g_boxwood -> RE: Bernard Dumas' Canadair CL-215 (1/24/2007 3:01:58 PM)
I did my homework with my left hand in these last few days... here it is what I came up with. I was looking for air cylinders to operate the gear: I was looking @ the units made by Robart (3/8" bore), Skymaster, Ultra-Precision, Jet-1A, BVM and similars, when I came across 2 companies that make professional cyls of almost any size... www.bimba.com & www.clippard.com These are totally different animals than those listed above: 304 stainless steel body, 303 ss piston and rod, alu end-caps, bore sizes starting @ 5/16" , 7/16" , 1/2" and custom stroke lenghts, double or single effect, with or without failsafe springs... I think you got it! [image]http://www.geocities.com/gb_teknik/CL-215/cutaway.jpg[/image] It took me yesterday to browse through the many possible solutions and the CAD files provided by both the mfg.s surely helped me making up my mind: I actually integrated the selected cylinders into the model and tested if they worked as I expected. LOWER Cylinders Both Bimba and Clippard work fine: Bimba's are 7/16" bore while Clippard are 1/2", they share the same length and the same 1" stroke; identical, Bimba being polished on the outside. [image]http://www.geocities.com/gb_teknik/CL-215/BIMBA_CLIPPARD.jpg[/image] UPPER Cylinder Here 1/2" stroke is needed PLUS some extra rod length (around 0.36'') that is more easily tuned with Bimbas than with Clippards. Same bore as above, 7/16". Attached pics show setup with Clippards (first 2 on the left) and Bimbas (right, darker cyls)... not many differences at all!
