_boxwood -> RE: Bernard Dumas' Canadair CL-215 (9/4/2006 8:57:22 PM)
I finalized the hull by installing the last 4 stringers** and by bridging the gearwell with some scrap stick to support the sheeting. **I didn't blend those stringers into the nose section (as I originally stated) due to the very high -added complexity over gained benefit- ratio: it isn't really necessary. The optional stringers I added to the nose section are a nice extra touch but probably not worth the time spent... these plans are well thought-out, mods turned out to be almost useless... I also added soft balsa sticks to both sides of the keel as I did earlier to better support the sheets where they butt up against each other. I sealed the nose well portion that protrudes into the cabin fllor and then added the roof formers and stringers just behind the cockpit. Basically the fuse is done, I'll now sheet the hull, the nose and the sides ahead of the step. I'll sheet the tail sides later on, I must build the fin/rudder first.
