g_boxwood -> RE: Bernard Dumas' Canadair CL-215 (1/9/2007 6:25:28 PM)
Hi strykaas! Thanks for your comment! I don't know if I did understand it right but I'll provide some additional infos about the setup that may help to clear things up. Here is the complete system: [image]http://www.geocities.com/g_boxwood/SOLID_07.gif[/image] As you see each leg has its own cylinder, while the 3rd -floating- cylinder is for the locking mechanism. Locking in the down position occurs when the 2 highest arms align (along the green line): loads from the ground are transferred up to the hinge where they are fought by reaction forces (blue arrows) coming from the anchor point. This is what keeps the gear down, not the air cylinder. To unlock, the highest cylinder (the floating one), pushes the arms away, the arms rotate and the hinges flex, moving toward the fuse. At the same time the retracting cylinders pull everything up without locking it in the up position. Sorry for the description but everything will be much more clear now. As I said I probably didn't understand exactly what your concern was so please feel free to get back to it so we can deal with it! That would surely help!
